What to do while there ..see pic
Ertech
Hi guys
Replacing S hose , and all Ps hose/ sls , front engine seal ,rebuilding tandem pump, engine mounts , water pump and a/c good . What would you do while there with all front part of engine accessible ?
So the long hose under the frame rail while the engine is jacked up before you place in the mounts. Transmission mount too!
Yea, perhaps gsxr will post the pic but this is the best time to refresh that hose without removing the engine. Access is best now.
Hi guys
While you’re in there, I’d just follow this thread as a guide. you can get it done over the winter.
:thumbsup2:
if the water pump is coming off, it’s pretty much incremental labor to replace
The front crank seal.
I’d check for oil leaks at the cam seals and solenoids. And replace all soft parts and rubber. Is your ETA original?
