I see a sizable dirt smudge on the right side of your last photo above on the vertical mushroom side. Must be some schmutz from your Porsche keychain?!?
I think I've said I'm not big on Red exterior, but this is gorgeous, JLAA Excellent job on all of the restoration, and I really appreciate the detailed pics.I used Gorilla Glue to glue back some of the vinyl along the driver's door pocket. It seems to work well.
I put thread locker on the nuts for that hold the wood to the door --- one of the nuts had come loose.
At the same time, I repaired some cracks in the base plastic of the fragile interior A-pillar triangle cover with JB weld --- that made the triangle stiff again.
The only thing I've found with my new 124 is that the upolstery is pulling away from the door side pockets. Very helpful to see how you addresed the issue.
Jlaa, Could you give me the contact info for your mobile painter? I'm in SF also and needs several areas touched up on my E500.I know a gentleman that does house calls for straightforward touchup work like this --- no body shop needed and he bakes the paint in your garage. As well, the price is right.
View attachment 55950View attachment 55951View attachment 55952View attachment 55949
Thanks,
Bill
Congratulations on completion of a major maintenance task. Again a significant component of the $5-10K of deferred, overlooked maintenance. Did you follow the extensive HOW-TO for this procedure? Any tips to add to it?Grrrrrr. I hate it when I find evidence of slapdash jobs done by previous caretakers of the car.
I replaced the ZHM filter and the ZHM dipstick tube today. The old ZHM filter was only slightly dirty (debris @ bottom of filter) and the old ZHM dipstick tube was completely broken.
Maybe the part numbers here will help someone in the future.
Small wins.
Looks like a lot of the other plastic bits on these guys. Not sure what they used, but I haven’t ever seen any other material that does the whole ‘turn into a crayon over time’ thing.
Any and everything petroleum based over 25 years...if you're lucky. Over 10 years if not.
Jlaa,
What is the refinishing process?
I'd find a way to clean it.. maybe alcohol, then epoxy primer and grey top coat.
I'm at the same point w my s600 insert.
I'm not sure the paint color, but it reminds me of early W124 body clading.
i "cleaned" the grille insert on my car.i did every square hole on at a time..i cant remember what i used to clean it with...maybe it was just some polish,,But it came out super nice..and got rid of the grey faded color.Now it is fresh grey colorIt was quiteabit of work..but definetly worth it in the end..as the new grilles are very expensive.Here in norway a complete grille for the 201 was almost 1000 dollars.
I'm sure you'll go for a new insert considering the condition of your car, but others might find my recent experience helpful.
I was using Solution Finish (https://www.amazon.com/Solution-Fin...pID=41RtJvMhgTL&preST=_SY300_QL70_&dpSrc=srch) to restore some black trim on my wagon. I decided to give it a try on my grey grille insert. With a narrow foam applicator sponge, it was a quick job. It has only been a week so I don't know how long it will last, but so far it looks good (not sure why the picture is upside down).
Another bit of advice, if you are going to the trouble to get a new insert, you should also look into getting new chrome strips. And don't forget the clips to attach them:
https://www.500eboard.com/forums/showthread.php?t=948
Very nice. How is the roof and window trim looking?
C’mon, I cannot contract lowmania!!! My trims are too bright and not black enough.![]()
Those are the best numbers you could possibly hope for, Jlaa. Anything in single digits is amazing. Did you heat up the cats with some high-RPM cruising prior to the test?
The zero/zero measurements are likely errors, but hey, I wouldn't complain.![]()
Based on my experience, the cat-heating procedure makes a yuuuge difference. If you spent 5-10 mins at 3500+rpm just before the test, that likely explains your stellar measurements.Ja. Since I live in an urban environment, there are a gazillion smog shops within a 2 mile radius of me, but I like going to one 20 minutes away so that I can get 5-10 min at 80 mph in 3rd gear before the test.
Wow!! That lighting really sets off that ‘Arrest Me Red’ color.
BUT no pic of that ‘Sexy Euro Red Ass’ ?
There is but one color which I would prefer over signal red, and that is makemann's Pearl Grey --- but since he will never sell it, I will have to hang on to this one.![]()
