I know you mentioned that you have fairly newish Bremi wires …. Is it possible that your hot idle misfire can be observed as a spark plug wire grounding out through the insulation to the block ….when it is dark …. like at night time?Stupid car. The hot idle misfire is back.
The only NEW parts in the ignition system are the plugs. Everything else looks very good, but none of it is OE and none of it is brand new. I'm considering going through and replacing other components with new.
Any thoughts on exactly what to buy? Is everything available new from MB? If not what are the best options available?
Should I start with caps and rotors, or wires, or...? Should insulators just be replaced, or can they be reliably tested/inspected? What about coils?
I have multiple sets of everything, and I have swapped everything out, but I can't say for sure that I don't have multiple bad examples of any parts.
Is there anything else that would cause a hot idle misfire? LH module? EZL?
It's a good thought. I actually checked that. Granted, that was before I changed the plugs, so the wires have been pulled and re-installed since then. Wouldn't hurt to check again.I know you mentioned that you have fairly newish Bremi wires …. Is it possible that your hot idle misfire can be observed as a spark plug wire grounding out through the insulation to the block ….when it is dark …. like at night time?
I vaguely remember @dionphaneuf chasing after an elusive hot idle misfire for a long time. We even put my SDS HHTWIN setup on the car w inconclusive results …. But I think he eventually found that his wires were grounding out by observing at nighttime.
Yeah, I mean, you thought changing plugs from NGK to MB Berus solved the problem …. Until the problem wasn’t solved …. But you had to have moved the wires along the way…..It's a good thought. I actually checked that. Granted, that was before I changed the plugs, so the wires have been pulled and re-installed since then. Wouldn't hurt to check again.
Right. It's weird though. The issue did go away for a couple weeks, and I did find a plug that tested bad. Not saying that proves or disproves anything. Just weird.Yeah, I mean, you thought changing plugs from NGK to MB Berus solved the problem …. Until the problem wasn’t solved …. But you had to have moved the wires along the way…..
No, it's hard to justify the expense for one problem on one car. It would be one thing if I had a fleet of Mercedes that needed work, but this is the only Mercedes I have, so I'm hoping to work this out without spending double the purchase price of the car on a diagnostic tool I'll only use once.Did you ever get your hands on a working copy of SDS? Dave’s reminded me many times that the ignition voltages on each cylinder can be monitored. Pretty handy to diagnose which cylinders are giving you problems. Will help understand if its consistently one cap that is iffy for example.
It's extremely noticeable and consistent sitting at a red light. Hot idling in gear it shakes the whole car. It's not 100% consistent, but it's there probably 70-80% of the time. I think it goes away at higher RPM, but I'm not certain. I have noticed a little hiccup here or there at higher RPMs, but I don't notice it very often and can't say for sure that it's the same thing.Can we back up a bit - how severe is the hot misfire? Is it continuous when hot, or intermittent? Only at idle, or does it go away at higher RPM? Does it occur every time the car reaches operating temp? Is it persistent, i.e. never goes away at operating temp? Etc.
Are you referencing this kind of "420"? Hopefully not.....offer $420 for it.
Actually I'm referencing the fact that the price I've paid for all my Mercedes cars in the last year has been the same as the model. I paid $300 for a 300E, $400 for the 400E, and $500 for the S500. So logically, the price for an E420 must be $420.Are you referencing this kind of "420"? Hopefully not.....
Have you installed the new engine mounts yet?It's extremely noticeable and consistent sitting at a red light. Hot idling in gear it shakes the whole car. It's not 100% consistent, but it's there probably 70-80% of the time. I think it goes away at higher RPM, but I'm not certain. I have noticed a little hiccup here or there at higher RPMs, but I don't notice it very often and can't say for sure that it's the same thing.
Yes, engine mounts have less than 2000 miles on them. It's definitely a misfire.Have you installed the new engine mounts yet?
I have not purchased new yet. I have two sets, one from the 400E and one from the S500. I've tried them both, but not AFTER replacing the plugs seemed to have resolved things. Also, there is of course no guarantee I didn't have problems with both sets.I will never claim to be an electrical guru, but I am of the opinion that MANY of these issues are the result of the insulators. I have various old ones (hoping to find someone to lead the way to a nonconductor chemical/epoxy one day) on the shelf that look good but are not. I would spring for new ones if you have not already.
Definitely check this closely. If the cam seal is totally dry, it's 99.44% likely the source is the cam solenoid - either from the flange sealing surface, or from the joint between the halves of the metal shells (likely from the electrical connector rectangle opening). The bolts all need to be coated in anaerobic sealant as well.It's also possible that this could be related to oil leakage. I know I have a valve cover gasket leak at the front of the passenger side valve cover. At one point I did see oil seeping into the bottom of the left distributor cap. The cam seal was totally dry and I don't think it was coming from the cam solenoid.
I will. I already ordered up the rivets to do this job proactively on my 5.0. Maybe I'll go ahead and do those now and then just install them on the 4.2 for now. I really should just do the damn valve cover gaskets too. I've been resisting since the motor will be coming out in the near future. I guess I could yank the aluminum cam oiler tubes and swap in a set of plastic at the same time so I have the aluminum tubes available for the 5.0. It's that stupid valve cover gasket that stopped me from running the car at Firebird at the end of the year.Definitely check this closely. If the cam seal is totally dry, it's 99.44% likely the source is the cam solenoid - either from the flange sealing surface, or from the joint between the halves of the metal shells (likely from the electrical connector rectangle opening). The bolts all need to be coated in anaerobic sealant as well.
I'm about to replace the cam solenoids on one of my cars as I'm tired of the oil leak, and I'm too lazy for the budget repair shown here. I do want to try the budget repair on the old ones so I can swap them on to the next engine, and so on... have multiple M119's with the same leaky solenoids, in varying degrees of severity.
It may be too late, being Friday, but here is a picture of 35% in average light. I'm very happy with it. Had the same concern about being too dark.I have an appointment Friday to get my windows tinted. I haven't decided on the shade yet though. Since it's a white car, I think 20% would probably look too dark. Trying to decide between 35% and 50%.
I've never done 50% on a car before. I worry that it might be so light that it's not even worth doing. Trying to find the best balance between heat rejection/privacy and appearance. I don't think a car like this looks good with super dark tint. Although my car does have several aftermarket changes, I like the fact that to the casual observer it looks pretty stock. Murdering out the windows would detract from that.
Would 35% look appropriate, and still somewhat subtle for this car, or should I stick with 50%?
Not too late actually. I'm just getting ready to head out the door now. That looks perfect! That's exactly what I want. Thanks for posting this. I'm going to do 35%.It may be too late, being Friday, but here is a picture of 35% in average light. I'm very happy with it. Had the same concern about being too dark.
My tint looks similar to 35% but I’m not sure since it came with the purchase.It may be too late, being Friday, but here is a picture of 35% in average light. I'm very happy with it. Had the same concern about being too dark.
This guy only uses top quality ceramic tint. We talked in advance and I removed the door panels and 3rd brake light myself so he doesn't have to take the risk with removing them. $400 total cost.There's nothing on my invoice that would remind me of the type of film however I remember it was a great product that was claimed to reject nearly all the solar energy. The cost to do all windows was $450.
I think it depends on the intended level of power increase. At moderate levels, this may not be needed, and might come with some risk (of screwing it up).I don't know if I'll ever add a power adder, but I kind of want to prepare for the possibility. So should I open up the ring gap before I put this motor back together?
I'm glad you realize this. Installing the power adder is the easy part. Making in run & drive well is exponentially more difficult, particularly if you want it to drive anything like the factory produced it. I've seen a couple of remote-mount M119 turbo setups but there was never any useful information available, and I have a feeling lag may be unacceptable for normal street driving.Looking down the road, I know I will eventually want to make this car faster than the stock 5 liter will be able to take it. I've already been thinking of a manual transmission swap. Not for actual performance. Just for the fun of rowing my own gears and the cool factor of a v8 stick shift w124. Beyond that, I'm thinking that maybe forced induction might be in my future.
I don't know if I'll ever actually do it. It's one thing to slap a turbo on it. It's another to actually make it run and drive well.
Nitrous is the easiest to implement, and a couple decades ago a company produced a kit for the M119/W124. A number of these have been installed with no reports of major failure. It's a dry setup based on a Mustang 5.0 kit, and will be limited by fuel supply / injector rate. This should be good for up to +150hp, maybe more.Nitrous would be a potentially simpler option, but not my first choice.
Koenig Specials and Albrex both made M119 kits back in the day (I think Koenig used the Albrex kit and put the Koenig name on it?). But as you noted, even with the kit parts, there's a ton of fabrication needed. And, the drive belt setup likely would not clear your electric fan.I think my preference would be a supercharger. I don't know of anyone who makes kits for this application any more, so a generic centrifugal supercharger and plenty of fabrication, machining, and custom tuning would be in order. Again, I probably won't ever pull the trigger on it. I just know I might want to go faster than a stock 5 liter.
This depends what you are looking for. Better performance numbers only? Nitrous will have the best ROI. Want a ton of midrange, part-throttle torque? That will need displacement or forced induction. Etc. Also depends how much more you want. 400-450hp is within reach. 500-600 or more will require more briefcases of unmarked bills, then you have to worry about breaking drivetrain components downstream... the snowball effect will be a problem.So I guess there are two questions.
First, what other options are there to go faster? The 5 liter, 3.06 gears, CLK wheels, WOT LH module, and lighter 400E chassis should make this car faster than any stock 500E. What more can be done?
Part of the 6.0 cost is the block machining/boring/etching. If you could locate a M117 5.6L crankshaft, you could try to build a 5.6L... need the crank, some machining/mods, and custom pistons. But, you leave the block alone and can use stock head gaskets. Also, the cost of forced induction could be steep as well...I know a 6.0 build is unreasonably expensive. I'd LS swap it before I'd spend that kind of money on such relatively small gains.
I'd lean towards leaving the ring gaps alone. But first, check the FSM for factory gap specs. I have no idea what they are. Also, the first thing I would do is send an email to Total Seal and inquire if you can get a set of gapless rings for the M119. Remember that you are dealing with an Alusil etched aluminum bore, NOT iron sleeves. More info on the bore is in this document.If the only option for a reasonable increase in power is forced induction, should I just open up my ring gaps now? It won't be the end of the world to have larger than necessary ring gaps, but it can result in a minor reduction in compression, and potentially a small amount of oil consumption.
Or am I better off just committing to leaving is naturally aspirated and leaving the ring gaps alone?
Wiseco is largely dealing with domestic engines with iron bores, or sleeves. I don't know if the numbers they published are applicable to an Alusil application. If I'm reading the FSM correctly (03-3170), the Wiseco "recommended" gaps are nearly 10x larger than MB spec, which would be a serious red flag to me. Also, Wiseco may be providing that data for engines making 1000-2000hp, not 400-500 which in their view is basically stock...Stolen from the Wiseco Pistons website:
For a street engine, multiplying your bore size by 0.004in will give you the top ring gap you are looking for. (snip)
Hmmm. There's a thought. Are we sure custom pistons are required? Not saying you're wrong, just wondering if there are other options. I'd assume that the longer stroke would mean stock M119 pistons with stock M119 rods would push the pistons out of the cylinder. Is there a shorter rod that would work with the M117 crank and M119 piston? What about a piston with a higher pin height that would work with the M119 rods?If you could locate a M117 5.6L crankshaft, you could try to build a 5.6L... need the crank, some machining/mods, and custom pistons. But, you leave the block alone and can use stock head gaskets.
What would this look like today? Do we know what was different between the Mustang kit and the old M119 kit?Nitrous is the easiest to implement, and a couple decades ago a company produced a kit for the M119/W124. A number of these have been installed with no reports of major failure. It's a dry setup based on a Mustang 5.0 kit, and will be limited by fuel supply / injector rate. This should be good for up to +150hp, maybe more.
See if you can locate a cheap 5.6L M117 to source the crankshaft from. There was a 560SEC in the Boise Jungle a few years back, but I didn't have the time/energy to go pull the motor to extract the crankshaft. Per the AMG E60 manual (in PDF form on the forum) there are minor mods needed to the M119 rods and block. The main cost would be pistons. That said, on paper this should be good for 360hp/400tq.Ok, I think that's enough of that thought experiment. Probably not worth messing with anything bottom end. The custom machine work and custom pistons required to get to 5.6 liters is probably not worth the expense, especially when spray is so accessible. That's not to say that I wouldn't ever want a W124 with big power, but if I ever decide to go bananas like that, I'd probably do something unholy like an LS swap in a CE or something. I have too much time into making this car decent in stockish form to ruin it with anything other than an M119.\
I have very mixed feelings about this. Stick shift is fun, but OMG it's so much work and fabrication. On a 500E you'd probably make money if you sold it, but not on a 400E. Besides - Treasure Valley traffic with a stick? Oooof. I'd be more interested in the 722.6 swap, which also isn't easy or cheap, but is closer to almost maybe sort of a bolt-in.Still thinking about that stick shift swap though...
I'm definitely not building this car for the money. All of my custom cars cost more than they're worth. But if they're built exactly how I want them, and I enjoy them, it's worth whatever I sepnt. If I had to guess I'd say I'm probably $6-7,000 into it at this point. Even so, I won't be making any decisions until well after the engine swap is complete. We'll see how I like it at that point.I have very mixed feelings about this. Stick shift is fun, but OMG it's so much work and fabrication. On a 500E you'd probably make money if you sold it, but not on a 400E. Besides - Treasure Valley traffic with a stick? Oooof. I'd be more interested in the 722.6 swap, which also isn't easy or cheap, but is closer to almost maybe sort of a bolt-in.
If it was local, and cheaper, I might consider it. Even if it was free though, I'd be needing custom pistons, which would be $1000 on the low end, and then the crank would need machined and rebalanced. We're talking a couple grand for maybe 30 horsepower. Not a lot of bang for the bucks.Here's your 560 crank?
Yes to all the above. But, the gain would be closer to +40hp, I think. What you would feel is the ±50 lb-ft torque increase, not the horsepower. Driving around town, the extra torque is REALLY noticeable. The extra hp, not so much.If it was local, and cheaper, I might consider it. Even if it was free though, I'd be needing custom pistons, which would be $1000 on the low end, and then the crank would need machined and rebalanced. We're talking a couple grand for maybe 30 horsepower. Not a lot of bang for the bucks.
Nice! With an LED bulb in the CHMSL, you won't bake the CHMSL anymore. However, your bulb out warning lamp in the dash will be on. There are two ways to correct this (aside from taking out the bulb in the dash) -Speaking of details, I had pulled the third brake light out months ago, and had been neglecting to do anything with it since I knew it would be best to wait until the tint was done before I reinstalled it. Just like everything else in this car, it was sun-baked and brittle. One tab broke off the rear cover when I tried to remove it.
Over the last few months I've collected up a couple other lights from other cars in the junk yard. None were in good shape, but I was hoping to piece together an acceptable replacement, even if I had to use super glue and vinyl dye to get it looking decent again.
At the end of the day, my original was really the best option I had. It had a couple cracks and was discolored, and had that broken tab on the reflector cap.
I ended up pulling the lens out, and then placing everything in a pot of boiling water for a couple minutes. The theory here is that the heat will allow the stresses built up in the plastic over the years from the sun to relax. This should theoretically make the plastic less brittle.
The plastic did seem a bit more flexible afterwards, bit without testing it to failure before and after, I can't say for sure. One downside is that it did discolor the plastic. The lens got cloudy, and the grey housing got much lighter and milky looking.
I was able to bring the lens back by first taking the haze off everything with green scotch brite. Then I used some light polishing compound to polish the lend back to an acceptable finish. I had to use toothpicks to get into the corners, but eventually it was ok looking. The lens did have some heat damage from the bulb, but it wasn't too bad.
I super glued the cracks in the housing. In the past I've used accelerator spray to help super glue kick off quicker, but I've discovered that this tends to make the glue more brittle. For this repair, I just let it cure naturally overnight.
Next, I used a fine file to knock down the excess glue. Then I carefully sanded to even everything out. The plan was to use Duplicolor Vinyl and Fabric specialty coating in medium gray to match the color. I've used that product before and it's a great color match in the interior of this car. The trick is to clean everything really well, and to also use adhesion promoter.
To clean, I start with dish soap and hot water. Scrub with an old toothbrush. This gets all the old funk off of it. Rinse in hot water, then dry completely. Next, I use non-chlorinated brake parts cleaner with a lint free rag. This is risky and takes some experience. Too much solvent or too much time and you'll melt the plastic. I tend to wet the rag, then wait a few moments for the rag to become just damp. Then, I wipe each area exactly once. After wiping an area, do not touch it. The plastic will soften and it will be easy to leave marks. Once it's all been wiped, it's ready for adhesion promoter.
Now, this is where things went sideways for me. On other plastic parts, I'd been able to just spray 2 or 3 light coats of adhesion promoter, followed by 2 or 3 light coats of color, and everything was great. The third brake light did not like that.
When I sprayed the housing with the adhesion promoter, the solvent contained in the spray attacked the top layer of dye or finish on the brake light housing. As the solvent then evaporated, that layer shrank and cracked.
I walked away for a bit and came back to find it had dried like that. And now had a nasty cracked texture. I decided the only way forward was to sand the whole thing back down. And then try it without the adhesion promoter. I used an orbital sander and 320 grit sanding discs to smooth it back out, then after wiping down with brake clean again, I set it up and sprayed just the color. The same thing happened again.
Here's a picture after that second attempt:
I'm not sure, but I assume that the housing is injection molded, and then some kind of finish coat is applied afterwards. Between the boiling, and the solvents, that finish coat had become delicate and was not willing to play nice.
I thought about it a while and decided to try a different approach. I sanded it all down again, and then went and picked up a can of grey Plasti Dip. The Plasti Dip sprayed on nicely and did not attack the plastic or its old finish. It left a nice new finish. The only issue at that point was that the color was too dark.
I figured the vinyl spray color might work ok with the Plasti Dip, so I gave that a shot. That ended up working great. Got the color and texture back where it needed to be.
I'm bit a fan of retrofit LED bulbs in older cars. There are numerous problems that can be created by their use. That said, the heat created by incandescent bulbs in the thrid brake light ends up damaging theblens and housing over time, so I decided a quality LED bulb was the best option here. I installed a Sylvania LED 7506 bulb in the socket, and then glued the lens back in.
Reinstalled and it looks great and works perfectly.
It didn't trigger a bulb out warning for me. Or maybe my bulb out bulb is out. Meh.Nice! With an LED bulb in the CHMSL, you won't bake the CHMSL anymore. However, your bulb out warning lamp in the dash will be on.
The 5.3L Chevy LS engine has a stock bore of 3.779".Yes to all the above. But, the gain would be closer to +40hp, I think. What you would feel is the ±50 lb-ft torque increase, not the horsepower. Driving around town, the extra torque is REALLY noticeable. The extra hp, not so much.
Also, when the indicator bulb isn't burned out. Mine was. I just replaced it and now it does indeed illuminate.The bulb-out will only illuminate with the engine running AND then you press on the brake pedal. It will then remain on, until the key is turned off.
Oh, sweet. Thank you! I happen to have a spare relay sitting around. I'll try that.Or neutering US N7 (maybe I did not post this)
Oooo. I'd be all over that if local, just to get the crank to experiment with. They're getting harder to find as they're passing 30-35 years old.I was able to find a 5.6 locally, and I'm sure I could get the whole thing for just a couple hundred dollars. Even so, I doubt I'll do it.
I'm not sure about this. As long as the cylinder walls are intact, why would new rings not seat properly? The Alusil walls should have imperceptible wear (if not damaged/scratched), I'd think new rings should seat ok with dino oil during break in. (??)I hadn't even thought about the fact that the cylinders are Alusil. This creates a bunch of additional complications. Any off the shelf piston for an iron block/sleeve engine will not have an appropriate coating to work well with Alusil. Furthermore, new rings will be unlikely to seat properly with Alusil unless the cylinders are at least honed.
Going to 6.0L adds a LOT more difficulty / expense, specifically boring/etching the Alusil block with Sunnen equipment. My understanding is that only a handful of machine shops in USA can do this properly. If there was a local shop with the capability, it would be more tempting... otherwise you have to ship the block Far, Far Away and hope the work is done right. The OE gaskets are mind-numbingly expensive ($2500/pair?) so aftermarket, or custom aftermarket, would be needed.So now we're talking about custom pistons, probably custom rings, custom machine work and balancing on the crank, and machine work in the block. All to get from 5.0L to 5.6L. At that point the only thing keeping me from 6.0L is a little extra machine work on the block, and head gaskets. The 5.6 is not a bargain option.
Dibs!Oooo. I'd be all over that if local, just to get the crank to experiment with. They're getting harder to find as they're passing 30-35 years old.
Just what I've read about Alusil engines from Porsche guys. I've heard that seating rings can be tough.I'm not sure about this. As long as the cylinder walls are intact, why would new rings not seat properly? The Alusil walls should have imperceptible wear (if not damaged/scratched), I'd think new rings should seat ok with dino oil during break in. (??)
I'm basing my statement on the assumption that honing would be required to use new pistons. If honing is required, then I would assume etching would also be required. At that point we're already into all that expense, so why not just have 100mm pistons, and do the bore before the hone and etch? The only major difference at that point is the shockingly expensive head gaskets.Going to 6.0L adds a LOT more difficulty / expense, specifically boring/etching the Alusil block with Sunnen equipment. My understanding is that only a handful of machine shops in USA can do this properly. If there was a local shop with the capability, it would be more tempting... otherwise you have to ship the block Far, Far Away and hope the work is done right. The OE gaskets are mind-numbingly expensive ($2500/pair?) so aftermarket, or custom aftermarket, would be needed.
There are a few variations of Alusil/Nikasil. Are the Porch engines using the identical technology / cylinder walls as M119? If so, I'm curious what problem were encountered. Did they have issues seating new rings into an old bore, like we'd be trying to do?Just what I've read about Alusil engines from Porsche guys. I've heard that seating rings can be tough.
This is where I don't know enough about the process to determine what we need to do. Have you read the PDF linked above for reconditioning aluminum blocks? Maybe an engine builder that specializes in these (i.e., Metric Motors) would be able to provide some insight. My understanding is that the etch process "eats" the aluminum away from the cylinder walls, leaving the silica exposed. I'm not sure if honing will remove enough silica to repeat the process, OR if this will change the bore diameter enough to require different piston diameters (but, with new pistons, that may be less of an issue).I'm basing my statement on the assumption that honing would be required to use new pistons. If honing is required, then I would assume etching would also be required.
Totally agree. I was also thinking we could leave the block alone (assuming the bores are undamaged, no scratches or major wear) and slide in new pistons/rings. If major block work is needed, then we might as well bore to 100mm and go for 6.0 displacement... but the total cost becomes prohibitive. And we haven't even discussed camshafts yet, lol (which would be nice, but not required).If I could get pistons for any kind if reasonable price, and if the block was usable as-is, I'd probably do it. I just doubt pistons would be less than maybe $1500, given recent inflation. If the block is not usable as-is with new pistons. It's definitely not worth it.
Heh. Good point, however, you could always swap in the stock 4.2L engine to sell with the car, and keep the custom motor for a 500E, or sell it separately, etc.And all this in a 9 owner title loan repo 400E.
