Ntrepid: I just read over your posting on mirror boot replacement and looked at Dave's photos. Since I just bought a used pair from Gerry I now need to install them on my E320.
Would you go over the procedure to remove the glass and plastic frame. Does the frame just pop off with pressure from the screw driver inserted on the bottom edge ? I'm afraid of cracking the plastic.
Thanks in advance.
Regards,
Peter Weissman
Don't know if this tip has been mentioned before: When I did this project, I dipped the new rubber boots in a pan of very hot water just prior to installation. Makes it much easier to stretch the new part into place.....
Also, be very careful when removing the triangular trim cover from the inside of the door. There is a plastic tab on the back side that is very easy to break. I found (after breaking a few of these) that using a flat metal putty knife works best. It allows you to apply a perpendicular (to the door surface) force right next to the tab.......
Hope this makes sense.
J. M. van Swaay
It's almost like MB meant for the trim to break on removal and be replaced with new each time.
Jon, color code 8320 is Palomino (pre-facelift, interior code xx4).Speaking of that tab, I think I just ordered one from Napperville but not sure I got the right part number. Is this part 124 720 11 11 8320? I have a parchment interior (not mushroom) so I asked them to double-check the part number for me. It says "Plate, Int Mirror Mou."
For Parchment (facelift, interior code xx5) the suffix should be 8F33. See attached screenshot with EPC footnotes.
OMG. They are so clueless. 8F33 is Parchment, 8411 is Cream-Beige, and 8320 will most definitely be Palomino. At least it's relatively cheap (compared to black!).Just a follow-up. I just contacted MB of Napperville and they verified that 8F33 was superseded by 8411, then 8320, which is what they are sending me, because it matches my VIN. She said it was not Palomono but Parchment. We'll see when it arrives. She said there are now three of these left in the US and 22 left in Germany. Mine is coming from New Jersey. Get them while they last.
No need to do that, as we have our own Mushroom King from Jelmeria......Should I cal her back and ask whether the MB gurus in Germany have deemed parchment to be the "new mushroom"?
No, it's just a misinterpretation by the nice lady you talked to. This is a "functional equivalent" supercession, meaning the item you will receive will work just fine. However it happens to be the wrong color. Usually the parts department folks understand this stuff, maybe she's new or helping out from a different department.Should I cal her back and ask whether the MB gurus in Germany have deemed parchment to be the "new mushroom"?
They are all coming from the same source, so no, the ones in Europe won't be any different. Many parts have substantially different prices in USA vs Europe, but it isn't because they are drawing from separate/different stock.Curious if the ones being sold in Europe at more reasonable costs are more recently manufactured ones.
It would be a waste of time. There's a tiny possibility of mixed inventory, meaning for a given part number some parts in the bin may be newer than others, but even if so there's no way to request a "newer" production part. It's whatever the warehouse guy picks and trust me, he doesn't care about the date code.For any rubber parts, I would want freshest parts possible! Should I try to exchange the "old" one with more recently manufactured on to match the '06 boot?
Current prices of mirror boots:
Cap - 1955-1993 Mercedes-Benz (124-811-01-61) | Get Mercedes Parts
1955-1993 Mercedes-Benz Cap 124-811-01-61www.getmercedesparts.com
Cap - 1955-1993 Mercedes-Benz (124-811-04-61) | Get Mercedes Parts
1955-1993 Mercedes-Benz Cap 124-811-04-61www.getmercedesparts.com
