Re: Bad bolts on engine rotors , how to take them out ?? HELP
Hi
There is an astoundingly difference in quality depending of brand of rotors and caps, i have recently learned...
I changed my rotors and caps in june this year, the last time was in 2006 at 130 000 km, now at 190 000 km they was not that bad, but
the odd minor misfire at idle and a look at my notes told me there was time to change them.
I bought a set of Berus from Ebay UK and put them on, very simple work, no problems with screws on the old Bremi rotors at all.
I noticed after a while an increase in fuelconsumption and some not so minor misfires at idle at the redlights, it suddenly wanted
13,5 liter of fuel per 100 kilometers, at this years vacation to Germany it engulfed 14,6 liter per 100 km!
Even on a rapid journey i have never exeeded 13,5 liters per 100 km.
And in Germany the misfires was apparent.
This weekend i removed the caps and rotors, and found this...
It may be hard to see in the picture but after under 5000 km the caps and rotors show quite some oxidation, there are marks after the rotor in the oxidlayer on the caps pegs to the ignition wires, so much oxidation after under 5000 km!
The rotors are also miscoloured and have a burnt look.
This a Beru cap.
This is the Bremi caps and rotors after 60 000 km.
Of course one of the screws in one of the Beru rotors failed, the tiny 3 mm allen key slipped and i tried with a size 20 Torx but that
slipped in the hole and a size 25 was to big, the hole in the screw is very shallow so you can´t drive the Torx so far in that you want.
Fortunatily Roger ( Taxidriver ) came by for dinner and some wine, so the morning after we got down to the garage and and cut a slot in the screw and inserted a flat screwdriver and could brake it loose.
When you compare the to rotors you can notice some differences, the Beru rotor have a small peg who pickup the spark from the
center peg in the cap, the Bremi rotor have a plate with a hole in it to take the spark from the caps peg, this make the Bremi rotor
to have a much bigger surface to receive the spark from the cap.
On the Beru caps you can see four distinctive spots on the center peg with heavy oxidation where the sparks have jumped from cap to rotor.
The material in the Bremi caps and rotors looks superior to the material in the Beru caps, the brass looks much moore of a higher quality.
I have now bought caps and rotors from Aiaautoparts in USA for 180$ including shipping, this is a good price and they are Bremi parts wich is the only make i will use from now.
I´ll have read this about Beru parts on the Swedish Mercedesforum but i thought it to be the usual myth, of witch there are so many
in the hobby, but not this time...
I read a comment where sombody wrote that Berus will only last about 10 000 km on a E500, but i disregarded that, not so any moore..
There are no other changes of any other parts as airfilter, fuelfilters, plugs or anything, on a testride yesterday with the Bremiparts installed and a 220 km journey at quite a pace, no old woman to church driving, i got 11,7 liters per 100 kilometers... thats a clear and
distinctive result.
I am sort of flabbergasted of this, i have used Beru parts for a long time, even proffessional in the capacity of workshopmanager of the
Swedish postaloffice and i have never had a reson to belive that Beru was second to none, but this is puzzeling me.
Does someone have clue?
Best Regards
Totte
