Firstly, I will apologise if this subject has been covered in depth previously, my searching has not yielded any straight answer. I am undertaking a M156 and 6 speed manual swap in my 1988 300E. With the aid of the W124 Performance knowledgebase, particularly the differential information sheet I decided early on I would upgrade my 185mm differential to a 210mm unit for obvious reasons, and most likely I will fit a Wavetrac centre like I have in my W126.
I managed to secure a 210mm differential from a 1994 E280 it has the rear cover 1243513408 and I believe it to be 2.65:1 ratio. Now my question is will the 210mm bolt into my 185mm subframe and connect to the half-shafts? I am not concerned about the tail-shaft as I will use a custom one in any case to adapt to the manual gearbox. Is there any difference between the driveline componentry between the 185 and 210 such as the half shaft strength, hubs etc.?
I also have available to me a 300CE24V which I can remove the entire subframe and differential from and bolt into my 300E if needed. But it will require a complete rebuild due to condition whereas the subframe and half shafts in my 300E are already in really good condition and will only need minimum maintenance for the swap. I completely re-built the anti-squat rear in my W126 a few years ago and to be honest I am still a bit scarred from that experience and want to avoid it!
