They will definetly make the ladies turn their heads..for sureIt appears that you received a few early / prototype "@Stevester500E" tubes. These are really really rare and since they are an NLA part, can be sold for €5.000—
It was said here on the forum that these tubes are a future collector item.
More information is here:
FOR SALE - FS: Original Mold M119 aluminum oiler tubes - future collector item | Parts for Sale
For sale is a set of M119 aluminum oilers tubes, from what I believe were made by the first molds. If you look at the shape of the tube, it is "blockier" than the later aluminum oiler tubes. The part number is the same as the later ones: Part No: 119 187 00 87 The second picture compares the...www.500eboard.co
i am debating buying it.It is a car dealer car..that is in at where i work..to get some stuff sorted out.And its just been imported from Japan.So no number plates on it yet.Is this your ride or a customer?
In non-US markets those were the standard wheels very early on. 8-hole wheels were optional for all versions, including the v12.Interesting wheels on that bad boy! Just the 'standard' 15 hole wheels? Is it an extremely early build or something?
As far as that glitch you described, check the transmission overload protection switch, i had that problem before.Re: Lowman"s 1992 500e Norway
Just had to post this little update
Been working on the car all weekend,as there have been stuff to sort out.
The car has been suffering from some "glitch"...it could while driving, loose all power in the engine" ..for just half of a second..just like if the power was cut..and then turned on again.And when i was about to drive off..as the revs rised...therewould be this glitch..and engine would stall..and all instrument lighting would come on..as is if the ignition key was on position 2..
I did check fault codes before and after...and afterwards..there was "No CAN reception " from LH1..
and from that..i checked the CAN wires..and they are all good..and did just change all fuses in GM module..and REseat all control units.and hopefully it would do the trick..though it had one minor glitch after that point..but fault has not resurfaced after that.
here are some pics of the fault finding
After that i removed the aftermarked shitty alarm from 1996
And decided to clean up the wiring under the steering column...and removed the after marked mounted Automatic daytime runnings lights..and decided to check all the wiring inside the switch connector
here is some pics
and did some interiour cleaning while i was at it .no further explanation needed i guess
And i made my own file book,printed out Service introduction papers,more technical information,wiring diagrams and stuff
View attachment 84561View attachment 84562
hey thereAs far as that glitch you described, check the transmission overload protection switch, i had that problem before.
Just thought i would do a little update.
Last night..i did dive into the diagnosis...did alot of testing...And i started to focus on the ABS/ESP light coming on /fault ,,and not bothering with the "raised 900rev idle"...as i do think that the reason for the raised idle is because of adaptions beeing screwed up because of the faultcode appearing.
I tested some canbus stuff...the canbus controller in both ECU and RCL module is in good order(i did this test because of "guided symptoms in the Mercedes workshop manual i found at Startek.info.
Anywhoooo
I found a poor can wire in the right hand side door sill.It was taped up..and inside it...half the wire threads were broken..So i soldered it..and taped it up.I am going to check the canbus wires on the driver side tomorrow.Im really hoping im finding some faults there aswell.
Fault persisted after fixing the CanBus wire.
I have also noticed that the fault with the abs/esp light only appears after car has got up to driving temp..and when sitting idling for a minute or two...which also explains why the faultcode potenially plays havoc with the idle adaption settings...as you cannot do adaption reset above 60 degrees...."i think".
I also messed about with some actual values in the Abs/esp module...and i noticed one pid ..that said "Circuit 61>>0 volts...."....when car was running....so that lead me on a track..eventhough i do not know if the car has a circuit 61...neither do i know what it is...i cannot find any info about it...but on the w211"s...it has to do with Battery voltage"stuff.
One faultcode that also have appeared is the the Abs/esp module is missing can signal from the ECU.......
So...that got me thinking....i need to verify the powerfeed to the abs/esp module....And i basically messed around alot there,,back and forth...
But in the end...i reminded myself of...oh...i do remember the w210"s especially....are pretty delicate when it comes to voltage..And that lead me further to the fact that i know that the battery has been sitting in the car for A long time...
So i decided to test the battery.......i tested it first when mounted in the car.....its a 100Ah battery...830CCA /EN
Battery test came out : 560CCA available.....battery resting voltage...12.5.....Battery test result "!Battery good....Recharge"..
Okei...today...i just ordered a new battery....and after taking the old one out..i tested the old battery again...and the test result was 542 CCA available...>>12.4 >> Replace Battery-...
SO......putting in a new battery...have given me some hope....done some "random "searches on the interwebs now tonight..and it does seem that the batteries when turning this low in voltage..can indeed play havoc with the electrics in the w210"s.......found several threads with "similar" "faults....though it can be a coinsidence.....but at least...it was a good feeling to put a fresh new battery in the car....basically a good thing to do anyways
OF course this problem is not solved..and i do not think im that lucky with it beeing "just" a poor condition battery.I have also ordered a new K40 Relay..as this is a critical component...I have opened the K40 relay in the car..and i do think i saw some poor soldering points...And for now i do not want to solder it....There is more to the k40 relay that can go bad..than just soldering points..there are resistors in there aswell..so..for now..i am leaving it untouched
I will definetly come back with updates.And a video also at abit later point..i have done alot of video "clips" during this "diagnosis" session.
Im sorry for the messy and lenghty reply...![]()
heyy there misterAre you using Star Diagnostics for this Lowman? Or a generic code reader?
As you likely know using Star will lead into WIS which should provide for a good testing and elimination strategy to trace the fault down. It can tell you in order of prevalence where to start looking for CAN errors etc on a particular module.
It is still available.so i can still get it..but i do not think it is wiseYou should have bought it.
Definetly an awesome car this.Its a Ford Galaxy 500, 1963..pretty much mint condition outside and inside..but like many of these american cars..they do look good on the outside..but underside..they are always leaky from the engines etc etc....and this one is no exeption.I adjusted the ignition on this one today..and now it runs preeeettty smoooth.And gained some horsepower aswell..as the ignition was set (incorrectly that is)to approx 25 degrees BTDC.And the spec is about 8 degrees..so you can imagine it was running poorlyAmerican muscle, classic![]()
Thaaaat is sooo cool to hearWow the First NEW car my Dad bought was a 65 Gal in the same color. He got rear ended turning into the driveway and it went to the scrap heap. I never saw it as I wasnt born until the following year but I saw the pictures! Thanks for the memory.
hahaha yeah i noticed that myself..Throttling DeviceHoly moly! LOOOVE the new parts and boxes. 'Throttling Device' hehe. I'll have to start calling it that.
Just curious, do you not have an ETA re-builder in No.? Or is this just your little 'spoiled child' that gets whatever it wants?![]()
Well
I just had to post this
You all know im a huge ford cosworth fan also..and ive been a consistent reader of two ford mags during my time with these cars....performance ford..and Fast Ford...which is the two biggest Ford magazine's in the Uk
So long story short.....my lovely 1987 model..Ford Sierra Rs Cosworth has got a feature in the october issueits also on the front cover...but the coolest of all is that it is the centrefold car ..poster car if you may
So as a car guy..and a cosworth guy..i am super proud to have my car featured..and my story told..and it is also a great way to honor my dad..who would have loved seeing this car on print in one of the biggest Ford magazine's out there.
View attachment 114473View attachment 114474View attachment 114475View attachment 114476View attachment 114477View attachment 114478View attachment 114479View attachment 114480
Yeah i knowYou know that when that odometer turns 100000, that 20% of the value of the car will go "poof!!" ... right?![]()
thank you sooo much mister,Well..the E50 is not approved to use the hook...so it is in many ways a huge mystery to why it is mounted on the car...and even written into the datacard.It is dated 1999...so it has to be someguy with " a saying" that has had this done to the car.I am debating to remove it..and sell it..as i will never tow anything with this car.But its quite cool to have though.Cool E50 with a Hook ,I like thisand middle muffler delete. How is the Sound.I think more Agressive but not deep or??
Hello Guest !
