FYI Old Lamin-X removal
socal210
Active member
Recently purchased a set of used E500 headlights that had old lamin-x film on them. Quite a but of wear and scratched up so I decided to remove them. Here's what is was like
Hard to tell from this picture but the lights looked very hazy and yellow
Old film removed carefully using a heat gun and gently prying it off the lights. Super thick way more than what is used to clear bra cars with. You can also tell this film is older technology by the way the adhesive was splitting from the film.
Easier to tell that it is yellow and faded in this picture.
Old adhesive left behind. I initially started with adhesive remover on a microfiber but this was taking too much time and effort for very slow progress. I ended up spraying some lubrication on the headlights and took a razor to them.
Old adhesive being scraped off. Even the adhesive was yellowed.
Sprayed down. Took multiple passes to get the adhesive off. The tiny remains were taken out with a microfiber dipped in a adhesive remover.
Finished result. The glass underneath the film was in perfect shape. Not pitting at all. These lights definitely had use and miles on them. If it hadn't been for the lamin-x there is no way they would be this nice.
Clean and Clear!
And finally here are the lights installed on my cabriolet. I do plan on putting film on the lights again before I start driving with these lights. The lamin-x did an excellent job of preserving the lights.
I don't know which one is your preferred adhesive remover but this stuff is the bees knees.
It has gently cut through everything I've tried it on. A buddy of mine who does vinyl and clear film suggested it to me.
Thanks for providing the update on the Lamin-X and how it protected your lenses. Definitely did its' job. I would expect that Lamin-X would eventually turn yellowish due to UV exposure and such. That's an awesome testimonial to the fact that Lamin-X works.
I've never put it on my own Euro lamps, but have already added it to one of my lenses, and will be adding it to the other one shortly. I also already added it to the brand-new fog-lamp lenses that are mounted in the front spoiler. I'm going to try to polish out the "old" lenses that I took off, and Lamin-X them as spares if they turn out well.
Again -- thanks !!
P.S. if anyone needs it, I have a brand-new shipment of Lamin-X for sale. More info here.
Another unsolicited suggestion:
These polycarb scrapers are amazing for removing anything that has been adhered to fragile surfaces. Such as glass and paint. And they won't send you to the ER for stitches.
My buddy gave me a handful many years ago, and I've maybe tossed out one since then. The edge hold up very well.
Many, many knockoffs out there, but I trust these specifically. Lidco Chizzler.
Use one of these with the adhesive remover I posted earlier, and the risk of using razor blades will be a thing of the past.
I'm using one right now to replace the tired rubber bumpers on my kitchen cabinets.
EDIT:
No affiliation with any of these products. I found this retailer has both the scrapers and the rapid remover:
Awww, the part number 005-989-17-21 doesn't show up in MB systems, dagnabbit! Wonder where Jeff found that.
My go-to of choice for adhesive remover for over 20 years has been this:
Can't beat it. Also great for stripping wax.
Dan
I used that exact 3M juice to remove duct tape adhesive on my latest project/disaster. Worked VERY well.
:choochoo:
:choochoo:
It's pretty much my Swiss Army knife of solvents. Very volatile, but I like it because it won't harm paint so I know I can use it on a painted surface without concern of damage. Some stuff that's thick, like the glue that holds badges on, will take a while to soften with this, but I usually just soak a rag or shop towel and apply it, replenishing as the material flashes off.
Dan
