NOTE: The test method described below may not apply to 126 steering links, see post #5 and #20 below.
I always used the side-to-side method for checking tie rod ends & drag link ends for play, yanking on the tire. The FSM procedure (click here) specifies to check the joints for play while turning the steering wheel back & forth ~4 inches.
However, @jhodg5ck had mentioned to check the joints with pliers as well. Sure enough, I had two bad drag links. Video below shows one of 'em, the other was similar. Both ends of the drag link had nearly identical play. The new drag link has zero vertical play.
For the 124.034/.036, the drag link is P/N is 124-460-14-05. New Lemforder drag links are made in Turkey and are suspiciously inexpensive. Genuine MB drag links for 034/036 are made in Germany with TRW ends/joints at 4x-5x the cost. Part numbers for the tie rod assemblies are in post #19 below.
Thanks for the tip, Jono!
