It is a common malady to nearly all M119 engines with dual-distributor systems, sooner or later, that the engine will suffer stumbling and cutting out. This condition is because there is inadequate air circulation inside the closed environment of the distributor caps, which causes condensation to form inside of the caps, effectively electrically "shorting" the flow of electricity to the spark plugs inside of the cap.
There is MUCH more background about this condition here on the forum, in this thread: FYI - Essential M119 Ignition "Tune Up" mods [Distributor cap vent / slot] | M119 Engine
The air circulation slots that Bosch and Beru cut into the edges of the distributor caps are inadequate and do not allow air to circulate into and out of the cap. This HOW-TO illustrates how to modify the distributor caps so that appropriate slots are cut to allow air to properly circulate. You will find that this modification, performed well, will permanently eliminate this problem.
Difficulty of job: 4 out of 10
Time required: 1-2 hours
Tools required:
Lift up the hood into the vertical "service" position. This will provide much more room to work, and make the job easier.
The first step is to remove the left and right air intake tubes (aka "zoom tubes"). Set them aside on the sides of the engine compartment.
Then, remove the center engine cover by lifting it straight up, and set it aside on the edge of the engine compartment.
Then CAREFULLY remove each of the plastic ignition system covers on each side of the front of the engine. Use your fingers to GENTLY release the clip at the bottom of each cover, and then rotate the cover upward and off of the front of each cylinder head. Set the covers aside at the rear sides of the engine bay.
Removing the covers will expose the distributor caps and ignition wires, as shown below.
Carefully pull each ignition wire off of its terminal on the distributor cap. Each of my wires is numbered both with the factory cylinder number label (brownish band) and also a newer, white label that I placed on each wire in 2020.
As you pull each wire off of its terminal, use a Sharpie marker (light color preferred) to mark the number of the terminal where the wire goes. This will help immensely when it comes time to re-install the wires on the caps' terminals. Note the silver Sharpie marker numbers that I wrote on each terminal (under the rubber ignition wire cap) back in 2020. These numbers were still very clear. The "R" in the center denotes the coil wire terminal, as well as "Right" and "L" for "Left" side coil.
From there, take your 5mm Allen wrench, or 5mm 3/8" Allen socket, and gently/slowly loosen each of the three captive screws of each distributor cap, as shown below.
After loosening all three screws, remove the distributor cap from the distributor.
Here is the inside of my passenger side cap, immediately after removal. Note the electrical tracks between the four outside terminals and the main inside terminal, as well as the greenish dusty by-product of random spark distribution inside of the cap.
Repeat the same cap removal operation for the other side.
Here is the inside of the driver's side cap of my E500. Note that it is COMPLETELY PRISTINE inside after 8,000 miles driven.
Side by side shots of the interiors of my two distributor caps:
The nest step is to remove the distributor rotors. These factory/OE/Beru rotors are held to the aluminum rotor carriers behind them with three 3mm captive Allen bolts. NOTE: Bosch aftermarket rotors have a strange 3.5mm size captive bolt, and are VERY VERY easy to strip. Check the forum for information on how to successfully loosen and remove the Bosch bolts.
After loosening the three rotor bolts, carefully remove the rotor from the distributor.
Repeat the operation for the other side's rotor.
The last operation you need to do for removal, is a single 5mm Allen bolt that holds the rotor carrier to the camshaft. Gently remove this bolt and remove the rotor carrier, and the distributor insulator behind it.
Here is a view of the insulator. I had replaced this insulator back in 2020.
And here is the front of the cylinder head cover, behind the insulator. Note that I had replaced the camshaft seal back in 2020, and there was NOT A SINGLE DROP OR SMIDGEN OF OIL OR MOISTURE in this area when the insulator was removed.
Repeat the rotor carrier removal for the other side.
Again, not a single drop of moisture or oil seepage/leakage at the camshaft seal. Great news for both sides.
You can see the moisture on the outside and the inside of the passenger side insulator, corresponding to what I found inside the distributor cap from that side.
More views of the inside of the passenger side distributor cap.
Now, it's time to cut the slots into the distributor caps. Using your Sharpie marker, make some appropriate slot markers where you will grind the new slots into the caps.
Then, put your cap upside down into a bench vise to hold it securely, in preparation for cutting the slots.
Then, carefully cut the new slots. Make sure to make them deep enough so that you go 1-1.5mm into the outer covering of the distributor cap. This will ensure that there is enough airflow into and out of the caps.
After slotting the distributor caps, clean everything off with a rag soaked in brake cleaner. The caps will be dusty from the slotting action.
Then take some WD-40 and spray a light coating on the inside and outside of the insulators, as well as the recess in the front of the cylinder head cover where the insulators fit. This will help displace any moisture, at least until the WD-40 evaporates.
Then, re-install the distributor rotor carriers onto the camshafts.
Then, install the rotors back onto the rotor carriers. I used a small dab of blue Loctite on each of the three rotor screws, on both rotors. Bad picture, but you get the idea.
Then re-install the distributor caps, and re-connect the distributor wires to the caps, paying attention to the numbers on the caps' terminals and the ends of the ignition wires.
Re-install the plastic ignition covers, center engine cover, and the zoom tubes, and you will find that the moisture problem in the distributor caps is eliminated forever !! (At least, until the next time you need to replace the caps).
Enjoy a successful repair.
Tools required:
- 3/8" drive ratchet and short extension
- 5mm Allen socket, 3/8" drive
- 5mm Allen wrench / hex key
- 3mm Allen wrench / hex key
- Dremel tool with 1.5-inch EZ-406 cutting wheel + EZ-Lock mandrel (more info here)
- Blue Loctite
- Brake cleaner
- WD-40
- Shop rag or shop towels
![[500Eboard] 20210718_173952.jpg [500Eboard] 20210718_173952.jpg](https://www.500eboard.co/forums/data/attachments/229/229289-f8f30a669368dce1116d7de3d71d9d79.jpg?hash=drbufksupl)
![[500Eboard] 31B5C6A1-60A9-4C50-B758-791CD266C4B9.jpeg [500Eboard] 31B5C6A1-60A9-4C50-B758-791CD266C4B9.jpeg](https://www.500eboard.co/forums/data/attachments/229/229290-9730908637630b0ebf15d904919efad2.jpg?hash=W8kFhLucWz)
![[500Eboard] 5312C010-5570-4C31-8271-91DC4F64F757.jpeg [500Eboard] 5312C010-5570-4C31-8271-91DC4F64F757.jpeg](https://www.500eboard.co/forums/data/attachments/229/229291-f579b8eba04424309ca61ae3b3e3eecc.jpg?hash=sEsSnJZ0Fw)
