Where to find rear struts for 94 500E?
Part numbers and R&R info here:
Available new from Naperville, $400 each, free s hipping with code 500EPROMO at checkout:
I was able to put the hydro legs into my shopping cart. :)
But, on the same site (MBOEMparts as I was directed to) I could not locate either the copper o-rings (N007 0003 012 102) or LCA nuts (N901 113 010 003). Per the site, the upper strut bushing (201 326 18 68) is NLA. Lastly, the lower strut bushing ( 124 326 03 68) raised a warning that this was not for this car (for which I provided the VIN prior to parts search.)
Any suggestions as to (in presumed order of importance):
- source for o-rings (N007 0003 012 102)?
- source for LCA nuts (N901 113 010 003)?
- alternative for NLA upper strut bushings (201 326 18 68)?
- the validity of the "not for your car" warning on the lower strut bushings?
As always, a warm "thank you" for all of your advice and assistance,
Charlie
Remove spaces from part numbers, and remove the letter "N". For "N007603 012102", search for: 007603012102
I would buy the complete mounting kit p/n 124-320-03-56, instead of only the rubber bushings mentioned in that thread. Besides, one of the bushings may be NLA. The kit is callout #41, the bushings are callouts 23 and 29. With the kit you get all new bolts/nuts/etc in addition to the rubber parts. TWO kits required.
Ignore the website's claim of not fitting your car. The website interchange info is not accurate.
Thank you again! As it seems I'm no longer repairing my car as much as I am restoring it, it's probably time to order and learn the online parts and service systems.
I highly recommend getting an EPC, or using the online EPC (aka Xentry Parts / ISPPI, or something like that).
Check out the "sticky" threads at the top of the list here:
Also, read this about NLA parts:
Cheaper, by almost $50/pair, to get from MB of Laredo, even with shipping!
