| 1993 Engine Assembly Mercedes E Class E500E | CHECK TYPE | | X | X60079 | $700 | All Star Auto Recycling USA-CA(Corning) Request_Quote 1-530-824-2880 Request_Insurance_Quote![]() |
With @gsxr’s input I grabbed a 91 2.65 dif from a low mile non-asr 500SL from a local recycler for $100.
All i had to do was change the side seals, reseal the rear seal and change the oil and it’s plug and play.
My retired MB mechanic buddy insisted we change the rear flex disc when installing the differential even though it didn’t look bad.
Regardless, it was the biggest bang for the buck and also the best upgrade I’ve done on my 420. Highly recommended.
That looks promising. Get the VIN of the donor car and a photo of the engine serial.
1993
Engine Assembly
Mercedes E Class E500ECHECK TYPE XX60079 $700All Star Auto Recycling USA-CA(Corning) Request_Quote 1-530-824-2880 Request_Insurance_Quote
Wrong diff... won't work. It's from a later S420 and has no hole at the pinion for your ABS sensor. Ad says donor is a 1995 S420, VIN WDBGA43E4SA242098, and the EPC says only up to chassis A212244 works, without code 867 (MODEL SERIES 140 MODIFICATION PACKAGE 06/94). This is why you always need to confirm with photos. I think in general you need a 92-94 only, and most 1995 won't work.![]()
94-99 MERCEDES W140 S420 REAR DIFFERENTIAL DIFF AXLE CARRIER 1293510405 2.82 OEM | eBay
Find many great new & used options and get the best deals for 94-99 MERCEDES W140 S420 REAR DIFFERENTIAL DIFF AXLE CARRIER 1293510405 2.82 OEM at the best online prices at eBay! Free shipping for many products!www.ebay.com
Numbers indicate that it's from a non-ASR as well. Can't see the ratio number besides in the listing.
There were about a dozen available around Sacramento valley for $100 to $150.All that torque needs a little more multiplication.
Have you felt any discernable difference in MPG on long highway trips? Honestly not a major concern with this car the way I drive but with the prolonged higher revs I'll still feel bad for the engine.
Also are you using anything to correct the speedo?
Yeah, that what I’m experiencingMPG may be 1-2mpg less on a long freeway trip, if even that much. It's not a huge difference.
Should be around 2800rpm at 75mph with 2.65 gears
Were there non-ASR W140 S-classes?That looks promising. Get the VIN of the donor car and a photo of the engine serial.
I believe Dave said 90,91,92 500SLWhat specific models and years that can serve as 2.65 differential donor for NON-ASR 400E?
How does one distinguish ASR vs non-ASR differential? I assume this is an ASR diff because it has 2 cables plugged into it, and a non-ASR would have only one, is that correct?
Thanks! Can you please describe, using extra epithets, what and how you've felt during the first 10 miles after installing a 2.65 differential? I just want to hear itI believe Dave said 90,91,92 500SL
One cable for Non ASR,
Two cables for ASR
Yes. ASR was standard on the 5.0L and 6.0L, but this was optional equipment on the lesser 140's, at least through 1995. At some point in the late 90's it might have become standard equipment, but it doesn't matter on the late stuff, because the design changed in late 94 or early 95 model year (VIN break noted above) where the speed sensors were relocated to the wheel carrier instead of on top of the differential. Cost reduction - allowed using the same diff for models with & without ASR/ESP/whatever.Were there non-ASR W140 S-classes?
See below.What specific models and years that can serve as 2.65 differential donor for NON-ASR 400E?
Correct!How does one distinguish ASR vs non-ASR differential? I assume this is an ASR diff because it has 2 cables plugged into it, and a non-ASR would have only one, is that correct?
Yes. 129.066 chassis, verify via datacard or photos of the diff, to confirm ASR vs non-ASR.I believe Dave said 90,91,92 500SL
Two cables for ASR
If you could find a nice one under $200 delivered that would be great. I'd pay a bit more for a lower-mile, rust-free diff but that's hard to find. I think Kegman got one for ~$150 locally?Dave, what's in your opinion a fair price range for 1990-93 SL500 non-ASR differential?
YUP! Use car-part.com as well, and search for "carrier". Be careful, sometimes they list S500 thinking the SL is the same, and it ain't... this is where the donor VIN is very helpful in weeding out the wrong stuff.I see several listings for "carrier" or "carrier assembly" on eBay. Pictures are of junked SL500s, but not if any specific part.
Is "carrier" or "carrier assembly" another term for a complete differential?
I got it for $100. They had three of them at Stockton, CA recycling place. They all were listed as no ASR. I picked the one with super low mileage and waited 1.5 hours for them to pull it and it turned out it was an ASR unit.If you could find a nice one under $200 delivered that would be great. I'd pay a bit more for a lower-mile, rust-free diff but that's hard to find. I think Kegman got one for ~$150 locally
No, not stretched... that's installing purposely too-narrow tires for the wheels. Some brands of tires have a rounder profile (i.e., Conti) while some others have a more square profile. The round profile can help where clearance is tight. There was a thread discussing this a few years ago with 10" rear wheels on a 500E, one brand of tire would clear, another would not, both the identical size.Round profile tire shoulder doesn't mean stretching does it? I don't like to do that if I can avoid it.
Be careful when people tell you what 'fits'. You can bolt on 9" fronts and 10" rears and roll the car forward & back in your driveway, that "fits"... but it would be undriveable in the real world. Again, if you follow the AMG instructions and don't go wider/larger than what AMG approved, it should be fine.I'm trying to contact the owner of the pictured car to see what all he has done to make the wheels and tires fit but I'll be ordering the Sportline springs and Bilstein sport struts as per your recommendation and after talking to Jonathon at Blue Ridge. He'll also be happy to discuss the sway bars and other suspension mods when I get a chance to drive there this spring.
No need to cut the fenders, just roll (fold upward) the fender lips and maybe twiddle the plastic moulding & bumpers. Just be careful that you don't end up spending so much that you could have bought a 500E to begin with...I don't want to cut the fenders and widen but the more I look at the 500E, the more my brain is telling me I won't be happy until I've spent all my money on this car![]()
Possibly... would need to get the size & part number from the back side to confirm. There were a number of different 15-inch, 8-holers.I also found these, the 15 inchers. Are these what came with the car stock?
Yeah the number of different 8-holers that I found are ridiculous. People on Marketplace don't make it easier because it takes several tries for them to figure out what numbers I'm talking about. Let us see what pictures she sends me this time.Possibly... would need to get the size & part number from the back side to confirm. There were a number of different 15-inch, 8-holers.
This falls under the bucket of "Be careful when people tell you what 'fits'." If you don't corner hard or have luggage/passengers, it may be ok. But when you push the envelope, there could be rubbing. Again, follow the AMG docs and you should be fine.Oh and I finally got in contact with the guy that used to own the pictured car. He said all he did was roll the lip and trim the liner slightly, lowered on H&R springs. Seems very doable if I can find the correct tires to put on. He said he ran Pirelli soft compounds but I'm going to stick with Contis if I can.
Snow tires are a whole 'nuther discussion. Depends if you deal with deep snow, or packed snow, or mostly ice, or mostly clean pavement with ice. I deal with mostly clean pavement and ice, so I use studless snows, like Blizzaks or the Conti/Michelin equivalents. Tire Rack has some good comparison test on snows. Remember you can use stock wheels for your snows, since you're not going to be be strafing apexes on Blizzaks. A heavy foot will shred the soft rubber compound, so go easy on 'em.Not as concerned right now with this because this poop storm will end soon, but if you run winter tires which ones would you recommend?
I don't know. I've never bought them, and nobody on this forum has bought them and posted photos. The 14mm front fitting will require cobbling a washer in place to hold the fitting in the frame bracket. From the photos, it appears the front StopTech hoses have 14mm fittings front & rear.These have incorrect fitting? I've never had trouble with StopTech before but don't know anything about the application on this car besides a few mentions of 14mm fittings instead of 17mm. Or maybe that was another brand.
OhAlright I'm getting a little frustrated with this crank position sensor. Got the bolt out but no matter how much I twist and pull on it I can't get it to come out of the hole. I don't want to snap it off in there because that's a can of worms that I'm not interested in opening. Any suggestions?
I will give that a try because I'm definitely not ready to pull the transmission out. I'll give it the night to soak, try again tomorrow, and then soak more if it doesn't want to budge. Haven't had any trouble starting her back up at any point, yet. But I know with my luck it will have to be done at some point soon. And I've learned not to force things in old cars when I'm tired. Only makes things much much worse.Try to spray some penetrating oil or WD-40 with a red straw in there. Hopefully you can wick it in between the sensor and its hole to soften up whatever is keeping it in there.
Thank you, that helps narrow the search! I don't think it had to do with wanting the emblem more than wanting to damage something someone else has. Won't be happening again.The gunsight mount changed as of 1994 on the 124 chassis, where it inserted into the hood, not the grille. The CLK is late 90's and will be the same type.
You need something that mounts into the grille, not the hood. So look for flat replacements that works for 1980's and early 90's.
I'm surprised people still pilfer these things.
Hmmm he would have had to run from inside the store and back without me noticing. He's spry for his age but not that quick. Unless he's picked up teleporting...Maybe your Dad took it?
He was trying to steal the car just three posts ago?
Since I already have the part I'm praying this is it. Temp never got to 100 but I thought that would be a factor in the sensor suddenly crapping out. There was a hint of a rough idle just before it shut down the first time as well. I need to get a SDS...It's hard to tell for sure... but if the crank sensor is original, and you're guessing at a part to throw at it, that would be worth a try. However, what you describe is not the "typical" CKP failure mode. But it would be tough to pinpoint further without viewing live data, while the problem was occurring...
