In addition to The
@gsxr's statement about using 0W-anything in an M119 (let alone an M117), I am personally allergic to anyone trying to apply 2019-era specifications to an engine that was designed 35 years ago. The goals are just different now, and more focused on engine efficiency and emissions reduction, and for which today's engines (with their tighter tolerances, and all) are expressly designed for.
Would you use the latest Dexron VI transmission oil in a 722.3? It would probably work, but it's FAR better to use a Dexron-II/III type/spec focused transmission oil than the current-spec stuff.
IMHO it is best to try to use the oils/fluids that are as close as possible to those that the engine/systems were designed to run on, and that were available then, than to try to "retroactively" apply the current stuff to those old engines.
Here is a copy of the oil spec sheet from the time frame (July, 1994 edition) when our cars were new.
Do you see 0W-ANYTHING in that graph? NOPE!
Do you see 5W-ANYTHING in that graph? YEP -- for the widest temperature range applications, but ONLY for those with extremely cold climates. ONLY 5W-** for situations where extremely cold climates exist.
For applications down to 0 degrees Fahrenheit / -20 degrees centigrade, you see 10W-** and 15W-** oils being specified !!!
For applications down to 32 degrees Fahrenheit / 0 degrees centigrade, you see 20W-** oils being specified !!!!
Remember that now, with global warming, it's rare to even get below 32F / 0C anymore. So that means that even 5W-** oils are really not even needed anymore.
As I said before, 10W-30, 10W-40, or even 15W-40 work excellently for 95% of all situations.
