No, I would say that the pitting in the imide lacquer finish of the black cap is not normal. Or perhaps I should say not ideal.
First, why did you replace the caps and rotors. Also, why did you inspect the caps at 40 miles? Which State in the US?
The pitting in the imide finish is generally between the uppermost HT poles and the central electrode. Moisture vapour is lighter than air. Hence affects the uppermost poles. So the marks look to be the start of moisture related arcing across the surface of the distributor cap. Have you noticed any misfiring or rough running?
I used to prefer BERU because the imide finish helped to suppress moisture build up inside the cap. But BERU, which are commonly available as reboxed Doduco parts, are known for failure of the central electrode due to heat from HT spark and tracking through the plastic material. This flaw was highlighted on the original patent submitted by Doduco, and I have had this happen to BERU caps on my R129 500 SL.
I now promote modifying BERU or Bosch caps by cutting additional vents to aid water dispersal, as described in the following link: -
Link to article on distributor caps
