Hi, was there a WOT enrichment on the E420 or not? We have this discussion around german Forums for years now and yesterday it started all over again. People claim it was only available in US since the 400E was introduced earlier into the US.... Howerver:
Fact is in the WIS there is not a single word about it. Another fact is that in Germany early 1992 400E Models were rated at 286HP(DIN) while later ones (near end of 1992) got only 279HP(DIN) even though the compression has been raised from 10:1 to 11:1. Whats up with that? Does this makes any sense?
Where to find any "true" data about that? Since years no-one seems to able to answer this issue a 100% correct.
Also what is the powergain when installing a WOT-enriching LH-Module in a 11:1 compression car? I've read that Eric and/or Dave have tested this on a racetrack an have had noticeable results.
I also have found this statement by Dave in the Benzworld.org Forums:
And can someone post the part-Numbers for the Modules with WOT-enrichment if there was any at all.
Best Regards, Christian
Can i see this diagramm too?"I have one in my '95 E420 and it works great. Picked up a full 2 tenths and 2mph at the dragstrip with no other changes compared to the stock module. On the dyno it translated to approx 290hp at the crank, compared to 275hp stock. I can email you the dyno graph if you're interested.
