The 8-piston setup will not work without a lot of custom modification, and IIRC, also custom rotors ($$$$). Generally, a bad idea. Not to mention those rotors are some of the heaviest boat anchors MB ever produced. (!!) I've seen some 6-piston setups installed with OE 2-pc rotors but the mods are much more than I'm willing to do. I don't recommend any of those brakes for a 124/129 and I can't help with technical info, sorry. If you want/need bigger than Silver Arrow, buy StopTech or MovIt. The Silver Arrow setup is plenty adequate for any E500E up through about 450-500hp... the only time you'd
need larger brakes is if you had more power than that, and I can count on one hand the number of 036's with over 450hp.
The Silver Arrow kit has been proven to work well with the stock master cylinder. I can't say the same for the 6- or 8-piston setups, except to pass along the feedback from the previous owner(s) of my '92 which had the 8-piston fronts installed with 4-piston rears... they reported the pedal feel was poor (excessive travel, I think). The PO of my car removed that funky setup and installed Silver Arrows, which worked GREAT.
If you have an unlimited budget and can experiment with custom AMG brakes that have not yet been proven on the 124, great, go for it... just don't be surprised if you end up having to re-do work and change calipers/rotors/MC's because you're not happy with the results. Then again, if you have an unlimited budget, just buy StopTech or MovIt kits which are properly engineered for our cars and don't require funky mods. If you
are on a budget, I'd stick with what has been proven by dozens of people (not two or three) worldwide to work well. Not to mention they are a bargain.
Used Silver Arrow, all four with new rotors/pads, est $1200 total
StopTech, fronts only, est $2500 plus larger OE rears
MovIt, fronts or all four, starts at ~$3000 and goes up to ~$10k, I think, depending on how crazy you want to get
