I was able to stop the crank from rotating and then loosened and removed each of the eight bolts, then the mounting plate and then the flywheel itself.
Jerry - just curious how you will get it under the car while on the jack. Did you raise the car more?
At least I didn't get Force-choked for installing the bolts the wrong way....
A/C drain hoses???
Separate & unrelated operation from inside the car, but yes. Upper strut mounts too....
Because the FSM is written for factory trained technicians as a guide, not DIY home mechanics.
Oh, I've never liked Mercedes lack of clear illustrations. The old ETM's were quite good though
That's why I post so many images over on Banzworld when explaining something,
and here as well although Dave does most of the tech stuff here.
Alldata and Mitchell have much better work instructions, though not always correct or complete.
Have a look at a GM FSM, they're just as bad if not worse.
My experience with older and young-timer MBs is that the older manuals were much better. They used to have photo illustrations and better instructions, I would say up to about the period of the 126 and the very early 124. From there, MB started going to more abbreviated instructions, and more line diagrams instead of photos.
Also the manuals are generally translated from German, so sometimes the English and the terminology is off, and this can lead to misunderstanding in the directions.
I have found that just using the manuals and getting familiar with the MB terminology and steps is really the only way to do this effectively. You learn it by doing. As Clarkz said, the manuals assume a certain level of technical proficiency, familiarity and knowledge that would be imparted to mechanics in MB factory training. The good thing is that as a DIYer I will NEVER be close to what a trained factory MB mechanic can do, I have learned quite a lot by working with the manuals and my own experience so that the lack of information in some of the manuals is not a major hindering factor for me. It also helps to have folks like Dave, Clarkz Vader and Jono who have done a lot of these jobs before, and can offer tips and tricks along the way. Often this saves significant time.
What I have found, in terms of my own process and key tenets, is the following:
- Never be in a hurry to get a job done. There will always be things that come up expectedly that you will need to tackle
- Go with your gut. If something you are putting back together doesn't "feel" correct to you, re-check and if needed, re-do it so that it is right
- Use factory parts as generally they fit the best, with select quality aftermarket being OK. This generally comes from experience.
- Prepare for any job properly. What I do is to read and re-read the factory manual and procedures; read the procedure if available on Alldata, and read the forums to see if others have done the job
- Document everything photographically so that you have record of how things go back together (I didn't check my photos when I put the flex disc back on, which Clarkz caught publicly and GSXR caught privately to me)
- Be persistent. If something isn't working, move on to another task if possible, or call it a day and quit until the next day. I had a night in the shop earlier this week when NOTHING and I mean NOTHING went well for me, so I just cut bait, bailed and did some other non-car related stuff. I very rarely have that situation, but I know enough to let it go and start with a fresh mind at a later time
- Having the correct tools is a huge help. This isn't always possible, so having enough other tools that can be adapted to the job also helps tremendously. For example, having a set of "stubby" combination wrenches really helped with the flex disc bolts in the transmission tunnel, and using a "regular" combo wrench would have tripled or quadrupled the effort.
Hope this helps. I'll have more updates and hopefully will be finishing up the transmission job this weekend before I head off to Boston on Monday.....
