Christian_K said:Awesome car! Love your Videos, eve the "older" ones at night in Holland are great!
It would be nice if you do something, so far no-one has done with a E60 at all - 0-250km/h onboard-video with almost empty fuel-tank on a german highway.
Or at least a 0-100km/h video if possible... I really would love to see this, no-one so far saw something like it.
Also, did you added the AMG camshafts? If not it was probably a good choice. As far as i remember Bernard Marijanovic (mb-evolution, head of germn W124-Forums), replaced the AMG-Camshafts on a customers E60AMG as he was rebuilding it and he boosted power to ~430 (DIN) HP and ~635NM(DIN) or 468lb/ft of Torque!
That should be tremendous compared to the stock 500E. And this was a car without even something changed on the exhaust-side. Imagine yours with your sport-metallic-catalyzers and 2-way till the End... That could be even a bit stronger.
No he never shared any information regarding what exactly he has done to that E60 AMG, even though people were asking. I think it was "our" assumption based on the pictures that lead to the conclusion that the camshafts had been replaced, as you could clearly see in the pictures as he was done with overhauling the E60, that there were brand-new totally clean camshafts in place.Hi Christian,
Any more info on the camshafts Bernard used? manufacturer? or does he make them? will it work with other displacements (5.0 or 6.4)?
I think with headers,sport Kat, x-pipe instead of resonator and new back box it should make about 450-460 based on the numbers Bernard claims...Now Just to find a company willing to do the headers.
I had a look at the kleemann SS headers for the C63 M156 block, its not a true header design but has large power gains and is small size.
I hate it when people are secretive about stupid things. Why can't he just tell us what the hell he did?Christian_K said:No he never shared any information regarding what exactly he has done to that E60 AMG, even though people were asking.
I believe if you look at all the photos, you'll see the original cams were severely worn and that's why they were replaced. However I think they were replaced with new AMG E60 cams, not anything custom/special.Christian_K said:I think it was "our" assumption based on the pictures that lead to the conclusion that the camshafts had been replaced, as you could clearly see in the pictures as he was done with overhauling the E60, that there were brand-new totally clean camshafts in place.
Might just be something along the lines of additional porting on the heads... hard to say though, there's nothing obvious in any of the photos. I archived all the pics on my website here btw - it's a lot to look at. I'd love to get an engine stand like that, but can't find any information on the manufacturer or model number. The original thread is at this link, but the photos seem to be missing...Christian_K said:And he also commented the post with a statement something like (free translated out of remembering): "A special ingredient/upgrade has been added to the engine and the car is now producing 43*HP and 63*NM".
he said the following:Free Translated:"Im Grunde genommen ist eigentlich nur noch der Rumpfmotor original AMG geblieben. Der Rest wie die 4 sehr scharfen Nockenwellen, mitsamt den passenden Ventilfedern, verstellbaren Nockenwellenrädern, anderes Steuergerät, 2 flutige Auspuffanlage, leichtere Hydros, Ansaugtrakt und weiter bearbeitete Ventilsitzringe stammen nicht mehr von AMG."
"Basically only the "Base-Engine" remained original AMG. The Rest like the 4 very sharp camshafts with fitting valve-springs, adjustable camshaft gear-wheels, different ECU, 2-way Exhaust, lighter hydraulic lifters, Air intake and further reworked valve seats, are not AMG anymore"
gsxr said:[
I hate it when people are secretive about stupid things. Why can't he just tell us what the hell he did?![]()
The answer is one post above yours ;-)195910 said:I am willing to buy a set from him if he can show us what he did, and the power gains (before&after dyno).
OK - fantastic info - and I hereby retract my previous rant.Christian_K said:Ok i did find his answer in the W140 Topic regarding the changes... how could i ever missed that...he said the following:
Christian_K said:The answer is one post above yours ;-)
Stock Power was probably around 400HP, as the E60s are known to have more power than the claimed 381HP.
Prad is power at the wheelsChristian, can you translate the dyno information from the photo below? I.e., what do these mean?
Prad
Pverl
Pnenn
gsxr said:The EPC indicates that the new, lighter lifter supercedes the older, heavier lifter... so it should be ok to install the new ones on an early/1992 engine with double springs.
Any news from Bernard on the special camshafts yet? Strange that the "custom" valve springs were still 2-piece instead of the newer 1-piece design, no?
Eng:hier noch Bild der gebrochenen äußeren Ventilfeder, die nach dem Ausbau der Ventile aus dem Kopf zu Tage kam. Zum Glück sind die Ventilfedern in doppelter Ausführung, sonst hätte das Ventil längst auf dem Kolbenboden aufgeschlagen
here is a picture of the broken outer valve-sping, which got visible after removing the valves. Luckyly the valve-springs are double by design, otherwise the valve would already have touched the piston-bottom.
Dave,gsxr said:I haven't done it before, but it's on my lengthy "to do" project list. Be careful which lock switch you buy... the correct one is p/n 202-820-40-10, which has a red LED indicator which I believe can still be used in place of the original alarm LED, while adding the lock/unlock function separately.
we were talking about two solutions here. I'm looking for the regular switch without LED, same as in my Limited. I can easily through the gear console panel and check the PNs.
Yes I agree, Christian.Christian_K said:But lets do that in a new topic please, otherwise this will get a bit to confusing, finding all those awesome tips/advices in the various showoff-forum topics... ^^![]()
