Yes. Everything would be the same for the M119 as found in the 1994 SL500. It's a close variant of the engine as found in the E500. Did you confirm that your car has plastic oiler tubes by looking through the oil filler cap with a flashlight? It's more than likely that a 1994 model M119 DOES have the plastic tubes, but it's good to make sure before you embark on the project.Gerry, I have a question. Will this process and these part numbers work with my 1994 SL500?
Thanks, Torry
