C36 ECU part numbers help
yao500e
Passionate owner of: 1994 E500, 1995 C36, 1997 E50
Hello folks.
I have an opportunity to buy a stock C36 ECU for a back up part.
Wanted to know if anyone can help verify these part numbers for me.
'95 C36 module is HWA-202-545-95-32
'96 C36 module is HWA-202-545-87-32
'97 C36 module is HWA-202-540-11-45
My year 1995 C36 vin: WDBHM36E6SF247453
really appreciate it.
Actually I would like to get another, but they are rare to find and when you do, they are pretty used up. Same with the W202 C43.
hi @2phast right now is a great time to buy a C36 again. And its ok to get a pre-1997 car is totally ok and in my view better in some ways.
My early 95 C36 had part number hwa2025459532 and the car had ASR. That is all I can share.
Hi 2phast. This is just an FYI.
I was told today ECU for 1995 and 1996 were same for both ASR and non ASR cars. My mechanic buddy confirmed this.
ABS ASR are controlled by another ECM unit on the car as we already know. he actually swapped ECU's into ASR and non ASR cars and it worked.
Just to add some confusion, my ‘96 has 202 545 96 32
It seems to be listed as a 95 ECU everywhere I’ve looked for one though… mine seems to have lost its output to turn the fuel pump on :/
Wait a min, your ECU is VDO from a Europe or Japanese car. where are you located? i know of one for sale at $1,000 USD or so.
I’m in Australia. $1k usd is too much for me at this stage. I can work around it by jumping the power from the sunroof fuse to the fuel pump relay so it just comes on with the key on :p
ok. if that work around does the job, then go with it. you should really figure out how to fix your ECU. it will be a huge problem one day. other components may start to short and burn out.
Yeah
I’ve got some avionics guys at work that recon it’s fixable
Since my '95 C36 is higher mileage and more often driven, over the years I have purchased additional ECU's as back up.
I even found a great ECU remapper and i purchased year 1995 C280 m104 ECU's and had it custom mapped for my C36. so I have a bunch of back up ECU's lying around. These cars are 30+ years now, gotta have these computer module spares incase something goes wrong!
