Headlight switch panel icon indicator?Anyone know where this little light bulb goes to? Working on removing all the NOS wiring
Looks like there's already a bulb in that locationHeadlight switch panel icon indicator?
AC vents?Looks like there's already a bulb in that location
Oh yeah much simpler with all that removed- found this pic onlineI think all this comes out too - bits circled in red. Can someone confirm. Was going to look at 500 E pics of normal engine bay
From many years ago when I was replacing the upper wiring harness:I think all this comes out too - bits circled in red. Can someone confirm. Was going to look at 500 E pics of normal engine bay
That's part of the NOS system. It's an RPM "window" switch, not related to the glass panes in the doors.
All part of the nitrous kit... if you are selling that, make sure it's complete or the buyer will have a real mess to sort out!I think all this comes out too - bits circled in red. Can someone confirm. Was going to look at 500 E pics of normal engine bay
Thank you!From many years ago when I was replacing the upper wiring harness:
Headlamp switch area illumination?Anyone know where this little light bulb goes to? Working on removing all the NOS wiring
@MY911S,Took a break this morning to check out the FCP Euro car show.
Yes it was. Interesting I wonder what the San Pedro event was. I go there a lot. We used to live there and aren't too far away.@MY911S,
Was that carshow in the Robinson Helicopters parking lot in Torrance.
BTW, I was in San Pedro w/ my wife Saturday and we ran across a huge car show down by the docks across from the yacht harbor. It was breaking up when we discovered it around 3:30 PM.
oh sorry if i caused confusion - that's not my car---it's just a sample video--that shows what to listen to (pump sound that's working)@MY911S,
Carlo, Is the starter turning over the engine? It doesn’t sound like it to me. Maybe my hearing is fooling me but to me it sounds like a dead battery to me. OR are you just turning the key off before the engine turns over?
Yup, that is for the M120 V12, and yes it is for a 1993-95 S600.Anyone know if this is a WOT LH from a S600 date code 92 from a 1993 car. @gsxr
Any M119 V8 LH module can be used for testing, from any year/model with LH-SFI engine management (through 1995 USA model year).Ah I thought I had read in this forum that would still work.
The plastic arrows are just a visual aid to line up the throttle vs transmission linkages (and, this can be tweaked to fine-tune upshifts/downshifts to your personal preference).Car runs but needs adjustment. Idles too high and doesn't shift or super late. Reinstalled another accelerator cable and found this crack in the bracketry.
Nope. That video is for the CIS-E engine, the throttle linkage is COMPLETLEY different vs LH-SFI. Basically nothing in that video applies to the 500E except the little black plastic rectangle he's replacing, which is the same/similar.Hmm I thought the arrows were as explained in this video
Now I think I understand. Those are two separate pieces, you are thinking it is 1 piece broken in half. Move the rearward piece with your finger and it might start to make sense. Those plastic tips should be lined up for the rough adjustment. In the photo, yours look ok, they are lined up within a mm or two? Can't quite tell from the angle of that photo.@gsxr Going back to my picture and the circled area - that black tab that looks to be broken in half is actually not a break? It looks like it. Here's a closeup.
What's the point of switching ignition switch on in step 6 only to switch it back to the off position at the next step
Yeah, something in there is a typo / mistake. With the ignition on, if a second person presses the pedal to the floor (not kickdown), the throttle butterfly should be almost fully open.This must be spelling mistake. WOT must be checked with ignition switched ON.
Phew what a relief. I should have put more faith in German Engineering than to assume that was per designNope. That video is for the CIS-E engine, the throttle linkage is COMPLETLEY different vs LH-SFI. Basically nothing in that video applies to the 500E except the little black plastic rectangle he's replacing, which is the same/similar.
The city light bulb is a T4... more details here.Any recommendations for a replacement bulb for the small Osram bulb next to the H4 in the Euro headlight? I went to the parts store and the Sylvania one that looked to be the same size wouldn't fit. It was slightly large in diameter.
Thank you!The city light bulb is a T4... more details here.
