Japanese Mods; series resistor and ground cables
Sebastopol
Active member
I was at J-Auto and saw some interesting mods that I thought I would share;
They placed the Series Resistor for the aux fan in the cooling path of the radiator, to move it away from the engine heat was the motive.
They also used significant amounts of grounding cable
Relocating the fan resistor is a great idea. This is similar to the factory location on the 140 chassis. (I'd prefer converting to a factory electric fan with PWM controller, which eliminates the need for the resistor, but that's far more complicated and expensive.)
I've seen the grounding cables on other cars in Japan. I don't quite understand what the benefits are supposed to be.
Note the car in the photos also has a customer aluminium radiator...
:jono:
