Although I promised myself not to spend as much money on the car this year as I did last year,.
Holy shitsnacks! Just got pricing of all components:
OEM fuel pumps are €248 each, Bosch €180. Coils are €123 each !?
Holy shitsnacks!Hmmm....doesn't sound like a very tasty snack to me. No thanks, I think I'll pass...
Amazon.com has had the best price on fuel pumps; have a US pal order the components on Amazon, and then ship them over![]()
I most likely can't use the offers written at http://www.500eboard.com/forums/showthread.php?2278-Bosch-fuel-pumps-reduced-price, so I'm thinking of ordering via eBay. For example: http://www.ebay.nl/itm/ORIGINAL-BOS...729204025?pt=DE_Autoteile&hash=item51a916f139, if they are original Bosch, that should be OK, right?
Anyone have part numbers of the coils? So I can check eBay for those, as well?
Jelmer, you think those Dutch prices are high?? Come over to Morepay and buy one fuel pump for €530, and that is with 20% discount...
I've purchsed fuel pumps, fuel filter and several other parts from different vendors in the US and got a very kind person to collect the items, repack in one box, and ship it over. Since it is a private package you must not leave any receipts inside. Then you put up a tenth of the cost as a value on the shipping docs to save import tax/VAT, but high enough so the custom just expedite without opening the box. You just have to give them something so it doesn't trigger any inspection.
(...the shitsnack must be some left over from Harry Potter and those strange tasting beans. I'm sure Site Honcho would enjoy a dose with mushroom taste..)
finally decided to try swapping one of the caps from where the misfire was happening. This cap was a 3 months new MB part from a dealer. According to them after they replaced that all problems went away.
So far the final conclusion is: a defective cap was causing the problems .
After ~1 h he found a new VERY interesting error. One rotor (passenger side) doesent work as it should. The spark continues directly into the metal behind it (hope you guys understand what I mean)!!
I did not check/think of the rotor or distributorcaps as a possible cause of failure because they are new and installed last season. But this sounds really reasonable
When I drove in Germany and the engine was nice and hot, it ran smooth as silk. No stumble, no noise, NOTHING. But when I start it now, it's more wobbly than everI need to replace my coils, but can't find the time :-/
What info would you like? I've had this stumbling issue ever since I got the car, two years back. It became slightly worse recently, with the hiccups occurring every few seconds. Felt like a cylinder not firing, which was especially noticeable at idle and revs below 2k when standing still. Everything else had been changed already (wiring, spark plugs, distributor caps+insulation plates, and then some) so this was the only thing that remained.
Well, this and the fuel pumps that were replaced, but since I managed to cruise at 240-260 easily, I didn't feel like I had a lack of power![]()
the only problem with the rotor it has cracks inside of it but could it be the issue (probably because of the hard removed plugs) ?
damaged little bit rotor cap
Roma, first of all relax! I'm sure the guys here will help resolve your issue as it's common, take things one at a time. Don't be disheartened, it's all part of 036 ownership and as you'll see from searching this board, most issues are common and at times it's just basic like Ivan's.
You highlighted the following :
If the cap is visibly cracked then change it. Start with that!
Definitely change the rotors and caps even if you think the contacts are clean. They have done their service for 30k miles.
This is a 2 month old Mercedes OE rotor that made the whole mess with my car. If you look carefully you can see pores,holes, call it whatever you want, in the plastic where the spark was shorting- slightly to the left of the center you will see some black dots. The other side of the plastic crumbled when I poked at it.
So if you cracked something its definitely the first thing to start with.
A few things I learned:
If you do something and all of a sudden your car started acting up, the chances are it is exactly what you did that caused it.
Never throw away old, but working parts immediately in case the new ones are a problem
Replace parts one by one if you can especially electrical stuff so you can go back to what you did last.
If I was a bit smarter I would have suspected the new parts as being a potential issue but I just dismissed them.
I replaced my ignition wires and now all of my ignition system is completely new. Car idles great. I will follow up on this but I am wondering how many of our problems come from coils wires caps rotors or plugs? Looking back I should have just replaced all components on the high voltage side that I was sure were not recently replaced. It's true coils can be measured but I'd still get new ones just in case. If the low voltage side is a problem : EZL etc. it could get expensive but at least these are not wear items.
Roma_500E said:Thats cool !
I am waiting for my rotors and caps , should get them tmrw.
Once I will install caps and rotors my ignition will be pretty much new (updated) like yours ( but I ve already got a new coils ) .
I think it sounds too optimistic, with the .036 anyway something will come up pretty soon
P.S. I hope caps and rotors will fix the issue ...
Haha as long as I'm the only one touching I am less worried
I am wondering if there are improvements to the wire technology in recent years. Seems the Bosch ones I got have silicon insulation and are quite shielded.
The installation instructions however say they should be kept as far from each other as possible which does not seem possible with the m119. I hope they are insulated enough![]()
Congrats, its enormously satisfying to get the engine running smoothly![]()
