Monoblocks
Maybe Monoblocks are kinda " standard" looking...or regular....but damn they look good when in good condition and with the polished lip!
Monoblocks
IIRC, the cost was near obscene levels (>$4k/set?). Although I would absolutely love a set, most likely I couldn't afford 'em. I believe these are very lightweight as well, near Monolite levels?
Wow those are even pretty rare in 18" version for the W211. I'm pretty sure they only came on 63's with the P30 performance package. With a 221 part number I am assuming those 19's were also rare option for S65's and maybe 63's??? Baller...
[emoji106]
Sent from my XT1254 using Tapatalk
AMG Monoblock II 18x9 F&R
Jeff
jeff is this the picture you were looking for with 9" all around.
how did you like the look and feel?
Karl,
I have always liked these wheels and have seen them on one other 500E. They were actually made for W140's correct??? Assuming that is the case are you running spacers on them and if so do you mind letting me know what size they are? Same story with the tire size you ran with them as they look perfect. Just in case I ever need to know... ;-)
Non-standard wheels. Some previous owner put those chrome things on whatever they are. I finally switched out to the Evos this year. Even my wife likes them better.
Green, for lack of a better word, is good!
Smart move! Those appear to be late W140 or early W220 wheels... if so, they were probably only 7.5" wide... not meant for M12 lug bolts either.Non-standard wheels. Some previous owner put those chrome things on whatever they are.
Here we go
CLS55 19x9.5 F&R
Jeff
I love those wheels on a 500E. What year CLS did these come on?
They are Brabus, appear to MB-III, 3-piece...?What wheels are those and what sizes?
Those look best with a 260E badge on the trunk as well.Not the best picture, but you get the idea.
Definitely not ballin' on a budget with those wheels !!!AMG Type III / Styling III, 17x8.5 ET30 all around, 245-45-17.
I believe those were offered as part of the Sport package on the very late R129 (circa 1999-2002). If so, they should be 8.5 ET25 front, 9.5 ET28 rear, basically perfect for the E500E. If you remove the wheels there will be size/offset and part numbers stamped on the back side. Pretty sure you'll find they are 129-401-17-02 and 129-401-18-02. These are relatively hard to locate, which is a good thing or I'd probably have a set stuffed in a corner of my shop somewhere...Can someone tell me more about my rims? I know that they are AMGs and they are 18". I believe they might be different widths as the front tires are 245 and the rears are 275. Was wondering when they were made and what car(s) they would have came on? Thanks
These tend towards the flashy end of the spectrum .....
Now the super-slammed and stanced look is not my cup of tea. However, I found these wheels on the intrawebz on a not-500E-specific-w124-site some time ago and I must admit I am very intrigued by this 3-pc take on the regular MB 8-hole wheel.
I may have read somewhere that these are rotiform wheels, but a search of their website yields no matches --- http://www.rotiform.com
Does anyone know more about these?
Thanks for the answers. That helps me a lot...I'll confirm when I pull them off to check numbers and see if there are spacers. I agree on the fit for a E500E...they fit really nice in the wheelwell....drive nice and give lots of tire area on the pavement.
As mentioned in other posts these are R129 wheels if spacers are not used. Fronts are 8.5x18 et25 and rears are 9.5x18 et23. I know because I have them myself.
I'm running 10mm hub centric spacers in front to fill the wheel wells better.
