Another discussion topic : electronics in the E500, in general. My background is E.E. so my detailed knowledge of what can fail in semiconductors led me to deactivate what I can. ABS/ASR is not active (you do not need them in SoCal anyway and I do not ski)...the main control unit was replaced @ 460k. Electronics tend to be temperature sensitive (especially to rapid changes). I always switch off AC before I start to avoid power overload and current spikes. Same for the aux fans which suck a lot of juice. Unbelievable within the 13y I have that car I never changed the headlight bulbs. All other bulbs , yes but not those. On the other side I am on my third alternator.
Just curious about other experiences
The other thing that amazes me is the cooling system, I mentioned that already...I drive at least half of the year with the temp gauge at a solid 100C, up to 107C or so when the aux fans kick in. It cost me (apparently) two water pumps but other than that the cooling system is original, hoses and all. Although they might have tested the engine in Death Valley (if you want to see a new unpublished Mercedes, go there..I saw three test convois there over time as I used to go hiking there every two months or so) the cooling system is clearly designed for mid-European 55F weather, not our 90's here.
Speaking of Death Valley : I was there 5 y ago, the only time I ever drove there in August. Don't do that again, the fans were working continuously....when I stopped @ Badwater I was afraid to cut the engine.....
No AC on and it felt like a pizza oven. I made a discovery although : when you approach Badwater (282ft below sea level) you see that for every 100ft of altitude loss you gain 2F in temperature, nearly constant. When I stopped the digital temp gauge below the odometer was stuck @ 127F...the background is that the gauge has obviously an 8bit AD converter ranging from -127F to +127 (2 to the power of 8 is 256)...I was sure it was hotter than 127 but the gauge had maxed out.
I have to write Mercedes Benz to fix that.....
Current mileage 566000, no issues
. More of a habit and sometimes part of growing with Dad telling you that you must switch off the A/C before ignition off or let the engine warm up first before switching on and all that shamozal .. All a Myth really IMO.. But hey, each to their own as they say.
:razz:
