I could use a wavetrac diff for my 190 3.6 build. Have to check what's the stock diff 2.6 ratio and if it would fit. What's the ratio range it fits too?
Certainly not interchangeable the 185mm with the 210mm diff core. No I ment I would be in to take one of the 201 5sr is going to get if it fits the 2.6 diff (which I have to check yet retio wise)
@5thscaleracer are you still doing this group buy or alternatively do you have any leftovers from that group buy? I’m interested in a wavetrac differential
Just FYI for interested parties, this is a complete 2.65 ASR differential with Quaife ATB installed, ready to bolt into any E500E, and into any 034 (400E/E420) with ASR. Should include the correct ASR wheel speed sensors for W124 as well but oaklandw124 can confirm what exactly was R&R'd.
Forgot to mention earlier, but for either Wavetrac or Quaife ATB diffs, you need a gear oil with zero friction modifiers. I highly recommend Motul Gear 300 75W-90 (not Gear 300 LS, which is the friction-modified version for clutch-type LSD's). It's expensive, but worth it... actually points like motor oil instead of maple syrup in January.
Ensure smooth gear transitions with MOTUL GEAR 300 75W-90. High-quality, durable oil for optimal vehicle performance.
shopmotul.com
Bad news is, this stuff is on nationwide backorder, so you'll have to wait to get any... unless you can locate a few random bottles on a dusty shelf somewhere. Need 2 bottles to fill the 1.3L diff after the build is complete. There's a seller on eBay with 6 bottles left, $40/ea delivered, ouch.
Forgot to mention earlier, but for either Wavetrac or Quaife ATB diffs, you need a gear oil with zero friction modifiers. I highly recommend Motul Gear 300 75W-90 (not Gear 300 LS, which is the friction-modified version for clutch-type LSDs). Its expensive, but worth it... actually points like motor oil instead of maple syrup in January.
shopmotul.com
Bad news is, this stuff is on nationwide backorder, so youll have to wait to get any... unless you can locate a few random bottles on a dusty shelf somewhere. Need 2 bottles to fill the 1.3L diff after the build is complete. Theres a seller on eBay with 6 bottles left, $40/ea delivered, ouch.
shopmotul.com
Designed for transmissions and transaxles - helps to slow synchros for easier shifting across a broad temperature range
www.redlineoil.com
Red Line 58304 (75W90) Limited Slip Synthetic Gear Oil - 1 Quart Bottle https://a.co/d/4Rkljru
I have been using this non friction modifier gear oil in my sport beetle’s G50 gearbox (buttery smooth in a gearbox known to have some crunching when cold) and in my Torque Biasing Differential on the same car (gearbox and diff share oil) and I love it.
www.redlineoil.com
Hmmmmm..... I am surprised by this blanket statement. Could this be a misunderstanding? Intrigued, I went to the Wavetrac website where I saw this in the FAQ:
The highlighted text advises against Red Line Shockproof Oils
The bolded text below advises against "Redline, Shockproof".
Looking at Redline's website, it seems (but is not verified)that 75W-90NS is exactly what Wavetrac is looking for when it comes to not creating too much slipperiness..... because the "NS" label indicates that this particular 75W-90 does NOT have friction modifier and is NOT part of the the Redline shockproof line.
I suppose this question is unanswerable unless someone calls up Redline and Wavetrac and speak with their application engineers.
FWIW I have always received expert advice from David Granquist @ Redline on specific technical recommendations.
Jlaa, I think you are correct. Shockproof is a definite no-go but their NS lube should be fine - however, I'd confirm with Wavetrac before using.
Note the Red Line juice still won't pour like the Motul. The easy pour (low viscosity at room temp) sold me on the Motul despite the higher cost. Soooo much easier to work with; especially when filling the diff in the car (not the workbench).
Looks like Wavetrac doesn't understand the Red Line products. They likely had one bad experience with someone using Shockproof, and decided to just not recommend that their customers use *any* RL lube, so that way people won't accidentally use the wrong stuff. Pretty lame IMO, I'd call them out on it via telephone but it would likely fall on deaf ears. They probably just don't care. Really irritates me to see stupidity like this. I'm still pissed at Wavetrac for their incompetence when I helped them develop the 500E differential application 10 years ago, and this Red Line isn't helping my opinion any. I still like their products though; but now that the Quaife is lower priced... hmmm...
Looks like Wavetrac doesnt understand the Red Line products. They likely had one bad experience with someone using Shockproof, and decided to just not recommend that their customers use *any* RL lube, so that way people wont accidentally use the wrong stuff. Pretty lame IMO, Id call them out on it via telephone but it would likely fall on deaf ears. They probably just dont care. Really irritates me to see stupidity like this. Im still pissed at Wavetrac for their incompetence when I helped them develop the 500E differential application 10 years ago, and this Red Line isnt helping my opinion any. I still like their products though; but now that the Quaife is lower priced... hmmm...
So Wavetrac is Autotech Sport Tuning an old VW/Audi tuning shop back in the 80's.
They were a Redline dealer from 80 to mid 2000's and they were the Quaife distributor/dealer for North America at one time.
Their whole staff is familiar with redline fluid offerings.
So it's not that they don't understand the redline product. Most likely they have seen unfavorable results from the use of Redline and possibly other oils over the years. It makes sense that they will suggest an oil of their choice to help protect their product.
I have tried Redline 75w90NS back in 2016 when Gear 300 was on BO for 6 months. Diff felt ok no issues aside from boiling the fluid over after doing 20 laps non stop at Bigwillow with the 190E. Ended up draining and using Castrol that same day and didn't have the boil over issues. Castrol made the diff smoother on deceleration. The transition from power to no power (throttle steering) where the Wavetrac stays locked.
So if any of you want to try redline for street use i am sure it will be fine. But if you are going to claim "warranty" expect some kick back form Wavetrac for not using their suggested fluid.
Are you guys familiar with a company called Lubrizol?
That company along with others like them are what differentiate what is Castrol, Mobil, Motul, Redline, Royal purple etc.
The oils we use today are based off these basic ingredients.
- Base Stock
- Friction Pack (purchased from 3rd party company like Lubrizol)
- Proprietary Secret Sauce (I call it snake oil umami)
you guys should google Lubrizol and really go down that rabbit hole attempting to determine who makes the best. I did my research back in my collage years. All i can say is it's a waste of time! If a Mfg says use X use X. If you want to use Y then just own up to the mistake if something were to happen.
The bolded text below advises against Redline, Shockproof.
Looking at Redlines website, it seems (but is not verified)that 75W-90NS is exactly what Wavetrac is looking for when it comes to not creating too much slipperiness..... because the NS label indicates that this particular 75W-90 does NOT have friction modifier and is NOT part of the the Redline shockproof line.
Redline makes a great product but you are looking at this the wrong way.
Redline and Motul can't make the same product they can only make similar or equivalent products. But that variable can make a difference in performance down the line.
Its like painting a car..
PPG 199 paint code vs Sikkens 199 Paint code
Similar product its paint
but colors won't match
ppg is thinner
sikkens is a harder paint
If you are happy with redline on that G50 trans good for you but I have a group of friends who hate redline for the G50 and use Fusch or Titan.
So personal preference I think is irrelevant especially when comparing a G50 environment to a differential environment.
All i can say is if you are using an equivalent oil for whatever reason monitor the performance.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
