I will be waiting with baited breath for your impressions!I have dozens of tapes recorded by a friend who shares my musical tastes. He recorded them In the early nineties from expensive state of the art direct drive turntables. Recorders and amps were the kind of stuff you guys pine for. All where recorded on Maxell XL 2s high cr02. These tapes still sound great. Noticeably better than CDs. They sound VERY good in my 1432 with rainbows up front. The exciting thing about your post for me lies in the fact I've never even tried them with the CR feature engaged! Turns out I may be in for an improved experience!
You can't beat JL Hooker and the blues.
Those are more for "retro reel stylejunkiesenthusiasts", some still exist out there. I too had few of them back in the 80s. The cassettes with such reels (originally made that way) are very hard to find these days, but some people are still buying them. To use them in our cars is a waste of money; once you insert the cassette in the player, you will not see the reels any more.
Yes, of course I do.If you recall, nearly all advertisements for home cassette decks in the 80s pictured the decks using “reel to reel” look cassettes.
Yes, of course I do.Those cassettes were very hard to come by, especially that at that time I lived in a communist country. Each time I was looking at a flyer with a new deck, I was drooling. In the end I got a Grundig, Akai or Onkyo were out of my reach.
Those times were different, many memories are coming back. Driving now a Mercedes from that era and listening to that music on cassettes is a one of a kind feeling, hard to get otherwise.
Wow, that's an exquisite looking repair! Nice work. Here's what I wanted to rant on earlier and couldn't. There are some "off label" use prescriptions here in my post, so caution is advised and YMMV:
First here's what actually goes wrong with these resistors: They were mounted in that awkward position that causes all of the heat from that glowing! (yes, look at it in the dark) resistor element to rise upwards over the upper wire termination. This extreme thermal exposure with resultant expansion and contraction causes the threaded attachment to eventually loosen. The loose connection eventually gains resistance to the point that it overheats and burns. This heat also travels along the copper, causing the insulation to burn, which in turn also releases corrosives that infect the termination. The syndrome continues unabated until the connection finally fails and/or the wire breaks.
Two things hasten this process along: The first and most common is that many, if not most of these cars have fan clutches that haven't worked correctly, if at all, since the day the car was built. This caused the auxiliary fans to work almost constantly in a futile effort to cool these lumps off.
Note that if the air conditioning compressor is engaged, the auxiliary fan low speed is usually switched on in a very short time as the refrigerant pressure rises to above 16 bar shortly after start up on a summer day. That is all good. That's why the auxiliary fans are there. They protect and enhance the air conditioner in those conditions where the refrigerant pressure is high, the engine fan is idling (not yet heated up enough to engage), and the vehicle is at low speeds or stationary. In the cars with inadequate fan clutch action, (remember, that's a lot of them), the auxiliary fan low speed was switched on in almost any operating condition whenever the ac compressor was engaged, so that terminal junction got a lot of heat a lot of the time. It didn't stand much chance of survival. Also not surviving this abuse were the low speed auxiliary fan fuses which were either 15 or 16 amp depending on which of the several wiring and relay arrangements that these cars had. Regardless of that and on the subject of fuses, only the Germans would fuse a circuit with a fuse having a capacity only slightly above the current passed through a correctly functioning circuit so that the fuse is frequently overheated and cracks incessantly in hot climates just from the constant thermal cycling. Hello poor ac performance and short lifespan of the high pressure ac componentry including poor Mr. Kompressor. Also, hello such concoctions as the "cool harness" causing the high speed auxiliary fans to work incessantly while duty cycling off the ac compressor to prevent high temperatures, the engine temperature in this case, not yours. The various inoperative fan clutches and low speed auxiliary fans running around out there are why people think these things are just the cat's ass.
WARNING, AUCHTUNG! An "Off label use alert" is in effect for all of the following: You are free to agree or disagree. I've been through these circuits 6 ways from Sunday and have at least 20 years of real world "testing" experience for the advice I offer below. But be warned that it is "approved" by no one, and "tested and verified" by no laboratory or engineer! If you do what I suggest and your car and whatever it is parked in burns to the ground, I KNOW that none of this advice caused it, but still don't tell me about it because I won't care, because as I said, I know this didn't cause it. There, you've been warned.
Now here's what I advise:
For all 107, 123, 126, and 124, If you have a red ceramic 16 amp auxiliary fan fuse in your fuse box [fuse D on the 124], replace it with a blue 25A fuse. It will stop chronically cracking putting thousands of dollars of your refrigeration system at risk. If you develop an actual high current consumption situation, it will burn open as it should and protect the wiring. [Note: This applies to non-V8 models of the 124 chassis. The 400E/500E do not use fuse D as the power feed for the twin auxiliary fans.]
[The pre-facelift, 1992-1993 USA model year 400E/500E have an external 30A strip fuse, typically located behind the brake booster. This 30A strip fuse feeds the single large fan relay K9. See attached image/screenshot with schematic from ETM.]
For facelift (1994-95 USA model year) E420/E500 only: If you have a blue 15 amp blade fuse in the blue low speed auxiliary fan relay (K9/1), replace it with a yellow 20A fuse for the same reason stated just above. [The high speed relay (K10) may have either a 30A or 40A fuse. See attached FSM ETM PDF; note the schematic differs between -->1993 and for 1994-->.]
The other reason that these resistors cook and fail is that MB kind of mistakenly (IMO again) thought this resistor a hazard early in the V8 124's lifespan. The hazard (ok, usually just some smoke) was actually caused by an aesthetic measure: The cramped quarters in the V8124 caused them to locate the alarm horn in plain sight right there between the brake hydraulic unit and the headlamp. Someone at MB obviously thought that this rude and often corroded bright metal clashed with the acres of black plastic surrounding it. They therefor fashioned a black plastic trim ring that fitted around the circumference of this alarm horn there by making it blend in better with the rest of the black plastic. Low and behold, this plastic ring would get all squidgy from the under-hood heat (remember those fan clutches?), and fall off the alarm horn. Then where would they land? Right on that hot auxiliary fan resistor! How you like that, Smokey?
In response to this, did they have us remove the trim ring from the ATA horns? Yes they did. Then they also built in at the factory, or had us retrofit a freaking sarcophagus around that damn resistor! That's why most of these cars have an additional perforated heat shield around these things. It was yet one more thing that tried to kill these overworked resistors and their associated connections. Many of these shields are missing because technicians recognized them for the additional menace as opposed to safeguard that they actually were and they often didn't seem to find their way back onto the vehicles. So here's another off label use. Make sure there's nothing near that resistor, and that anything that could find its way to it, such as a unsecured wire, is properly secured in a position well away from the resistor. Then, assemble the resistor such that it has no additional covering. IMO, it should look exactly as Doug has it in that picture. No less, definitely no more.
Here's another "off label" modification: Let those puppies breathe! Not those puppies, Andy. I'm talking about these resistors. This is very easy to do with the headlamp out, and still doable with the headlamp installed. Using a die grinder, Dremel, or the like, cut a ventilation opening in lowermost vertical portion of the surround shell of the left air guide, just forward of and slightly below the resistor. Here's a few pictures. Expand the pictures and you can easily see the hole, along with my fickle finger through it just in case you can't:
View attachment 30450View attachment 30448View attachment 30449
There is already a guide for you right there, as the USA cars prior to '94 have a blanking plug or a knockout plug in that very place that you need to open up, and the Euro cars / USA '94 and later cars have the ventilation hose for the headlamp housing passing through this hole. Make sure that this ventilation hose is still in place after you add a resistor vent hole, as its purpose is to prevent the overpressure that may exist in these air guides when the vehicle is at speed from entering the headlamp units causing dirtiness and condensation. You Euro lamp fitters removed these blanking plugs and installed the vent hoses for your lamps, didn't you? I bet you will now...
Hmmmm….thanks! Have you ever taken the temps of the resistor while jumping the pressure switch with the rest of the car cold, in the garage? I am curious to survey others’ temperature data…maybe such data can be used to infer “bad wiring” vs ”good wiring”?I left mine off, removed the horn and they reside in a drawer someplace. On the back corner or the light box, klink had me cut a hole the size of a quarter (+/-) so not only would the light design allow air flow back there but more of it. I also had bad wires going up about 10" from the resistor so that was a fun rebuild too.
My son and I were discussing this… he plays wax in his dorm room to a Bluetooth speaker I got him… this type of setup is really tempting me… but I know, it’s hustling backwards.Yes, of course I do.Those cassettes were very hard to come by, especially that at that time I lived in a communist country. Each time I was looking at a flyer with a new deck, I was drooling. In the end I got a Grundig, Akai or Onkyo were out of my reach.
Oh weird. They had to emissions test your car when NEW?Jeff - some interesting comparisons with my '93 Red.
My serial #979484 - quite a ways off
My engine # 007967 - close
My ship # 3095 - close
My car came in thru LA to Hutchinson Motors in Walnut Creek.
Don't know why the VINs would be so far off?
Oh, and my list price is $30.00 higher for Cali emissions test...
2 years later! 4000 more miles and I (phew) passed smog again. It is always a nerve wracking experience passing smog in CA. HC and CO number are low, but just a tad higher than last time. Same shop, same tech.It has already been 2 years since the last smog check! With the pandemic going on, traffic is very light. It is only a 30 min drive all at freeway speeds to my fav smog place - Holly Smog in San Carlos. If anyone needs a smog in the Bay Area, Andrew and Luis at Holly Smog are pros. When they lift the hood, the first that they do is actuate the latch to make the hood go 90* so that heat doesn’t build up while performing the tests. Actually this is one side benefit of a 90s car with non defeatable traction control —- in CA, the only smog test needed is the stationary sniffer test. No dyno run needed.
The car passed w good results, and we chatted about Andrew’s Dodge Conquest w LS swap and the 240SX on his lift that he’s stripped and is restoring.
Not to turn @Jlaa's thread into a hi-fi thread but, I have 3 of these (rare now) Sony Super Metal Master Ceramic cassettes, the sound is unreal for a cassette tape compared to type i or type ii cassettesMy son and I were discussing this… he plays wax in his dorm room to a Bluetooth speaker I got him… this type of setup is really tempting me… but I know, it’s hustling backwards.
Does the smog test state the lambda value ?2 years later! 4000 more miles and I (phew) passed smog again. It is always a nerve wracking experience passing smog in CA. HC and CO number are low, but just a tad higher than last time. Same shop, same tech.
I was also talking to my awesome smog guy about aftermarket cats (for when the OE one fails in the future). He helpfully printed out this guidance from the BAR for me. Note the underline part —- techs are supposed to check that the CARB EO number falls within the correct vehicle category (but they do not have to check for specific application for pre OBD2 cars!).
It measures HC and C02 and C0 under specific conditions, which is a function of lambda, but it doesn't explicitly report on lambda.Does the smog test state the lambda value ?
@Jlaa, Why the sweaty palms? The M119 will pass CA Smog with flying colors. I was assured that by Glen after my car sat for 3-1/2 years and all I did was fill the tank w/Arco Premium and a bottle of Chevron Techron. Drove about 30 miles on the freeway and2 years later! 4000 more miles and I (phew) passed smog again. It is always a nerve wracking experience passing smog in CA. HC and CO number are low, but just a tad higher than last time. Same shop, same tech.
Paranoia maybe? I will use an analogy I am sure you might appreciate. Taking a car to smog for me is like taking a residential project through building inspection / plumbing inspection / electrical inspection / whatever. Always those code guys can find something to pick apart.@Jlaa, Why the sweaty palms? The M119 will pass CA Smog with flying colors. I was assured that by Glen after my car sat for 3-1/2 years and all I did was fill the tank w/Arco Premium and a bottle of Chevron Techron. Drove about 30 miles on the freeway andIt passed
PS: Glen’s “High-Miler w/ 662,527 miles on the clock just passed CA Smog on 8/01/2022
RELAX! I’m sure as meticulous as you are and it’s banging on all 8 cylinders you have “No Worries”for a long time
lol
I understand your logicParanoia maybe? I will use an analogy I am sure you might appreciate. Taking a car to smog for me is like taking a residential project through building inspection / plumbing inspection / electrical inspection / whatever. Always those code guys can find something to pick apart.
East Coast! From what I can piece together of this car's ownership:Nice work @Jlaa!
I was surprised by the level of corrosion you found. Where did your car live prior to your purchase?
Nice. I should point out that I wire-wheeled these nuts to remove corrosion. I don't know if wire-wheeling these removes any plating on these either, so I've ordered new nuts too. When I receive the new nuts as well as the two new copper nuts that bolt onto the exhaust, I will drop and clean the cast aluminum transmission support bracket too.Love this! Had a similar rusty bracket holding a hose in my 560SEC. Small, but stuck out like a sore thumb to me. 20 minutes of wire wheel plus spray paint and Im sleeping easy at night. Paint the back of the fence, as Steve Jobs Dad used to tell him...
While working, Paul shared a piece of advice with Jobs: “Youve got to make the back of the fence, that nobody will see, just as good looking as the front of the fence,” Isaacson told “60 Minutes.” “Even though nobody will see it, you will know, and that will show that youre dedicated to making something perfect.”
Fascinating!East Coast! From what I can piece together of this cars ownership:
FWIW I was surprised at the hidden corrosion on the back of this exhaust bracket - the part that faces the exhaust mounting. I am not sure if this is because it is painted metal on metal contact here on something that moves/vibrates (the exhaust) or if the bolt plate itself is mild steel and rusts or what --- but I wonder if the back of the bracket on many peoples cars has corrosion ......
- Stockbroker in NY. Made it big, bought the car with cash and retired to AZ.
- Peter Mueller then acquired the car when the stockbroker (who was Muellers classmate) was dying of cancer. As I understand, Mueller was an auto wholesaler in the East Coast and may or may not have been with the Hitler Youth. He passed in his 70s and was a heavy smoker/drinker. The car from what I understand was super special to him and he often brought it to shows.
- then acquired the car. The father of this individual went to prison over 99 counts of bank fraud, filing false tax returns, and insider trading.
- Jeff093 in New Hampshire acquired the car.
- Moi! Luckily my life is rather dull and devoid of drama!
shoe sizes.........I'm missing any info on the shoe sizes here.Fascinating!
I love how much you have been able to put together regarding the past owners and the lives they lived!
YessssssWeekend project. I cleaned up the filthy transmission mounting bracket and polished 1 surface of the transmission pan. Ugh. That trans bracket was gross. It took a whole can of brake cleaner and many qtips to get it back to looking shiny….. 90 mins worth of cleaning! Also, I love the right angle drill I bought some time ago.
My next tool purchase will be an ultrasonic cleaner.
View attachment 163745 View attachment 163746 View attachment 163748 View attachment 163749 View attachment 163750 View attachment 163751 View attachment 163753 View attachment 163752
Thanks! I read that SG is corrosive to alu parts - is that why you use SG Extreme? (SGE being not corrosive?)Yessssss
Buy the biggest ultrasonic cleaner you can fit. Then buy gallon jugs of simple green extreme off amazon.
While your wallet might not thank u, you’ll never think about investing in q-tip stock again.
I used shop’s ginormous sand blast cabinet w huuuuuuuuuuuge shop sized compressor to blast off the finish off 4 old Citroën TRX sized wheels some years ago. That’s when I realized sand blasting a tiny little line at a time actually makes blasting a whole big thing take longer than one might imagine!!Yeah... the garage tool I fell in love with at first sight was the media blaster. Then the lathe. But of course those arent exactly residential garage tools. Thank God for friends. One day Im gonna figure out how to own a shop with someone I bring out of retirement.
Yes exactly. SGE is safe on aluminum and it used throughout the aviation industry.Thanks! I read that SG is corrosive to alu parts - is that why you use SG Extreme? (SGE being not corrosive?)
BTW I still need qtips. Because 3 piece wheels.
