Thanks for the helpful information. I have the 2-3 second wait on reverse and clicking, when I first start the car. I will look into changing the fluid and filter as next maintenance project.
It could be that the B2 is on its way out.Thanks for the helpful information. I have the 2-3 second wait on reverse and clicking, when I first start the car. I will look into changing the fluid and filter as next maintenance project.
I had to remove the crossover pipe and this was no problem -- not nearly the problem (with the upper bolts) that I thought it was going to be. Interestingly, my bottom bolts' nuts were different. One was a copper 12mm nut, and the other was a (rusty) seemingly non-copper 13mm nut. I'm going to re-order new nuts and bolts for both the top and bottom and replace them next time when I add the RedLine ATF juice.
Yes. And also, in some instances, the trans pan can not be removed as it becomes "pinched" between the pipe & valve body when you try to lower it.Gerry - why did you have to remove the crossover pipe??? Access to the torque converter??? Thx.
It's usually not that bad to remove. When re-installing, apply anti-seize to the threads of the 2 manifold bolts. If the two shorter bolts that clamp the crossover to the main pipe are rusted or damaged, you may want to replace those... any hardware store with a good metric fastener assortment will have the proper size.Looks like I am in for some fun this weekend. The cross-pipe...
My car has been modified for first gear start, but I honestly don't know what method the PO installed. I've noticed that when cold the transmission is reluctant to upshift from 1st to 2nd. There is no reluctance going from 2nd to 3rd or 3rd to 4th regardless of temperature. There are also no issues with down shifting and no delay when shifting to reverse. After the car warms up the transmission shifts perfectly from 1st to 2nd. Any suggestions? I am planning to do the transmission fluid/filter change or at least have my Indie do it because transmission fluid and I don't seem to agree on where it should ultimately end up.
For the past couple of years, my transmission has had the dreaded B3 "reverse" clutch issue, whereby I have had the clicking in reverse (particularly when the transmission is cold) and delayed shift into reverse (2-3 seconds). All forward speeds have been fine, and other than a little funkiness/flaring at the very top of the rev range -- particularly when pushing the car hard through the gears -- it has operated extremely well for regular driving. I have avoided the reverse issue primarily by backing my car into the garage (as I do with all my cars) to minimize wear and tear with a cold transmission in reverse.
The car has 117,000 miles on it, FYI.
Today I came home from work and parked the car (20-mile drive home) in my driveway for about 2.5 hours. Everything was just fine with the car and transmission. A little while ago I went to the post office (about 2 miles away, back roads) and noticed that the car all of the sudden was VERY reluctant to upshift from 2nd to 3rd gear, and once in 3rd it would be all I could do to get it to shift up into 4th. The car was holding both 2nd and 3rd gears into the 5,000-6,000 RPM range, and even then, I would have to play around with the throttle pedal a bit (back off slightly, etc.) to get it to upshift. I also noticed that downshifts (for example from 3rd to 2nd, when crossing a parking lot and slowing down to the ramp to pull out from the parking lot onto the street) were bouncy and sort of abrupt. Kind of a quick clunk. Most of the time on main roads I could not get the transmission to upshift into fourth at all -- I would cruise around in 3rd gear, 45-50 MPH at around 4,000-5,000 RPM, no upshift.
My FGS system was in normal shift mode and later on I turned it off completely, so it should have had no effect on any thing.
When I got home from the post office I checked the transmission fluid with the car running - engine was HOT from ~5 miles of driving plus the earlier drive home (outside temp in the low 70s, so not much cooldown in between drives).
Fluid was right where it was supposed to be from what I could tell -- at the upper mark of the high-temp arrow range (the higher of the marks on the dipstick) and seemed to be clear, and smelled OK. I checked it 3-4 times and every time seemed to be at the same place.
The fluid has not been changed at least in the past 6 years, so that would put it at around 90K service, or before? So I am sure it's due, with 27K of regular non-synthetic ATF in it.
My question of the experts is:
Should I replace the fluid/drain the torque converter, and replace the filter, and see if that cures the problem? Use RedLine D4 fluid and a Mann filter? If that doesn't solve anything, what are my next steps? A rebuild? It's probably at that point anyway for the B3 situation, but I was planning to do that job (and reseal the exterior and pump) myself.
Anyone had this problem of "extremely reluctant" upshifts before? What did you do about it?
+1. Sounds like something going on with the shift linkage. Have you checked the nylon bushings at each end of the shift rod under the car? The shift lever should have zero play, if there's any at all, one of those bushings might be shot. Think there's a GVZ-esque DIY article around here somewhere. *rummages around on messy desk looking for it*In my book, whenever something is done to a car, and a related problem crops up immediately after that, then it's a cause and effect thing. I think somehow your shift knob/linkage work affected the mechanical transmission control. It's just too coincidental not to have some cause and effect.
They used to rebuild transmissions in their shop .. Hong, their Vietnamese mechanic, did all of their transmissions. But he stopped doing that some years ago - I guess it was just too time and labor intensive to be a money maker for them. So, they farm them out.I did not get that feel from MBI.
Did you check both? There are two, one at each end of the rod.I'm not seeing any visible wear on the bushing.
That's the valve body, you'd see that if you dropped the transmisison pan.Can someone tell me what this diagram represents and where on the car I would find this?
What happens if you try to move the shift lever forward slightly towards Neutral? Will the trans upshift to 4th, or does it just go from 3rd to neutral?
Hmmm. Does the transmission go into neutral (engine revs change), and then it goes into 4th gear after you move the lever back to D?
He's out this week, I think with sporadic access to email and Internet. So, responses may be delayed from the GSXRman....Where did gsxr go? I was hoping my latest post might provide a diagnosis.
I'm out of ideas at this point... it's a pretty unusual failure mode. I'd try poking around the other major MB forums (PeachParts, MBWorld, BenzWorld) and see if you can find anyone else with the same symptoms. I vaguely recall something about a small mesh screen inside the valvebody that can cause lack of upshift if it gets clogged with debris, however I didn't think it was the 3-4 upshift...?Yes, exactly. But I have to move it up to neutral, not just move it in that direction.
Sounds vaguely sexual.....I noticed yesterday while dry shifting that it feels like its clicking into gear
but ... that bad back of yours .... though in the NW, especially this time of year, one does spend a lot of time indoors, so always plenty of time for that sort of recreation .... or going to the neighborhood brewpub to toss back a few pints of IPA...Never too old or sore for that.![]()
Some damned good pinots out of Yamhill County, too. (don't tell the Californians, though...)There is a lot of good beer up here in the Pacific Moist West.
Ah-HA! Yes, if the clicks in each position are not lining up exactly in the plastic shift gate, something ain't right.I am convinced it is the linkage. I'll probably take it to Burback for an adjustment. I noticed yesterday while dry shifting that it feels like its clicking into gear about a quarter inch before the D notch.
I hear you on that. Dunno about y'all, but I'm not gettin' any younger, dagnabbit. If you do some of your own work, and have the means, I'd highly recommend installing a lift. Even if you don't have a shop or high-ceiling garage, there are low-rise lifts available that fit in the common 8-9' ceiling garages. The high-lift version that you can walk under is even more spine-friendly. After I got mine in 2007, I spent a lot of time kicking myself for not getting the darn thing years sooner!I screwed up my back yesterday lifting the back end of my riding mower or I'd drag the race ramps back out. It sucks to be old. :|
