Data in bold are measurements I took personally, and I'm confident the numbers are accurate within ±0.05mm. Other data is unconfirmed. Base circles are always between 37.00-37.10mm. I never had .960 cams to measure. Based on what you stated above, I'm wondering if Jono sent me data from other cams (not .960 cams). He had told me 15 years ago that he measured the .960 cams, and they were identical to E420 cams he also measured, which seems weird.
If you can double-check / verify any of the data below, that would be great.
The AMG 6.0L camshafts are different between LH (#18-21) and ME (#26-31). The code numbers are stamped on the flange of the cams. I suspect the lift is slightly different between the LH and ME cams. No idea about duration.
Note there is quite a spread on the measurements of 6.0L exhaust cams (9.4 to 9.8mm). It's surprisingly difficult to get precise measurements (better than 0.05mm accuracy), which is why I think the numbers vary so much from different people measuring. I took a LOT of repeated measurements to get my 4.2/5.0 data in bold above. I also had to measure multiple different lobes, as there was some variation between lobes.
M119.971/.975:
4.2L 1992 intake = ?
4.2L 1992 exhaust = ?
4.2L 1993+ intake = 8.45mm
4.2L 1993+ exhaust = 7.40mm
M119.960
5.0L 1992 intake = 8.60mm (data from Jono)
5.0L 1992 exhaust = 7.60mm (data from Jono)
M119.970/.972/.974:
5.0L 1992 intake = 9.50mm
5.0L 1992 exhaust = 8.75mm
5.0L 1993+ intake = 8.90mm
5.0L 1993+ exhaust = 8.40mm
5.0L E50 AMG intake = 10.40mm (data from @Taxi Driver)
5.0L E50 AMG exhaust = 9.40mm (data from @Taxi Driver)
6.0L E60 AMG intake = 10.10mm (data from @Rouven036 in this post, LH engine, cam code numbers possibly #18-#21)
6.0L E60 AMG exhaust = 9.80mm (data from @Rouven036 in this post, LH engine, cam code numbers possibly #18-#21)
6.0L E60 AMG intake = 10.2mm (Benzworld post, LH cams)
6.0L E60 AMG exhaust = 9.70mm (Benzworld post, LH cams)
M119.98x AMG 6.0L:
6.0L E60 AMG intake = 10.15mm (data from Jono, I think these were camshaft codes #26-#31 for ME)
6.0L E60 AMG exhaust = 9.40mm (data from Jono, I think these were camshaft codes #26-#31 for ME)
6.0L E60 AMG intake = 10.1mm (Benzworld post, ME cams)
6.0L E60 AMG exhaust = 9.60mm (Benzworld post, ME cams)
