The $400 400E
Now I just need to get the car aligned. @gsxr Dave is there a shop in town you recommend for alignment work on our cars?
Lyle Pearson is still my #1 choice, but they may be scheduling 1-2 months out. Last alignment I had there was summer 2021 and it was $200 (gulp). They've always gotten it done properly though, and will provide the printout afterwards on request. I'm not sure where else to go.
Fortunately I'm not in a big hurry. $200 isn't too bad I guess these days. It cost me $130 to get an alignment done on my wife's Prius a few months ago at a regular tire shop. $200 for a dealer alignment on a Mercedes seems reasonable. I'll see if I can get it scheduled.
Only 1 week! Awesome! Price up to $260... less awesome. Guess they need to pay for the burned-out shop (fire damage a few months ago still being repaired).
Fate heard me breathe a sigh if relief over the fact the car was running perfectly, and it has now developed a misfire at idle. Guess I know what I'll be doing after work.
Nuts! Are the caps original? Wires? Etc...
No, it's all been replaced at some point. I did pull it all apart and media blast the contacts and slot the caps right after I bought the car. Haven't looked at them in probably 6 months at this point though. That's first thing on the list to look at this afternoon.
I forget - do you have SDS? If so, live EZL data will tell you which specific cylinders are at fault.
I do not. Might be something I need to consider. Whats the best option for SDS without spending a fortune?
@Jlaa posted some info on the forum within the past year or so. Seems the current recommendation is a C4 system that is absolutely confirmed to include HHT-Win, and also has a 38-pin cable with all 38 conductors. Likely $600-$800 or so all-in with laptop, MUX, cables, and software.
Yeah, that's kind of what I suspected. Probably more than I want to spend for basic diagnostic equipment at the moment.
The blink code reader is basic diagnostic equipment.
SDS is advanced diagnostics and will support most all MB's through at least the late teens, if not early 2020's.
Fair point. Still more than I want to spend right now though. We'll see what a visual inspection reveals.
I swapped in a set of basically brand new Bremi caps and rotors from my S500. No change. It's actually getting worse pretty quickly. It only happens after the car is fully warmed up. There are no codes on any module.
I first noticed an occasional little miss this weekend on the same drive that confirmed that the overload switch issue was fixed. That was, of course, immediately after I installed the S500 EZL. In the past couple days it has been getting worse.
At this point my best guesses are either the EZL, or a coil on its way out. The plug wires are Bremi and are pretty recent and appear to be in good shape. The plugs are basically new. Less than 2000 miles on them. I do have a pair of coils from a 95 E420, as well as the pair in my 95 S500 I can try. I'm all out of EZLs at this point though. Anything else worth checking?
I could ask the dealer to diagnose it while it's in for the alignment on Monday, but I fear what they might charge for it.
Swap parts around for grins, since you have them available. Is the misfire only at idle, and clears up when driving? I assume zero fault codes. Measure plug boot resistance for grins.
I'm not sure if the dealer would have any tech capable of diagnosing LH-SFI, and the cost would be astronomical. You'd be far better off investing the several hundred claims into an SDS C4 kit.
It's most obvious at idle. It may be occurring at higher RPMs, but it's hard to say. It's not very noticeable if so.
OK - it's probably at idle only. If there's a misfire under load when driving, it's a pretty noticeable loss of power.
I THINK I noticed a decrease in power, but I do not notice any roughness above maybe 1200 RPMs. Hard to say for sure if it's actually down on power, or if it's just my imagination though.
I'll swap in a different set of coils and see what happens.
I swapped the original 92 400E EZL back in and the misfire remains. That's actually a huge relief. That tells me that the misfire is probably completely unrelated to the EZL swap I had done. I'll reinstall the S500 EZL, and then start measuring plug wire resistance. I can't think of what else it might be.
Interesting. All 8 cylinders' wires were between 1.849 and 2.012 k ohms. Both coil wires were zero ohms, full continuity. I expected some resistance on the coil wires, but there is none.
Regardless, none of that suggests an issue there.
Anyone have any other ideas?
If the wires check out ok and there was no change with different coils or EZL...
sounds like you are down to a cap or rotor, or (less likely) a spark plug issue.
Wow. This is interesting. Were any of the NGK plugs fouled? Can you measure resistance of the NGK plugs? Resistor plugs are not correct for LH engines, but also typically don't cause a misfire. The MB plugs you installed are non-resistor Beru and 1.0mm gap is perfect.
On the bright side, it's great news you fixed the problem!
:yayo:
None are fouled. They all measure between 3.5 k and 5.2 k ohms, except one, which has no continuity. I'd say that was probably my problem.
Yep - that one was likely the root cause. There have been reports for many years about counterfeit NGK plugs but I assumed that was mostly the more expensive ones. Where did you buy these NGK's? Was it a large vendor like FCP, RME, AHAZ or a no-name seller on eBay/Amazon/etc?
Pretty sure they came from RockAuto.
It's been a little while since I checked in. The last few weeks of the build have mostly involved interior work again. I tracked down some decent burl wood trim, and a center console storage compartment with a good burl roll top. Got those installed.
Then I dove into one of the bigger cosmetic jobs on this car. The leather seats are in ok condition, but not great. They're very stiff, and there is some cracking and wear, especially on the driver's seat. There has also been a dog in the back seat at some point and there are numerous scratches and some minor punctures as a result.
I've been trying to decide for a long time exactly how I wanted to deal with this. The leather is not beyond saving. I finally committed to a plan, and I'm almost done. I'm happy to say the results are very impressive.
The plan involves a restoration kit from ColorPlus.com. I have no affiliation with ColorPlus. I paid full price for the materials and did all the work myself.
Here's a link to the kit I used:
The kit includes a cleaning solution, a moisturizing/softening conditioner, and dye. The kit came with a quart of each. One really nice thing about this kit is that they custom match the color of whatever you're working on.
I sent them a sample of MB tex that nicely matches my interior, and in just a few days they shipped out a custom tinted kit.
I mostly followed the instructions with the kit, but did a few things a little differently as well. Unfortunately I didn't really take pictures along the way. I guess since this was my first time doing this I didn't feel too qualified to offer a how-to. I do kind of regret that now, because it was somewhat easier than I expected.
I started by removing all the seats from the car, as well as all the head rests and the steering wheel, and then removed all plastic trim pieces, arm rests, etc that prevent access to all the leather surfaces.
I mixed up the cleaning solution provided with the kit and gave everything a thorough wipe down to get the top layers of grime and funk.
Next, I used a drill brush to scrub the crap out of everything with the cleaning solution. This was messy, but did get a lot of funk off.
Drill brush kit:
Next, I rinsed everything thoroughly with clean water, and then dried it. I then allowed it to sit and dry out for 24 hours before moving on to the next step.
This entire process was done in my garage, but I have had the heat on to keep the temperature around 72 degrees the whole time, day and night. I'm sure my power bill will be shocking.
Once the seats were clean and dry, I started sanding. I used an orbital palm sander and 320 grit paper to sand every surface of the seats. Obviously you need to be careful on edges not to burn through. The goal is just to scuff the leather to the point that the conditioner can permeate the hide. Definitely don't sand to the point of breaking down leather fibers.
Once the sanding was complete, it was another round of cleaning, rinsing, drying, and then waiting 24 hours for everything to be fully dry.
Next, I applied the leather conditioner to everything. My leather was very dry, especially on surfaces that faced direct sunlight. The rear head rests were hard as a rock and would have easily cracked if I pushed on them hard. I knew they would be a challenge.
Over the course of a week, I applied and reapplied the conditioner to the leather. Basically, you let the conditioner soak in until the leather stops absorbing it. Really dry areas might soak up the conditioner in just a few minutes or hours. I'd check every few hours and reapply to any areas that were no longer wet. Most of the leather stopped absorbing the conditioner after a day or two. The front seat bases took nearly a week. The rear headrests and steering wheel took so many applications that I eventually used up the entire quart of conditioner and they were still thirsty. They are much softer now, but honestly I think they could use even more, so I have another pint of the conditioner on the way. When it arrived, I'll continue on with conditioning the head rests and steering wheel until they stop absorbing it.
Satisfied that everything else was fully rejuvenated, I went about cleaning the residual conditioner off the seats. I again used the cleanser from the kit. This took several rounds of cleaning, each time with new fresh rags, to get all the residue off. Then it was another round of rinsing and drying for 24 hours.
Next up was repairs. There were a couple punctures that were bad enough to require patching. Fortunately, they were in inconspicuous places, like the side of the rear seat back, and the map pocket on the back of the driver's seat.
To close the tears, I cut a piece of MB tex large enough to support the back side of each tear, then I carefully inserted it behind the leather. I then used thick cyanoacrylate glue to glue the leather down to the vinyl.
Once dried, I sanded to knock down high spots, and then started filling the low spots in the tears, as well as any scratches, cracks, or worn areas. For filler I used this stuff:
The basic strategy with the filler is to apply a little, let it dry, then then sand it smooth. A few tips though. First, apply just a little bit at a time. I used a toothpick to apply it . The best plan is to apply just a little bit into low spots, and don't necessarily try to fully fill it in a single shot. It you use too much you'll have two problems. First. It will take much longer to dry, and the thickest part might not be dried by the time you start sanding, which will make a mess when it starts to smear. The bigger issue is sanding.
To sand the filler, I again used the orbital palm sander with 320 grit. The most important thing here is to apply basically zero pressure. If you apply any pressure, the sander will press down on the high spot and depress it so you're sanding across a wider area. When you lift the sander you'll have a bump left because the filled section springs back. What you need to do is basically hover the sander above the repair and let the paper only contact the filler you're trying to shape. It takes some patience, but in the end the repair will be invisible.
Keep in mind that you don't want to spread filler into perforations in the leather. Anywhere where I had cracks or scratches in perforated sections, I carefully applied the filler to just the damage between the perforations.
After a few rounds of filling and sanding, the leather was ready for color.
The last step before color is to blow evrrything off with conpressed air, and then wipe everything down with quick-drying lacquer thinner. The compressed air will also help to clear out debris from perforations, and the lacquer thinner will get any remaining grease or dirt off, and will chemically soften the old finish, which helps the new color bond to it.
The color can be sprayed, but I was not confident that I'd have enough of the color to get full coverage after accounting for losses due to overspray. In the end I don't think that would have been an issue. The manufacturer states the product can be thinned by 10% with water before spraying. I suspect that would have worked fine, but it also would have required more masking and prep work. I elected to brush the product on instead.
Applying the color is fairly straightforward, but I learned along the way that the product actually dries very quickly, so you need a good strategy to get full coverage without texture issues.
You do not want to fully saturate the brush and glop the product on. Especially on perforated sections. Instead, you want to prime the brush and then spread the excess off on a pallet, and lightly brush over the leather. Several light coats are the goal. Use a very high quality, fine, soft bristle paint brush. You do not want visible brush marks.
After several thin coats, things are looking very good. You will inevitably end up plugging some of the perforations with dye, so next step after the dye dries is to go after the perforations with a toothpick to clear them all out. It will take forever, but is necessary.
Once that's done, rub everything down with 800 grit scotch brite to even out the sheen.
It's a ton of work, but it's looking great.
Nice job! Owner JC220 documented a similar recondition job and had similar great results. I'm not sure we here in the states can get the products he used so nice to get a review of products here in the states. Lots of work.
Forgot to ask - how did the alignment go?
Everything went well. The front camber ran out or adjustment before it could be brought fully to factory spec, but they told me that's pretty normal for lowered cars. They got it as close as they could, and it's not far off. Everything else was able to be adjusted perfectly. I'm definitely happy with the outcome. It drives nicely.
Spotted this in the parking lot of a local grocery store. The snow indicates it probably hasn't moved in many days. Tags are a year expired. Can't help but wonder why it's been there so long.
Wish I knew how to contact the owner. Maybe it's an opportunity for another cheap project car.
It had 200kmi back in 2011... wonder what it's at now! Last registered Feb-2021. No options:
WDBEA34E9SC186180
Edit - 229kmi in Dec 2022:
Ok, so curiosity got the better of me. I went to the DMV and got a vehicle title record report. I have the name and address of the last owner. Dude is 81 years old and has owned the car since at least 2010. Internet sleuthing shows he moved from California to Idaho in 2010, so he likely owned the car before that. I do not have a phone number for the guy, so I have yet to be able to talk to him. I've sent a message to him on Facebook. We'll see if he responds.
Looked at the car a little more closely today. The interior is kind of a mess. The back seat is completely missing and the driver's seat is badly torn. It doesn't look like the car of an 81 year old long-time owner. If I had to guess, I'd say he sold the car at some point in the last couple years and the new owners never transfered the title. Then they likely had problems with it and just abandoned it.
A friend of mine told me today the car has been sitting there at least a month, so I think it's safe to call it abandoned.
It's no more than a parts car given the condition and what we know of its mileage history. Even so, it's abandoned, so if I can figure out a way to legally make it mine it should be a cheap source of parts.
Wow! This is interesting. How would you go about obtaining legal ownership for an abandoned vehicle? If possible, that would be fantastic for a parts car (or, another Beater project).
:yahoo:
:yahoo:
There are two options I can think of.
First, try to get in touch with the last titled owners. I figure I'll write a letter and mail it. Old people like snail mail. The state says these people are the owners of the vehicle. Either they are aware of that and they or their kin have abandoned the car, or they thought they sold the car to someone else, but that person never transfered the title, so they still own it despite the prior "sale."
In either case, if the grocery store decides to have the car towed, the towing company will put a lien on the car and will likely come after the last titled owner for towing and storage fees. Ask me how I know.
That being the case, they should have incentive to get the vehicle out of their name. So I plan to explain all of this in a letter and see if they reach out to me to make something happen.
The second option would be to work with a towing company. A towing company can take possession of an abandoned vehicle, and place a storage lien on the title. After a period of time, legal ownership of the vehicle will transfer to the towing company, at which time I could purchase the vehicle from them. I know a guy who knows a guy who would likely be willing to do the paperwork on that, but the store that owns the parking lot where the car is parked would have to approve of the tow. Odds are they already have a contract with another company for that, so this path is not super likely to work out.
There is another path, which is to send a CERTIFIED letter to the last titled owner. If the letter is returned unopened, the state will take that as a sign that the owner has no interest in the vehicle and will issue a provisional bonded title. There are multiple problems with that though. I couldn't legally take possession of the vehicle until I had the provisional title, so it would just be sitting in the parking lot all that time waiting to be impounded. It would also be possible for the other owner to come back into the picture and take the vehicle back within a certain period following the issuance of the provisional title.
So yeah, many options, but none that are simple. Admittedly, my interest at this point has as much to do with seeing if I can overcome the challenge of procuring the car as anything.
I have an appointment Friday to get my windows tinted. I haven't decided on the shade yet though. Since it's a white car, I think 20% would probably look too dark. Trying to decide between 35% and 50%.
I've never done 50% on a car before. I worry that it might be so light that it's not even worth doing. Trying to find the best balance between heat rejection/privacy and appearance. I don't think a car like this looks good with super dark tint. Although my car does have several aftermarket changes, I like the fact that to the casual observer it looks pretty stock. Murdering out the windows would detract from that.
Would 35% look appropriate, and still somewhat subtle for this car, or should I stick with 50%?
50% is LIGHT, and almost not worth it.
However, I'm not a good reference point... my standard tint is 5% on the rear doors/window and visor strip, and 20% on the front doors. I prefer 5% all around but my wife doesn't like 5% on the front doors at night.
Anyway - I'd recommend 35% or darker. If you want to minimize interference with your Fuzzbuster®, get a dye-based, non-metallized film, at least for the visor strip and maybe rear window also if there's a rear antenna, like on V1 or the new Passport. I prefer 3M ColorStable, available at AutoShades in Caldwell. The V-1 lives above the mirror, behind the tint:
I don't plan on any kind of radar detector, so that's not a concern. 5% is crazy dark! I have 20% on my truck, but it's a darker shade of metallic red, so I think it works fine. I worry that the contrast between the white paint and dark windows would make it look darker than it really is. I actually do want some visibility from outside in.
We'll count Dave's vote as 35%.
Stupid car. The hot idle misfire is back.
The only NEW parts in the ignition system are the plugs. Everything else looks very good, but none of it is OE and none of it is brand new. I'm considering going through and replacing other components with new.
Any thoughts on exactly what to buy? Is everything available new from MB? If not what are the best options available?
Should I start with caps and rotors, or wires, or...? Should insulators just be replaced, or can they be reliably tested/inspected? What about coils?
I have multiple sets of everything, and I have swapped everything out, but I can't say for sure that I don't have multiple bad examples of any parts.
Is there anything else that would cause a hot idle misfire? LH module? EZL?
Aren’t you planning to fit a 5 liter engine anyway? Why don’t you aim the new MB parts cannon at the 5 liter and call it good? Bunch of things not available from MB anymore (ignition wires, EZL, LH modules) but they can be found as NOS items, so if you go through the hassle of finding these, you might want to throw these parts at the final engine and not the current stop gap engine…
Yes, that's the plan. The way I figure though, most of the ignition parts would be swapped over to the 5.0 anyway, and I'd really hate to have to troubleshoot this issue on a new, unknown engine. I'd rather have the ignition system sorted first, and then just transfer it over. I'm already using the 5.0 EZL, and I have two 5.0 LH modules I could test with. I suspect the issue is with the caps/rotors/wires though.
