Al right guys , it seems all of you solved the issue with the skipping engine but I just got this issue ...
Here is the story.
A week ago car was fine (slightly rough idling that you usually feel by your butt )
I found out that our 500E should have NON resistor spark plugs , so I decided to replace them for OEM (thinking about FURTHER IMPROVEMENT) ...
1. I got the set of the spark plugs. Tried to install them when one of the wires on the back cylinder fell apart (wires appeared to be OEM factory) so that was right time to install a fresh (thought great idea, car will be better.....)
2. Got a set of Bosch wires that I tried to install. The passenger side was a little issue. It was REALLY hard to unplug the old wires so it seems I
damaged little bit rotor cap (heard of little crack).
3. Removed all old wires and installed new wires along with the new spark plugs.
4. Started my 500E and it worked FINE. Test drove it for 40 miles - FINE. Parked it.
5. Morning on the following day .... Stated it fine , drove for an hour when I noticed skipping (not missfire but exactly skipping) at idling but car accelerated fine.
6. Two hours later tried to drive it and was really angry , it started to lose power exactly at the mid range 3000-4500 rpms. At this range a feel sort of the light vibration on the body and apparently losing power ...
Great .......
7. Came back home , parked the car and turned it off.
8.
Started the car right away - it started FINE but right after 30-50 seconds of smooth idling it starts skipping (sort of sneezing when sit close to the exhaust pipe). It also feels like somebody shut of one or two cylinders for super short time and car shudders.... it skips once in 5 - 10 seconds .
I read the whole thread and it seems I got the same problem like Ivan did but the suspicious thing in my case is that I just did work on those parts and then I got an issue cuz before car was fine.
Another things which is weird is that it starts skipping right after 30-50 seconds of smooth idling ... why is it not skipping right away ?
Here is what was changed
Engine harness 10K miles ago (OEM)
Spark plugs 50 miles ago (OEM)
Ignition coil appx. 50K ago (OEM)
Spark plug wires 50 miles ago (Bosch)
P.S. Rotors appear to be good and clean (was replaced about appx. 30K miles ago and I cleaned them just in case).
the only problem with the rotor it has cracks inside of it but could it be the issue (probably because of the hard removed plugs) ?
Did not check that seal (plastic piece between the cap and engine).
I also did not check rotors itself. But I feel it should be something with what I did wires ? plugs ?
Everything is pretty much straight forward (what to do and check) but the only thing messed me up is point #8 ...
Please guys advise me what should I do since you already went through this annoying issue.
I want to do research myself before taking this "spoiled baby" to dealer and I really have to do research before cuz those guys charge $179 per hour and love to tell fairy tales so I should be prepared.
Why 500E is so nasty thing - trying to make it better but instead got new issues ........
