I like the $19 price but not if there is clicking or slop in the gears. Stay tuned.
What are reset contact points?agree with above, gleitpaste on the gears, and the reset contact points.
The cone-shaped plastic bulb on the end of the shaft that you push inward to reset the trip odometer. You lubricate slightly this plastic bulb along with the point where it contacts the lever that it pushes to reset the trip odo.What are reset contact points?
Interesting. My 12-tooth was in pieces and my black gear had one tooth gone. Wonder if one took out the other.No, just push the 12 tooth gear on with your thumb. Its a press fit. My original twelve tooth gear looked fine. In retrospect there was no need to replace. I think it was the original black gear I changed out that caused problems.
Okay, I'm stuck. I look at the brass sleeve on the spindle that is closest to the camera and while I do not want to yank on it, I do not understand the side-cutters procedure. Do I snip at it like I would cut an electrical wire with the side cutters? I just don't want to screw anything up. Thx for any adviceReplacement of the gears is not difficult. There is a small brass retainer sleeve that holds the small gear on. This sleeve comes off with pliers. [GSXR edit: Do not pull off the sleeve with pliers! Deform it with side-cutters so it slides off the shaft with finger pressure only. Forcing it off with tools will damage the motor.] You DO NOT need the sleeve with the replacement gear. It slides on with enough friction to stay in place. You can access the sleeve and small gear without removing the clear plastic cover. The other two gears require removal of the plastic cover. I removed the sleeve and small gear without first removing the cover because I had only intended on changing the small gear, until I saw that a large gear had a tooth missing too and I determined that all three gears should be replaced.
Installation of the new gear, without the brass sleeve, will require some force... but because the new gear is supposed to be a friction fit, this is normal.Sliding the E1 12 tooth gear onto the shaft is requiring more effort than I'm comfortable with. I bought the part from Garagistic so I trust it is the correct part. It is so snug I cannot even get it started onto the shaft let alone slide it down. Is there a trick?
I was wondering if a little heat might help installation. Hot tap water might do the trick?Heat up the gear in hot water?
Yes, these charts come with the instructions when you purchase a speedo correction box, so that you can correctly calibrate the new gear ratio with the existing speedometer. I have posted on this topic before, as I did this with my 560SEC about 15 years ago, when I switched from the stock 2.47:1 final drive ratio, to a 3.07:1 sourced from a W116 450SEL.Does anyone have a chart for accurately changing the gear ratio after say installing a different differential ratio?
Thanks Gerry!Yes, these charts come with the instructions when you purchase a speedo correction box, so that you can correctly calibrate the new gear ratio with the existing speedometer. I have posted on this topic before, as I did this with my 560SEC about 15 years ago, when I switched from the stock 2.47:1 final drive ratio, to a 3.07:1 sourced from a W116 450SEL.
OWNER - 600Eric | Owners and Their Cars
Looking really good Eric. Can't wait to se it person.www.500eboard.co
The gears are for the odometer only.Does anyone have a chart for accurately changing the gear ratio after say installing a different differential ratio?
Thanks for the great info and clarification as always!The gears are for the odometer only.
The speedometer can't be adjusted via gearing.
When changing axle/differential ratio, you need an electronic converter box like YellowBox (on backorder) or Abbot & Costello ERA, which Gerry linked above. Th is will adjust both speedometer & odometer automatically, and works if you are not changing the speedo faceplate scale (i.e, if you change from a 160mph to 190mph faceplate, custom modifications are required - not DIY'able AFAIK).
I’m hoping someone has a 94-95 E420 euro spec car which came with a 2.65 dif that would happen to know or have access to a Speedo that could let us know the tooth count???Anyone know the tooth count for a USA speedometer for a 2.65 diff ?
Thanks,
neil
I know, I know... but I've only had these fail once, ever, on any car over nearly 3 decades of MB ownership. I do have spare speedos in stock but didn't want to bother taking apart a used one, to likely find the used gears were the consistency of stale Oreos.You didn’t have a set or two in your spare parts stock?
Tsk tsk.
Your 124 hoarding foresight seems to be lagging in recent months...In hindsight I should have ordered 2-3 sets. OOOPS.
See post #34 in this thread.Hello all. My odometer stopped working a while ago so today I took the odometer apart to see which gears I had to replace and the three gears made with the soft material were completely disintegrated... My 500E is a euro 1992 model with an odometer in KM/H. I'm using the two pages recommended in the previous posts to get the new gears (garagistic and odometer gears) but I don´t know which gears to buy. Does anyone know which gears I must get?
You should not need to replace E4/E5 gears, and yes they would be different than USA/MPH speedometers.The other two gears that are not replaceable seem different from the ones I´ve seen in this thread (see attached), is it because my car is in KM?
