Hello to all the team. I was not much talkative since my registration, but spent time reading threads about that fantastic car. I own a [1992] 500E since 2003 (purchased for the birth of my son), and we have had wonderful travels with it.
The last trip was to Venise (Italy) with the family, that was in 2013, great memories. Since, the car sat in the garage: main reason is that we enjoy several cars (MB of course), and I was too much involved in my job and our home restoration project. End of 2016, I decided to start a restoration project on the 500E, from the trunk to the engine. Car remains very reliable and in good shape.
All was going fine until I reached the engine bay. A lot of stuff to work on, interesting to understand that engine, until I discovered and unplugged camshaft magnet. Why? Mmm, basically because the magnet was broken. So, purchased a new magnet, about to install it, ... but then came the first bad new of the restoration: high engine wiring harness totally cracked all the way. Ouaouh! I knew that was a weak part of the car, but discovering that wires was a great disappointment.
So, back to the dealer, purchase a harness, installed it, crossed fingers, and started the engine few weeks later: started, cranked, fired, and... ran from first try. Very impressed (although totally convinced these cars belong to the most reliable cars ever). Anyway, a strange noise coming from the front, right hand side (when driving the car, looking at the road) bothered me. Further tests later, and the issue did not fix by itself, so once again I decided to dig deeper. Yesterday I removed the serpentine belt (needs to be replaced also) and moved manually all the pulleys from all the accessories. No surprise at all when I turned the compressor's one (looking at the engine, hood opened, the one on the far left hand side, above the alternator's pulley): untight from its axle, and making pan noise, metal debris falling as dust, not a good signal at all.
So, the compressor's bearings are dead, the pulley is now blocked, and most of all: that part remains a mystery for most of us. Has anyone faced that issue? I insist that it is not the AC compressor (which is located at the right hand side when looking at the engine), but the air compressor. I wonder how one can remove it from the engine? I am pretty sure that once split out, I should be able to replace the bearings, or to install a new one.
So, that was a rather long story about our dream car. Hope I did not bother you too much.
Jean-Louis
Jean-Louis
