1995 S500 windshield wiper nightmare
JRVAULTS
It seems my drivers wiper has a hydraulic arm that is failing and extends the wiper out all the way and it's hitting the car at the edge of window? Why?
Your car is showing 2 wiper blades. What model is it? It’s not a 124.
If the blade is extending to far you probably have to remove the mechanism and repair or replace it.
I have w140s and these pics are from my S280 when I repaired its wiper.
You likely have a stripped plastic gear due to age / lack of lubrication. Take it out, strip, clean and inspect it.
(Note this car has 46k miles on it only. The mech had seized up a little from sitting around)
View attachment 214553View attachment 214554View attachment 214555
Yes in the first pic...it pushes that arm out but fails to pull it back in...I can't tell how that could happen...
Hey...how do I remove that piece from the car? It looks like I'm gonna have to remove that too piece with a ton of the hex head screws holding it down....like 30
That arm pushing out and not back in is my only problem. Other wise it works fine. Can't I just prevent it from coming out?
Yes remove the screws and trim.
It's clearly broken and in need of repair. If you want a straight R&R job get a good used wiper.
Can I modify it to a normal wiper arm instead?
Erm - no. It will be less effort to just fix it properly.
