Yes, it is possible.
There are several ways to do this:
3) Have the Sultan of Brunei adopt you, he has a few so I am told. You might get lucky and get a SL720 thrown in too.
Kind Regards,
Ron
i have talked to Arrow about cranks, but they are spendy. Like 4k spendy.
I hear that for the first time Jono. I know for a fact that the AMG 6L crank has a 117..... part Number (from the 560 engine) and that only the counterweights are diameter reduced - not more not less.Well, the bearings are two Totally different widths so Creative offset grinding will be required not only to increase stroke but also make the narrow/late 970 bearings ride properly...which is what I hypothesized looking @ the two cranks.
So, yes..you Could use a stock 117 crank but the guy grinding it is going to have to be Damn Good.
jono
I'd love to build a Mean 6.0 w/ some Serious cam...would Really want to take what ever car that was in and run stand alone as tuning LH is a PITA/limited..
jono
Jelmer should make a sticky about this topic, since it seems to come up from n00b's once or twice per year, with the same answers every time...
If it was the 1997 E60 from the West coast, Jeff, one of our members, bought it.
We are still waiting for a report about how it stacks up to his Brabus!
Niibe in Japan bought one of the two NOS motors, and yes, he was disappointed to only get ~315hp (crank) on the dyno with the 5.0 LH module... then he sourced the 6.0L module and boom, 380+hp.Whatever happened to that AMG 6.0L for sale from the Mercedes factory for $10K ? Didn't someone purchase it, and had to source a 6.0L LH module ?
There are at least 2 different casting numbers. However I don't know the difference between them, nor if both will work in an M119 conversion.For posterity sake, I want to source an M117 crank or two.
Do all M117 560 series cars have the same crank?
Any particular year or part number that I have to look for?
Anyone know what the diff is between the 5.6 crank castings?
All my 560 cranks are the same, but I really only chase LATE stuff.
Keep in mind, the bearing width b/w a 117 and a LATE 119 are Way different. You'll need a talented crank guy to work his magic.
jono
Yup, everything I keep is 6/89 or later.
Sent from my XT1585 using Tapatalk
An R129 SL60 engine (M119.972) from a 1993-95 500SL/SL500 (129.067 chassis) is a direct bolt-in to any E500E, although some brackets/etc may need to be swapped around.will a 6.0 m119 engine which was on a sl60 be a direct bolt on or I have to need adjust something for an e500 ltd 94'
...you also need a 6.0L LH module... I have one for sale if the donor engine doesn't include the correct module.
Some info here - short answer = not cheap!!Hi I would like some advice as to the possibility of upgrading my 1991 500e to E60 specification
has anyone done this and if so how and how much did it cost
I can't recall anyone posting details about doing this in the last 20 years, but yes you can absolutely upgrade to a 6.0L engine. The easiest method is to buy a used AMG 6.0L motor, like the one @TimL had for sale recently, and swap that in. Otherwise you can contact tuners like Vath or RENNtech about custom building a 6L, or Blue Ridge MB. Including installation, don't be surprised if the estimates are in the $40k USD range for a turn-key conversion. That's for the engine only.Hi I would like some advice as to the possibility of upgrading my 1991 500e to E60 specification
Also non-engine info here:Some info here - short answer = not cheap!!
Convert e500 to e60 ????? | High-Performance Modifications
Hi everyone ,, I have E500 1994 and I was thinking if it was possible to convert the engine to the 6.0 AMG e60 engine and if yes what are the parts a have to changewww.500eboard.co
Moderator edit - Moved posts to the E60 conversion thread.
