Installation of rear Koni's
Test Drive: I'm actual very happy with the results, the car has much more feeling with the road and it's actual still comfortable.
So I'm planning deleting the SLS, installing a 400E/500SEL pump and remove the old pipes.
Hi Dan.
So, then you are almost done with the SLS-delete, looks OK.
How is your camber with that low ride height at rear?
Are you sure about deleting the hydraulic tubes all the way from the SLS-valve to the pump and oil reservoir? I think you have to cut them apart to get them off, which means you get a comprehensive job if you or a future new owner reconsider to add the SLS function again. I will leave those pipes oil filled and blinded on the car. The threads on the fittings on the supply and return lines are M12x1, which is not so common to find blind plugs for. So one option is to leave the SLS-valve in place connected to the tubes, but with plugged ports to the struts, they are M10x1. Instead of the copper washer plug type, you get plugs with conical sealing face inside if wanted.
Cheers
(BTW, I have decided to go for Bilstein B8. Will be done during the winter hibernation.)
