Is that Roma_500E's car?
Right!Is that Roma_500E's car?
Alex,
It would be a good chance to hide those crevices now, which to my understanding has no other mission than indicating the panel joint, which can be seen inside the boot if ever needed...
I like the original look,
I thought of that and also about hiding antennae hole also, but decided to go stock look
Alex,
ABSOLUTELY NOT! Any restoration if correctly done, would not hide, with lead, plasic, by any means. Result would be nothing but, cheap look and
a bad sign of a careless restorer. I would look at it very suspiciously, what is original is original...........and should stay so.
As my paint master said - oem coating is the best one that can be made, and if it remains without damage it is better to leave it as a base layer.
It can be reapplied/re-sprayed... but not to the level of the factory coating, which was a complete dip of the chassis in a bath which electrostatically (??) bonded it to the metal. If possible you don't want to remove the factory coating to expose bare metal, unless it's absolutely necessary.I am aware of the zinc coating issues, but as far as I know it can be reapplied/re-sprayed...
No racing)Oh! 380mm thats MEGA, is that really nessesary, maybe youre going racing, perhaps?
See 6:30 to 6:50:
Well, we know where a good percentage of the world's available E500E spare parts stock has gone and is going! I'm jealous! Great job and can't wait to see it finished.
Love that color [emoji7]Nearly finished with chassis.
Hope to take it home in beginning of spring and start assembly
Parts Parts Paint and more Parts!! Geezs
I'll be in Saint Petersburg on May 18th please have your car done for inspection.![]()
I hope the chassis will be back to St.Petersburg till May 18!
I a doing all works in Moscow.
If this will happen I can show it to you for sure!
No) I had one used set and sold it when I found this new ones!Do you have another set of those door sills ?![]()
