Low cost, High quality LED lighting.
Yes, the units are made in China. Yes, I absolutely try to avoid buying China. But there simply isn't anything approaching a cost-effective domestic solution.
4000K, which I prefer for general/utility space. Not too blue, not too yellow.
There's about 300,000 lumens in this garage. Fully dimmable via 0-10v combo dimmer units from Legrande Adorne.
The picture shows the lights at ~50%. I had to use two zones due to load limits on the 15A 110v runs.
Lights are mounted on short 3/4" threaded conduit, rather than the chain mounts which are standard. Ceilings are 12' and then 17' in the high bay.
Sourced from this site.
https://www.ledlightingwholesaleinc.com/LED-High-Bays-LED-Low-Bays-s/150.htm
If you call and speak to a Sales Rep they will very likely offer even better pricing.
Thirteen fixtures were right around $1400 shipped, including the optional drop mount brackets.
I didn't know what to expect with lighting this "cheap." I expected DOA units, inconsistent color, and/or poor dimming.
The entire order was perfect. I plan to grab some spares and also retrofit my other garage to these same product line, albeit the smaller units.
Over the past couple years, I've become a complete lighting junkie/geek. I'm all in on LED. One of the best moves I've done is modifying the fluoro lighting in my machine shed to LED tubes. Instant on. And they work in the cold.
