I replaced my ETA with a $200 used ETA from Ebay. Thanks to Dave who pointed out that the date tag, 02M11, meant that this was a unit that was made in November 2002, with the good insulation -- not the crap MB used to make the originals.
The job was much easier than I anticipated. It took about 90 minutes and I even took my time. The hoses were all brittle and broke as they came off, as expected, so I had the new ones ready to go.
I used a long screwdriver to loosen the large hose clamps on the rubber collar between the MAF and ETA. The vertical brake vacuum pipe comes off in two pieces. The bottom piece has an aluminum washer where it mates up to the intake manifold. I was able to use my 19 mm crow's foot wrench, which was the first time I ever found a use for it.
I read Jim Forgione's post about losing the throttle linkage spring, so as soon as I popped off the throttle cable I secured the spring with a few large rubber bands. He said he spent a few hours trying to reattach the spring because it came off on him. I can see how difficult it would be to try to find where the other end of that spring connects under the intake runners towards the front of the engine.
So far, there are no problems, other than an intermittent idle problem that popped up last night before I even changed the ETA. For some reason, when I move the gear selector to drive or reverse, the idle bounces +/- 200 RPM with a frequency of about one second. Put it back in neutral and the idle is smooth as glass.
Since it happened with the old ETA, I have ruled the ETA out as a problem and I suspect it may be the Neutral Safety Switch, which I replaced about two years ago, but I bought it from AutohausAZ and I don't know about the quality of the part. I plan to order a factory NSS this week. This idle problem occurred on my old 400E about ten years ago and it was the NSS that ultimately fixed it.
Well, here are some pictures. Sorry this post is nowhere near as detailed and professional as GVZ's.
