Another entry for me – a proper carpet / upholstery cleaning machine. Been meaning to get one of these for years. The arrival of another cream interior w140 meant the time was now! First test on the neglected S500 Coupe trunk carpet. Very easy to clean up took only about 10 minutes total – the waste water was black afterwards
View attachment 83511 View attachment 83512 View attachment 83513
Super-important machine to have for that all-important "ace10" flipper-dealer 'showroom fresh, only-driven-by-old-lady' look.Awesome result!(Carpet)
For those interested, Harbor Freight has the Braun slimbar LED lights on sale for $22.99
https://www.harborfreight.com/390-Lumen-Magnetic-Slim-Bar-Folding-LED-Work-Light-63958.html?ccdenc=eyJjb2RlIjoiODE5MzYzMjEiLCJza3UiOiI2Mzk1OCIsImlzIjoiMjIuOTkiLCJwcm9kdWN0X2lk IjoiMTIzNDQifQ==
Metric Ratcheting Combination Open Ended Spanner Set(s)
Wrenches for a proper P-I-M-P!
Zuhälterschlüssel or X-Steel 25pc Cr-V Ratcheting Combination Wrench Open Spanner Set (6-32mm)
AvE did a tear down video of the M12 Ratchet.
As with all of his videos... there is a far dosing of foul language.
Spoiler alert.
Despite being a frequent critic of Milwaukee, he has a favorable opinion on this tool.
I recently bought the 3/8" version. It's a little bulky but works very well.
What's the speed (rotation RPM) on it like? Can you spin stuff off quickly?
I ask because I've been looking for a air or electric 3/8 ratchet for disassembly. Most of the air operated ones don't turn that fast.
They will spin faster than a hand ratchet but not any faster than the air wrench. I'd rather have one of these over the air wrench because the hose gets in the way. If you're looking for speed, get an impact driver and use this for hard to reach spaces.
Thank you for the spoiler. I prefer the 2-second summary vs a 20-minute video...AvE did a tear down video of the M12 Ratchet.
Spoiler alert. Despite being a frequent critic of Milwaukee, he has a favorable opinion on this tool.
Where do you find that one?
WIHA (made in Germany) 13mm insulated ratcheting wrench for disconnecting the nuts on battery terminals. They also make an offset non-ratcheting version.
View attachment 87572View attachment 87573
This is nice! But perhaps overkill. Connect negative last and disconnect it first. This way there is no problem if a wrench should make contact with the car body.
Most all newer benz models (2000 onwards) also come with 10mm bolts on the battery terminals in which case a ratchet works best
I had totally forgotten my Krikit until I had my recent 1982 300D. I replaced belts on it and while gingerly turning the tensioner with the star on the alternator bracket it occurred to me that I had it. Still in the top drawer of my roll around cabinet in the white cardboard box it came in when I bought it at my neighborhood NAPA store when I was in trade school.
Certainly a majikal tool of mysterious means.
Nice, Jono! Also found a lower-cost similar setup, dunno about the kwality though. Main complaint in the reviews is that the heads get floppy:
Amazon.com: Neiko 03114A Flex-Head Double Box End Ratcheting Wrenches, Chrome Vanadium Steel | Extra Long Design | 5-Piece Set | Metric 8mm - 19mm 3-Pack: Home Improvement
- Wrenches are constructed from a high strength chrome vanadium steel with corrosion-resistant mirror chrome finish for durability
- Unique extra long design provides more torque than other similar wrenches in the market
- Classic 12 point, 72 teeth ratchet gear needs a minimum of 5 degree swing arc that is perfect for restricted, hard to reach work spaces
- 180 degree rotating flexible heads allow you to apply leverage at any desired angle and get around obstructions
- Set includes 5 laser etched wrenches packaged in a high density foam tray: 8x10mm, 12x14mm, 13x15mm, 16x18mm, 17x19mm
I recently bought a Milwaukee M18 mid-torque impact wrench to compliment my air-impacts. Being cordless, it's so convenient to use and powerful enough for most jobs on a car. Haven't tried it on a crank bolt though.
M18 FUEL™ 1/2" Mid-Torque Impact Wrench with Friction Ring (Tool Only)
BTW, Home Depot currently has a great deal on a kit with a 2.0 AH battery and charger; $200 plus tax, free shipping:
Milwaukee M18 FUEL 18-Volt Lithium-Ion Mid Torque Brushless Cordless 1/2 in. Impact Wrench W/Friction Ring Kit W/(1) 2.0Ah Battery-2861-21CT - The Home Depot
Normally, the tool only price is $189.
ADMIN EDIT 1: The sale mentioned above, for the $200 Milwaukee FUEL kit at Home Depot, ended sometime in summer 2018.
				You're approaching it all wrong.It seems this tool is back at $200 plus tax, including the 2.0AH battery and charger..... trying to think of a reason to get it ...
Having used this for over a year now, I'd recommend it as a general-purpose cordless impact... GREAT for tire swaps and general mechanical work. With the small 2.0 battery it is light weight and has enough capacity to swap multiple wheel sets between charges. I end up charging it every few months. Great deal at $200, IMO.It seems this tool is back at $200 plus tax, including the 2.0AH battery and charger..... trying to think of a reason to get it ...
Delivering 450 ft. lbs. Fastening torque and 600 ft. lbs. Nut-Busting torque, the M18 FUEL Mid-Torque Impact Wrench is more powerful while also being up to 2 in. shorter and up to 1.5 lbs. lighter thanwww.homedepot.com
However, it lacks the power to remove really tight stuff. IMO, the 600 lb-ft rating is... optimistic.
				The problem with the hi-torque model is that it's larger and heavier, and you only need the extra power in rare cases. For 98% of the work you're likely to be doing, the mid-torque is perfect, and the lower weight means less fatigue when handling. And the smaller profile fits in tighter spaces, i.e. for flex disc bolts.Thanks for the blunt opinion. I'm going to pass on this tool. I used to have big noisy 26 gallon compressor and a bunch of Ingersoll Rand air tools / impact wrench, but when I moved cross country to a place where land is literally like 10x more expensive, I had to downsize and give up all the air tools. I've only missed those air tools once or twice in the past 20 years.... I'll continue to wait until the hi-torque models go on sale.
Dammit, Jlaa!! I didn't need to see that!Of course right after I post, I noticed the 1000 lb-ft model is now on sale for $250, including 5Ah battery but no charger.
I have both types. The first is to remove broken bolts, the second is to remove fasteners with the hex heads rounded off.Say, do you guys use bolt-extractors that go OVER the bolt as well? Wondering how useful something like this is.....
The hook and pick set, using it over and over and over again, from seals in the transmission to oil filter seals to starting holes prior to drilling and scratching/removing crud from tight spaces and channels
D
Be careful what you wish for .....I am looking forward now to my next seized/stripped fastener! Bring it!
I had to do this not too long ago with an aluminum block drain bolt for an inline-six M104 engine. It was not pretty, and of all the automotive jobs I've ever done, it was probably the one where I came closest to having to actually call in a professional to help. Fortunately with persistence I was able to complete the job.
When you do the block drains (the M119 has two of them) please use extreme care with the block drain plugs. On my M104 in my G-wagen, I had an extreme challenge late last year to remove the aluminum block drain plug, and literally had to drill it out of the block. It took me around 11 or 12 hours to extract the plug because a previous "mechanic" had 95% rounded off the plug so that I couldn't get an adequate "bite" on it. See photo below of a new M104 plug next to the one I extractedObviously this is an M104 not an M119, but the care taken should be the same (plus you have TWO plugs on an M119).
Links below. Very tempting...The Milwaukee Fuel 1400 ft lb ugga dugga gun is already popping up in pre-pre-pre Black Friday deals. Looks like the going price is $269 for a kit with charger and one 5.0 ah battery. Look for model # 2767-21. Regular interwebs pricing has been in the $375 range.
				 mueller-kueps.com
					mueller-kueps.com
