What product did yo use to clearcoat? Something like this?Just clearcoat the insulator and dist.cap
Thats what i did 3 years ago and i have not had any problems with misfire after that.
Thanks for the video. I understand your porous-insulator-absorbing-oil-vapor-theory (PIAOVT) now.
May I ask two questions?
+ How cold does the garage in which you park get?
+ What weight motor oil do you use?
I have not experienced this problem, but, to be fair, I've only put 3,200 miles on my car as opposed to the 20,000 kilometers that you've accrued on yours. As well, in anticipation of avoiding this problem, I changed the caps/rotors/insulators to new aftermarket Bosch parts exactly 3,200 miles ago when I first took delivery of the car.
I wonder if motor oil weight as any affect on PIAOVT.
For what it is worth, my garage never gets colder than 55F and never gets hotter than 90F. Furthermore, I use 15W-50 weight motor oil year round.
Stephan,
I can’t view the video at the moment but will ASAP! But the pic looks like an emulsion of oil and water caused by the blender action of the spinning rotors. If there is any oil in there I would be changing the shaft seals behind the rotors. That’s the only place that could possibly let oil seep into the area. At those low temps the seals tend to srink. I think new seals would at least eliminate the oil part of the problem.
Take Care
1: Plastic degradation. These parts are 26 odd years old now and subject to very hot temperatures and engine oil vapour / atmospheric moisture. The constant high heat then cold temperature changes will have taken their toll on the plastic discs after so many years & miles.
It may be coincidence, but the few black insulators I've encountered (made by Doduco) were generally in much better condition than the orange (Bosch) insulators. I've also seen some Bosch insulators turn that sickly yellow color as seen in Eno's post above, and I'm pretty sure they were not this color when new.I have had one fail on my 300E-24 on the past and on VERY close inspection I could see fine fissures / carbon tracks where the spark could make it’s way through the cap itself. This was viable because the parts were bright red – on Black ones like Lowmans any carbon tracking; if present will be much harder to identify.
I'm having a hard time with the blowby theory. There should never be enough pressure inside the crankcase to push oil vapor out through the cam seals. However, a slight leak of liquid oil could theoretically get vaporized by the high voltages present in the distributor. Vehicles which show absolutely zero signs of oil leakage (not even light brown residue/varnish below the cam seals) that have fluid back of on the insulator would likely have a different source for the liquid. Another possibility is liquid oil leaking into this area from either the cam advance solenoid (very common leak) or the valve cover gasket.2: Contamination from Engine Blow by. There will always be some degree of engine oil vapour & blow by gasses including fuel present in the distributor area. Usually there is a fine oily film on the back of the insulator discs. This will be having a long term impact on the plastic and could perhaps break it down. Which would be indicative of the fluid sometimes observed running out of the discs.
If the insulators are old / original, it's cheap insurance to replace them (new Bosch insulators are under $50 USD each now), ESPECIALLY if new caps/rotors are being installed. Before installing, clean every trace of oil from the entire area to ensure it's bone dry. It would be interesting to remove the parts for inspection after a few thousand miles and see how they look.IMO the time spent cleaning these and re-installing would be better spent fitting new ones instead because of the reasons above and the age of the parts involved. We see countless times how installing new insulating discs does cure the problem. Cleaning the back of the discs will cure the problem on the short term but as that atmospheric moisture makes it’s way back in behind the discs – which it will – the problem will re-occur with ignition leakage through the failing insulator discs. If ANY fluid is observed coming from the discs themselves they are junk for sure.
I did watch the video. There is a discolored area below the seal, which is odd (screen shot attached). I understand you believe this is from oil vapor, but I still don't believe oil vapor is being pushed past the seal. If there was that much pressure in the crankcase, you'd also get oil vapor passing the front and rear crankshaft radial seals, and probably leaking from the PCV hoses & valve covers, and anything else open to crankcase pressure. As I mentioned above, it would make more sense if it were liquid oil leaking into that area, which is then vaporized by the high voltage. Maybe. I really don't know. We'll see how your Doduco insulators look when you check them again later on.you should watch the video(if you havent) ,dave..as the "leak" on my car is definetly NOT a LEAK...either from cam seal OR cam solenoid...it is 99.99 percent certain that it is vapour![]()
Im Schmutz..may i help youThose insulators are not entirely cleaned up -- I see some schmutz on the edges/lips of the insulators. Very important to clean those sealing surfaces !!!
Main reason for replying is to throw this question into the ring... why are the insulators not O ring sealed on their back side against the head?
Gareth
... Does anyone have any idea if Bremi parts are as good as Bosch?
Thanks guys,
Found Amazon to have good prices here in UK,
Can anyone confirm Bremi part numbers?
Cap 6018R, Arm 7027. £55 for the pair is cheaper than fleabay!
Lowman... Agree with your view, I wonder if there is room between the aluminium and the insulator for some anhydrous absorbent material?
Did your black (Doduco) insuators have liquid on the back side, or were they dry?Hello, are the newer orange insulators any better? I have this black ones from year 1992 never changed. Recently I cleaned them but I stil have misfire when hot on idle. Strange thing is then when I restart engine missfire goes away for a few kilometers or minutes on idle.
Was this the passenger side cap or driver side?My 500E was put away for winter in my carport. Rather than cold startups etc I choose to let the car hibernate and start her up this evening for a first drive of the year.
Fired up right away as always- perfectly smooth. Drove it to a filling station a mile away and half filled tank with fresh super unleaded. Cranked up fine and drove off on up the road.
Next junction around 5 miles later- pop fart dead. Stone dead. Cranking and popping that was all. Pushed her off into a hard shoulder and phoned GF to come get me whilst my brother who happened to be with me stayed with my 500E.
Came back 20 mins layer - pulled the dist caps and they were laced with water condensation inside. (My very first suspicion is that it was dizzy cap related) All leads, plugs, caps and rotors are brand spank new less than 100 miles on them - fitted about a year ago.
Dried out the moisture with a cloth, sprayed WD40 inside the cap and in the rotor area as best I could - problem solved. Drove home as is nothing happened. Some WOT action confirmed I was on all cylinders again with a puff of tyre smoke.
Lesson? If your 500E is stored outside or in less ideal conditions for months on end it would be prudent to check moisture before first trip out. Dont take cold start behaviour as a given - if moisture is in there it will show its face after 10 or 15 mins of driving.
Lesson no 2 - always have a rag, 5mm Allen wrench and a small can of WD40 in your 500E's trunk.
I will monitor this and keep checking caps periodically and apply WD40 each time to displace moisture from in there.
The picture was taken at the side of the road with the moisture I found in RH bank cap. Both were the same level.
Sucks breaking down - especially in a gleaming 500E! I'll not lie - it pissed me off, imagine how good a 500E would be with coil packs....... dont like distributors and my other HFM models never miss a beat. The 500E will have to gain my trust again somewhat
My advise is to switch on the A/C to get the engine to warm up much quicker, this will help dissipate the moisture quicker.
Location of cap described in my post above! (Read post #42 fully PLZ…..)
Makes no difference to this issue how fast the engine warms up IMO……
I have my own theory on this issue. We know that behind the insulating cups is an alloy section of the cylinder head. The coldest surface in this assembly due to the thermal mass of the alloy head material. This area is also not sealed from the distributer cap – due to the hole recess (In the insulating cup) to allow the rotor arm mount to pass through and that the cup is freely floating against the head (No seal) and only seal is an O Ring to the distributer cap. This distributer cap O ring seal is more locating function than seal and this is confirmed by the fact the Distributer caps have vent slots in them at this O Ring seal junction.
Remember that it is very typical in this problem for the car to cold start just fine – then at a certain warm up stage start to stumble / cut out….. Correct? Which was exactly my situation yesterday.
I believe that atmospheric moisture readily makes its way in behind said insulator cup and condenses on the aluminium head. This is also where people primarily see liquid spotting on the back of the insulator cups. Then as the motor begins to warm up this moisture is displaced / evaporates / moves into the distributer assembly to the next coldest surface – the inside of the plastic distributer cap and condenses again causing the misfiring / stumbling.
Yes the insulator cup(s) itself can be defective / have micro fissures perhaps – but that is NOT the case in my car as the photo proves with excess moisture sitting inside the distributer caps to the point the car was dead – where it ran 100% perfect minutes previously at cold startup. (The moisture was NOT on the underside of the distributor caps at startup is what I am pointing out!)
So to me the void behind the insulating cups IS the primary weak point. And I am trying to think of a material to seal / fill that void - foam would need to be applied carefully and possible hazard due to the engine temps. Unless I use Pink Fire rated foam…….. a bead of RTV won’t be enough either there will still be void space. I also want to avoid a situation of glueing or adhering the insulating cups to the head wherever possible. I would place a tube inside the rotor hole area to protect the cam oil seal ring from the pink fire rated expanding foam. For those wondering about the foam – yes it will clean off and dissolve with appropriate cleaners should I wish, and have a backup new pair of insulting cups on the shelf for this experiment – to swap back in if required.
WD40 is bashed on most forums since it is a less than ideal lubricant. Lashing WD40 inside the distributer caps is a temporary solution at the moment which after all is exactly what that product is most suitable for (Water Displacement 40th Formula) Has anyone used WD40 before in the M119 caps? It does work………. It was my brother who suggested it yesterday, he is a top fuel crew chief and uses it on the Mags when the dragster is stored outside overnight before racing. The WD40 spray layer will not last indefinitely, indeed it may only last a few weeks and evaporate off but whilst that coating is inside the caps the water condensation cannot condense and cause issues. Moving forward, foam or not I also intend to upkeep the WD40 spray inside the caps as additional protection.
EDIT- further reading on TFTSNBN https://www.benzworld.org/forums/r129-sl-class/1638170-m119-distributor-caps-moisture.html
PS I have my own ideas and theories developing on this issue ranging from how any vapour can escape from the caps etc and I will create a new full thread of my own
Note the M119 caps are vented, via slots at the bottom.
I keep reading about the insulator O-ring as being a problem, and that replacing it will somehow fix things. I don't think anyone understands how little that O-ring does. AFAICT, it primarily is a dust seal, and provides a soft barrier between the cap and insulator. There was a lot of speculation, SWAG's, and not much useful info in that thread. Drilling a hole in the oil fill cap to relieve excess crankcase pressure was an awesome suggestion. (Not!)
I'm not convinced the bottome vent slots are a problem to be "fixed". We've already proven that the mystery liquid which collects on the back of insulators is not water - if the damp insulator is removed and left to sit out for days, the liquid never evaporates. I'm also not entirely convinced the liquid is condensed oil vapor being pushed out the seal, but that is a possibility.Exactly! This [vent slots in the cap] is a problem.....
