Approved ATF Discussion for 722.3 Transmission
OK, 236.14 is approved by MB as well as the best transmission shop in the U.S.
Marc has a vested interest that the best ATF is used in a transmission that he has to warranty.
And I have it in my MB reman for 3.5 years. Still smells good, nice red color.
Shifting is perfect and reverse has no perceptible delay what so ever.
So that's my opinion.
And I don't have the slightest doubt that the day MB stops is supplying the .10, the .14 will get the "should be used" fine print addendum...
They did stop selling the .10, years ago and released a Service Bulletin to use only 236.14
In all Nag 1 & 2 gear box's from 96 to June 2010.
The only source of 236.10 is the aftermarket, Fuchs, Febi, Meyle, Shell.
The Febi & Meyle are Fuchs
Perhaps we can lobby Kent to do a video on the topic. I think Dave has some influence there with his Pacific Northwest relative....
OK, my mission is accomplished. Two yoinks awarded in one thread. Yep, I've still got the Eye of the Tiger....
Indeed, and well played, Honch.
But Lord Vader is not to be denied! MB is only supplying the 722.14 fluid for ALL of the Dexron type applications. All of the 722.3 approved oil part numbers which include "sheets" 236.1,.6,.7,.9,.10 are NLA and are subbed in the Paragon system to 236.14 fluids.
:starwars:
OK, but you guys didn't answer the question ... WHICH ONE IS BEST ?!?
Eh, that's kinda like asking "which one is best - blonde, brunette, or redhead?". There is no simple, singular answer; other than "it depends". Same for the ATF.
:stirthepot:
Eh, that's kinda like asking "which one is best - blonde, brunette, or redhead?". There is no simple, singular answer; besides "it depends". Same for the ATF.
:stirthepot:
Just get one of each and that problem is solved...
:hitit:
:hitit:
I'd have to move a bit south/east to Utah for that... may encounter compatibility problems, etc. I'm happy with my current model!
:D :D
I guess you could go for a combined mixture of 2.65 quarts each of .10, .14 and RedLine.
That should make everyone happy.
probably beating dead horse agein, but, just read some local mb forums and quite many say that dex II should be used, specially mobil atf 220. That is not synthetic oil. Reason to use that is that it have more friction material than synthetic dex III. So turbine slips more with dex III. Dex III is faster when cold. Anyway I am going to try that mobil 220 ATF. http://www.ulei-mobil.ro/pdf/MobilAutoDataSheet/mobil_atf_220.pdf
Dexron fluids all have friction modifiers, which reduce friction, and make the fluid more slippery. Both Dex-II and Dex-III likely have similar amounts; I seriously doubt there is a major difference between them. Synthetic base stock is definitely preferred as it will last longer, not shear down, reduce operating temps a bit, and provide a good margin of safety in case of overheating.
If you want a fluid without friction modifiers, use a Type F fluid, which is pretty much just a Dex-II/III without the friction modifiers. This fluid allows clutches to "grab" more quickly, shifts will be firmer, less smooth. It's often billed as a 'racing' fluid, but as Jono mentioned previously, Type F fluid can also extend the life of a 722.3 trans that is slipping/flaring with normal Dexron fluid.
If you want to use a Mobil ATF, I'd recommend Mobil-1 ATF:
https://mobiloil.com/en/automatic-transmission-fluid/synthetic-atf
http://pds.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil_1_Synthetic_ATF.aspx
:gsxracer:
:D :D
She's cute and she can beat you at driving a race car. Sounds like a keeper to me...
:hearts:
I had been using synthetic fluid in my 560SEC, but when the tranny warmed up after driving 50 mi., it would not want to go into reverse for up to 8-10 seconds. The forward gears all shifted just like any other 722.3, but the reverse had a mind of its own.
Jono told me to do a type F fluid and filter change to try to extend the life of the tranny.
I am glad to report that I have not had a problem going into reverse within a couple of seconds since the change, so type F worked for now in the 560SEC.
All other cars are on Redline D-4 fluid and are shifting just fine.
I just texted Kent, here's his response.
If that's what Gerryvz's Uncle says; then it's good enough for me!
Fuchs Titan 4000 ATF is wonderful stuff, just filled the 500E with it and the trans shifts like butter. I run Fuchs ATF's and Gear Oils in all my Benzes.
We just added a 55 gallon drum of synthetic type F to the shop. Costing myself $$$$ keeping all these .3's shifting @ what should be the end of their run;)
Sent from my XT1585 using Tapatalk
Well, at least they are more comprehensively damaged when they finally die...
LOL. Yup, if used to get more life out of a trans, it likely will be more "done" when it's, er, done. Would be interesting to tear one down afterwards and see if any hard parts (items without friction material) are damaged or otherwise in need of replacement.
Trae, I'd be careful with the SEC, my understanding of the reverse delay is that if you push it too far, you can end up killing the reverse piston... although at ~$100 it's not too expensive. Not sure if other stuff can get hurt too. (??)
Nah, just clutches are thoroughly used up.
I've been running my white 91 on f type fluid for 10 years now, works Wunderbar.
Come to think of it, the only .3 i have that Isn't running some form of F (trick shift etc etc) is the s600.
We bought a 400E that "needed a transmission" a few years ago. Type F and 4-5 lbs on the modulator and she's been about 15k miles, shifts Perfectly.
Now granted, I do Not like these butter/Chrysler like shifts..I want Positive, Firm shifting which isn't everyone's bag I know:-P
my gaaawd....whaaat a thread....ive read it all..and my head is spinning :D
i think im takin the blackbeauty out for a spin...:gsxracer::jono:
What Dave said. A broken LB3 piston is not the end of it if you are unlucky, not by a long shot. It is also common for the LB3 piston to so overextend as it attempts to compress the disintegrated plate brake pack that it blows off the return spring retainer, thereby sending all the return springs into the rotating masses, grinding them and your gear set to kibbles and bits.
A delay into reverse, and/or a ratcheting noise when moving in reverse are your early warnings, but they aren't even that particularly "early"
I certainly don't want kibbles and bits in my tranny, so here is the question of the day:
Just exactly how long do I wait until a tranny rebuild? Is it subjective? I have never had to have anything "rebuilt" on any car in my life.
So far, the car shifts fine in both forward and reverse with no clicking noises.
If I have to select reverse, I do it at idle hoping that I don't exasperate the problem.
Automatic transmissions are an enigma to me. I really don't understand them and only do what you guys (Jono) recommend.
I don't want to confuse the topic here with my type F fluid change for the 560SEC.
It seems that the best fluid for our 722.3s are Redline High Temp. or Redline D-4.
Again, all my trannies are on Redline D4 with the exception of the 560SEC.
An extra second or two to engage reverse is a warning, as is any kind of unusual noise as you start moving in reverse. If it does either of those, don't put it in reverse again until you get it fixed. After that happens you can usually keep driving it forward until the cows come home, remember why they left in the first place, and then leave again, as long as it isn't slipping.
Klink, since we're on the subject... what does it mean if you have a slightly delayed reverse engagement (1-2 seconds), along with a whirring noise during the delay? No clicking, no funny noises when the car is actually moving...
:wormhole:
What lube do you use in these trannies?
Well, in my 722.3xx transmissions, I used Red Line D4 or High Temp (which is just a thicker D4).
Not taking the bait on that other tranny... nope... nuh-uh.
:tumble:
:wormhole:
Hell, I don't know for sure. My guess would be some scraping noises from LB3 plates that are missing material. They may make some noises as they are slowing to a stop.
:watchdrama:
Friggen previous owner deferred maintenance plan. My last transmission oil change record was in 2002 at 92,000 miles. Its 2016 now and car has 148,000 miles. Ugh. Time to learn how to change the fluid.
im abit curious about this talk about the F type oil...
is this the Ford spec oil you are talking about?cause we have some Quakerstate F type transmission oil at work ..
Is there any chanse of damaging the transmission?i kinda would like to try this in my 92 500e.(just mentioning it cause the example mentioned was in the 560sec...).if it DOES not harm anything..heh.obviously :)
would be nice to have a "cheaper" alternativ to the Mercedes oil i have in the transmission at the moment.
Yes, Type F is the older Ford fluid. It should not cause any transmission damage on an otherwise healthy transmission.
:tigger:
MaxLife and the Castrol Transmax (which is what I have been using) are readily available, both Dex III compatible and excellent choices. I would not hesitate to use MaxLife, I've just been using Transmax instead. Both are usually side by side on the shelves.
Just change these ATFs at 25K miles and you're golden.
I just performed a transmission flush in my 02 E55 which has the 722.6 using Maxlife ATF which is NAG1 compliant. The last flush was about 2 years / 30,000 miles ago with Shell ATF134. I gotta say that the transmission shifts beautifully with the new fluid and at $17/gallon at Walmart, you really can't go wrong.
The MaxLife should be fine in the 722.6 / NAG1. Just make sure to flush it every 30kmi or so.
:gsxrock:
Had an issue with double engagement on that initial drop in gear cold take off at times using the Castrol Transmax in my 420. It has completely vanished after the last change to Febi brand REAL Dex 3 https://www.fcpeuro.com/products/auto-trans-fluid-0009899203.
"This is a mineral based Automatic Transmission Fluid that meets Dexron II, MB 236.6, 236.7 Specifications. OEM Approval: MB 236.6. 722.3 and 722.4 transmissions should have their fluid changed and filter replaced every 30,000 miles. If this is a service vehicle or one that regularly sees tow duty, the fluid should be replaced every 15,000 miles."
It is time for a transmission service on the W210 wagon (722.6xx) and have a couple quarts of RedLine High-temp on the shelf. I need a couple more quarts and was wondering if it would be OK to mix the High-temp with some RedLine D4?
Or, is that just bad juju???
The D4 is ~7.5 viscosity, the High Temp is ~10 viscosity (@ 100°C, cSt). I'm not sure how the resulting mix with thicker viscosity would affect the shift quality in the 722.6 box. Would be better to use the correct stuff if possible.
BTW, after a fluid/filter change, it doesn't hurt to reset the TCU adaptation and go through the re-learn procedure, although it's a bit of a chore and requires SDS. If you're happy with the shifts before & after, don't worry about it.
:rugby:
I'll ask...
So I see 236.10 fluid superceeding and replaced by .12 fluid and currently 236.14 MB spec. Where does Spec 236.11 fall in the usage? It says to the bottle- it meets Dextron III? Reading Pentosin ATF 1 label.
I use only [FONT=&]0019892103 :)and it works flawlessly...and my trans is super happy :)[/FONT]
001-989-21-03 is the original 236.10 spec and should be ideal for any 722.3 (or 722.6) transmission.
https://bevo.mercedes-benz.com/bevolisten/236.10_en.html
However, I believe this is NLA from Mercedes, at least in USA. It was replaced / superceded to a newer spec fluid (236.14) that is thinner, but "compatible"... at least according to the latest spec sheets. Equivalents to 001-989-21-03 are still available via aftermarket sources.
:hornets:
