Moderator's note:  Another fully illustrated HOW-TO on headlight switch replacement can be found at post #55 of this thread. You can reference that HOW-TO at this link.
My 1994 E500 headlight switch started getting finicky, sometimes stuck, and telling me it needs to be replaced. There is a fantastic HOW-TO at Pelican Parts:
LINK HERE: Mercedes-Benz W124 Headlight Switch Replacement | 1986-1995 E-Class | Pelican Parts DIY Maintenance Article
A couple of notes (some un-needed steps):
Headlight switch part number: 000-545-62-04 (it was $62 at mboemparts.com as of spring 2018. Edit: now $58 in April 2024, list price $72.)
Tools: 8mm socket, phillips head screw driver, 24mm socket or needle nose pliers, plastic interior trim removal pry bar.
This is a straight forward job, just take your time. My switch lasted 168k miles and I think I will never be replacing this switch again.
In case Pelican Parts link does not work at some time in the future I have attached a PDF of the instructions and photos.
- I did NOT need to remove my lower kick panel
- I did NOT need to disconnect the parking brake release cable from the handle
