Transmission Vac Lines - I have 3?
jaymanek
Hi All,
My transmission has three vac hoses.
On all diagrams I can find on here and also on the EPC, there are two listed. One which goes directly to manifold and one to the firewall valve.
I have a third pipe on the right side of the transmission.
Anyone come across this? Im guessing this transmission may have come from another model.
I have it disconnected at present and shifts seem fine...
Jay, for Euro-spec cars, there may be 3 vacuum hoses:
1) Vacuum modulator (left/driver side)
2) Cold-upshift delay (right side, at control pressure cable)
3) E/S shift selector (right side, at control pressure cable, Euro-spec vehicles only)
#2 and #3 can both be disconnected & plugged with no ill effects, on a Euro car. It will remain in "S" mode at all times, same as USA-spec cars.
:strawberry:
Ah yes... the USA-spec cars sometimes have the "worldwide" control pressure cable, with the extra port blocked off. If you don't have the E/S switch in the wagon to connect to the third port, just don't worry about it!
Ах, да... в автомобилях для США иногда есть "всемирный" контрольный напорный трос с заблокированным внешним портом. Если у вас в вагоне нет переключателя E/S для подключения к третьему порту, не беспокойтесь об этом!
:джоно:
