OWNER 357Magnum (400E)
357Magnum
Hi, after registering here a while ago, here's my introduction.
400E, 06/1993. Smoke Silver, 30mm H&R springs, 8x16 ET34 with 215/55 tires. New upper wiring harness, a new radiator had to be installed at the end of last year because the old one was leaking. I also replaced the leaking camshaft seals because there were ignition problems (the distributor caps were always a bit oily). Oh yeah, almost forgot, the transmission oil pan gasket was also leaking. I changed the filter and transmission oil at the same time.
Before this, I drove a 190E 16V, not as a daily driver. I always told myself, "I'll only sell the 16V if I happen to be offered a good W124 V8." Well, after 15 years with the 190, the time had come. I have to say, the 124 is the better 190 :) You have more space, it drives much more comfortably and smoothly. It's less stressful. The V8 packs a punch when you floor it, but it's really a relaxed cruiser. The M102 16V was always "ready," always slightly aggressive. The engine sound is great in both, each in its own way.
Hello, and nice-looking car you have! Nice touch with the MOPF2 rear bumper with black impact strip, I've never seen that before. It's certainly unusual but I like it! Are you going to color match the bumpers and Saccoplanken as well?
And regarding W201 vs W124 - I honestly think it's a bit of an age-related thing as well (🤫).. I got my W201 when I was 18 back in 1998, and loved that thing! My parents had a W124 at the time, which I thought was nice in any way, but not for me. I preferred the nimble and point-and-shoot handling of the (lowered) W201 much more, even though it was smaller inside (actually tiny when I look at it today)! I got my first (own) W124 last year, and seem to have grown into it over the years. I find it to be the perfectly human sized car, unlike most new cars which I find to be waaaay to big (even my CLS BS is cumbersome in a lot of situations.
I actually still have my W201, which I recently started looking at again after 15+ years in storage. Besides a leaky radiator it has coped with the years out of commision surprisingly well, and still starts up as if I parked it yesterday (yes, it's a diesel).
Thanks. To be honest, I only just noticed that the rear bumper is from the facelifted model (MOPF2). LOL. It was probably installed by the previous owner. The right rear quarter panel has been repainted at some point. I think the original bumper was damaged and this was the only one he had available
Today I replaced the crankcase ventilation hoses. They weren't rubber anymore, they were rock-hard plastic. Of course, the only connector I can't find new anywhere in Europe broke. It's part number 146 in the picture. I've now found it at a dealer in San Francisco... I hope it arrives here in Germany. For now, I've temporarily repaired the connection with superglue. But this shouldn't be a long-term solution.
I couldn't get the crankcase ventilation hose back on at the throttle body. So I removed the throttle body, and of course, the rubber gasket for the mass airflow sensor was rock hard and cracked. 🙈
Good grief, everything under the hood made of rubber is as hard as a rock. And since I already had the throttle body out, I sent it straight to a specialist here in Germany for repair. They're checking everything, replacing lines, and cleaning it. I'll let you know when all the parts are back in.
Yes - ALL the rubber bits on the engine get rock hard after 20-30 years! When installing new parts, it's amazing how soft they are. The MAF boot/seal is one of the items which gets fossilized, along with all the PCV hoses on the intake manifold. Thankfully, all those parts are still available new from Mercedes. (Don't use aftermarket hoses, they do not last.)
So, this week the throttle body came back from its overhaul. It came with a new gasket between the intake manifold and the throttle body, and the "donut" fitting for the mass airflow sensor. I put everything back together, turned on the ignition, waited a bit, and started the engine. A constant whistling noise, and the idle was too high... disaster!
So this morning I took everything apart again, checked everything once more, and used another new gasket for the intake manifold. Then I put everything back together. I only installed the new gasket after the throttle body had been "puzzled" into place between the intake manifold and the throttlebody (which is a nasty job requiring a lot of dexterity). Then I started the engine again... and the M119 is running again!
When you repair something yourself and it works again afterward, that feeling is the best.
Apparently, I damaged the paper gasket when I first installed the throttle body, which led to a leak and caused the hissing and whistling noise along with the poor idle.
The only annoying thing now is that I damaged the connector, or rather the locking mechanism of the throttle body connector, and it's currently being held in place by two cable ties. Is this locking mechanism for the plug perhaps available separately for replacement?
Good to hear it's running again! The paper gasket for the ETA should be stuck to the ETA with a thin coat of Hylomar sealant. This keeps it in place while installing. I believe this is mentioned in the FSM procedure.
The large connector is not serviceable or sold separately. It had been available as a full electrical pigtail, so you could replace the entire wire harness+connector, and solder the new one to the ETA. But, this is NLA now. Not sure if Kurth sells it separately.
