... just because they don't like the pricetag.
Exactly!!!and do not understand how it works, how it fails or how to repair it.
IMO, the only valid reason for SLS removal would be on a full-blown race car that gets little if any street use, and that includes wagons too.
I'll never understand why people want to get rid of something that works well, just because they don't like the pricetag. Kinda like buying an old Ferrari, then the engine dies, and rather than fixing it they stick a small block Chevy in there instead. Yeah, it will move the car, but it just ain't the same. Ditto with SLS removal... IMO anyway. Just fix the SLS properly, with new parts it should be good for another 20 years.
I will toss in that you'll pick up some ponies not driving that pump..especially w/ the system under Load..;-) I've found a few HP on the 560's doing as much.
I'd also add that w/ a full set of adjustable Koni's all around you can make the car work quite well on street or track...!
Anyone need some 500 SLS bits..
Jono
Yup, ditch the tandem pump, which if in good shape is worth a few $$;-)
The 16V guys talked about close to 10HP @ full load/under stress, ie heavy cornerning etc.. The cars are still More then comfortable with standard suspension, go for a ride in a lowered E420..
As for the coilovers, The front spring perches were not designed for that much stress, they would need to be Heavily re-enforced to withstand the strain...that said, the ones I've seen retained the stock spring, but also Added a small one on the coil over. Kind of a strange setup.
As for a reason to remove the system that does not have to do with the track...I had one VERY Tired 500E come through here, pushing 300K on the clock..his tandem pump LEAKED, the proprtioning valve was weeping, one of the rear rams was getting wet w/ oil, and Both lower ram ball joints were Toast. This was an instance were swapping out to non SLS would be OK, this car will never be Spectacular..it's just been Used. And instead of driving it around half in the bag you could put a Very nice standard system in place and not have the worry of $$$ repairs again in the future. Ideal, eh..but real world Workable, absolutely.
Front suspension doesn't need to be fiddled with so much..but I Would recommend to anyone doing this swap go ahead and drop a set of V8 124 H&R's/Eibachs in to round out the setup.
Jono
Was checking up on M119 Power Steering Pumps. Found one which is not for models with self-leveling or ASD auto locking differential.
Do 500 have ASD auto locking differential?
Well i never saw any used rear SLS Struts for the 500E anywhere. Also, the Struts normally last forever, only rarely heard of any leaks or other breakdowns - mostly its the lower rubber bushings that tend to get worn-out and which produces the well known knocking sound from the back.
New price for them was like 370€ from Sachs per piece and ~60€ for the "bulls balls" in the trunk (the actual damper) per piece.
Yes thats exactly what the lower rubber bushing causes normally - the "Poltergeräusch" or "Knocking sound". What else should cause this in a shock absorber?poltergeräusch hinten beheben
stossdampfer ausgeschlagen, ersetzen
Hei Dan.
The 500s don't have any diff.lock like ASD. They have ASR, which is a electronic system with ignition/fuel cut-off (?) so the engine reduces the power to prevent uncontrolled wheel spin (...which is the fun part sometimes ;-))
But I don't know whether the ASR also engages the rear brakes to even out the traction between the rear wheels. Anyone here to confirm/disclaim that?
Factory docs with details on ASR operation are at these links:AFAIK the 500 has two ways of keeping the wheels from spinning: below 40km/h it does something fancy with pressure and whatnot, and above it simply cuts out the engine. Anyone have more details about that?
Yes arnt, uncontrolled spin you say, it shuts down power and if that isn't enough it starts to brake the wheel thats trying to break loose, safety first but as you say, if you want fun and control that spin yourself, you have to go the E420 way and be the master of power w your right foot,,Roger
Mind you I'd say half of the servicemanual, 124 036 500E, is about the ASR system,,,,,
If you delete the pivot rod from the self-leveling unit, is modification to the stabilisator torsion bar (1243262565) then required?
Sorry, I missed this post!
I'm running the Koni Adjustables and I like them Very much..! They do "crank up" nicely and on the softer setting they are Quite comfortable. I had an E420 Slammed on H&R's 1 nib shims and 18' brabus w/ Bilstein Sports and PS2's...that was a bit on the firm side, but that was the idea..30 series profile tyres didn't help things much!
So if you like to dual use the car, konis would be a Great way to go!
jono
Yellows...I haven't seen reds in an age!
Another question, are they adjustable both at front and rear?Sorry, I missed this post!
jono
It's the same for all w124
8741-1092S (rear) 26-1198S (front)
I'm using Koni at the front - Just reailazed that the rear ones is half-price of the front
Here is a cheap place to buy them in Denmark (even cheaper than in Germany):
http://www.refako.dk/index.php?cPath=89_890000987_890001026_890001027&tPath=85
Keep in mind that KONI only allows rebound damping adjustment. The compression damping is not adjustable unless you have them custom modified.
Found this on the net: When you first fit Koni Sport shocks, you drive your car about 300 Kilometers with the softest adjustment. After completing these 300 kilometers, you go for a second adjustment and let your Koni Sport shocks adjusted exactly as you like.
Having the ability of adjusting the stiffness of your suspension shocks 'to a level that you exactly like' is a pleasant feature. In fact you can adjust all 4 shocks separately for a precise balance.
8741 (front) can be adjusted directly on the car 3 clicks, 26 Series range limited to 2 clicks and need to be unmounted (rear)
http://www.koni.com/193.html
I'm considering to try the rear once just making a loop on the pipes from the tandem pump, if I'm happy with the result, then switch the pump later on.
Jono, just curious, were you using KONI Reds or Yellows? I've heard the Reds are NLA now.
That is not the part number of the strut. Is the part number of the dust boot, which is not available separately....he part number on the old struts was A2013260192 I checked the number on EPC and it was unknown...
Nicely done..and it does ride well, doesn't it..
Just a FWIW, but the fender wells in these cars clean up Very nicely w/ a power washer and a quick wipe down.
