Ignition problem traced to faulty insulators behind distributor caps
500Espot
Administrator
Postby J. M. van Swaay on Mon May 18, 2009 5:41 pm
I posted this problem a few weeks ago in the diagnostic area, thought I'd follow up here before spending lots of money on parts:
1994 E500
119.974 engine
78,000 miles
new engine wire harness
Symptoms:
Intermittent rough running and occasional no start. When no start condition present, engine cranks, fires, but will not continue to run. Ocassional backfire also occurs when no start condition present. When rough running condition present, it is most noticeable at idle?idle speed is however still correct at about 500RPM. Engine smoothes out at higher RPM. Rough running symptom only occurs after a 5-10 minute warm up period, No start condition only occurs on warm/hot restart attempt. Cold start and initial run are 100% normal.
Retrieved a code 18 from pin 17?crankshaft position sensor. Replaced sensor, no fix.
Recheck for codes, none present.
This seems ignition related, it?s almost as if one bank of cylinders is not firing. A few of you have suggested that I might have a failed/failing EZL ($$$$$$$$$$$$$).
Because the problem is intermittent and appears to be temperature dependent, I'm not quite ready to condemn the EZL.
I am considering replacing coils, rotors, caps and wires to see if that fixes the problem. Normally I don?t like to diagnose via part replacement, but I think these are all original so it probably would not be a complete waste if it doesn?t fix the problem. Also, it's been recommend that new coils be installed when installing a new EZL, so, if I end up needing a new EZL this will already be done.
Anything else I might try/consider before spending lots of money on parts?
Thanks,
J. M. van Swaay
Postby gerryvz on Mon May 18, 2009 5:54 pm
Caps and rotors are de rigeur - if they haven't been done in the last 25-30K miles, DO THEM NOW. This is a relatively inexpensive item ($250 in parts) and imperative that it be done regularly -- the E500E seems to go through C&Rs regularly. I've replaced them twice in less than 40K miles of driving the car - and both times it needed them badly due to carbon tracking inside the caps.
Coils really don't go bad much, but generally if they do, they go dead. Your engine won't run. I don't think your coil is the answer. Nor do I think your wires are the issue -- if it was wires, you'd have a shorting condition. Not to say it isn't, but one way to tell obvious shorting is to start your car up in a dark (black) garage and see if you can see any blue external "arcing" of the plug leads to the block -- if yes, then wires. If your C&Rs don't resolve the problem, there is absolutely no doubt in my mind that it is the EZL.
You can check your caps just by removing them and looking for carbon traces on the inside of the caps. If you seen black carbon tracks and/or greenish crap on the inside of the caps, it's time to replace them and the rotors NOW. Based on my own experience with the C&R going "bad" when the engine is warm, I say go there first.
Unfortunately though ... I think you are going to find that your EZL is the issue here.
Hope this helps.
Postby Honza on Mon May 18, 2009 6:42 pm
I have problems like these with my 1994 E500 this spring. I wanted to bring it back to life after winter storage and it was running ok when it was cold but 10 minutes after reaching the operating temperature it went completely wrong to very rough idle and very weak acceleration. I have changed the Air-Mass-Meter, upper wiring harness and spark plugs but the problem was not fixed.
Then I have spoken with my friend, who is running a Mercedes Garage in Ireland and he suggested that it should be the problem with backfire in the rotors because he had this problem on one R129 500SL 1 year ago. The main point by the replacing of the rotors with all accesories is that the engine must be at the operating temperature and after removing the old ones with the orange rings at the backwards you have to dry it completely with some kind of hot-air dryier and then mount on the new rings. sealings and rotors. There is a lot of screws which should be screwed up with exact torgue moment.
The parts are :
A 119 158 01 88 x2 EUR 71.13 each
A 020 997 05 48 x2 EUR 2.20 each
A 119 158 02 31 x2 EUR 56 each
A 119 158 01 02 x2 EUR 114 each
and you can see them on the picture on this link. The numbers are 14, 17, 20 and 23
http://www.e500.cz/phpBB3/viewtopic.php ... a&start=10
I hope that it will help because the EZL is very expensive to fix.
Good luck
Honza
1994 E500 Limited Saphire/Grey
http://www.e500.cz/
Postby gsxr on Mon May 18, 2009 6:59 pm
I would start by pulling the caps & rotors and inspecting them. If you see carbon tracks and/or greenish residue, you can try cleaning them up. I use a small screwdriver to scrape the crud off the contacts. If they were REALLY crudded up, and cleaning them nice & shiny makes NO difference... then new caps & rotors may not either. But, it may be worth the hour of time prior to shelling out $250+. If they were that bad, I'd expect them to act up more often, not just when warm. I'm really not sure about the coils - I'm not familiar with the failure modes possible. I assume the plugs are clean and are the proper spec.
Unfortunately, I'm thinking along the same lines as Gerry... the EZL is definitely suspect. This is when a spare EZL can come in handy. If you can find someone with a similar car, you could test their EZL in your car (or vice-versa) and see what happens.
EDIT: Later information has shown the EZL either works or it doesn't, for one or both coils/distributors. If the problem is intermittent, the EZL is almost certainly not at fault.
I would absolutely not buy a new EZL unless you had conclusive proof that your current one is bad. New ones are $3k list, best price I know of is about $2100. I just sold one of my spares, I may let another one go as well, it would be less than a third of that if you're interested. Gerry has one for sale also, posted in the classifieds. But first, try to rule out the caps / rotors / wires / coils / etc...
Dave M.
Postby J. M. van Swaay on Tue May 19, 2009 3:27 pm
Thanks for the replies.
Honza, did the new caps, rotors and seals solve your problem?
I removed the caps and rotors, visual inspection shows very slight carbon trace on one of the caps, otherwise they look normal to me. However, I don't really know what normal would look like. So, I have attached two pictures. Should I clean and resinstall or replace?
The epc lists two numbers for my EZL, they are 015 545 61 32 and 015 545 62 32. The one currently in my car is the 61 32. If you have a spare that you are interested in selling please send an email to jmvanswaay@charter.net.
Thanks for all the help.
J. M. van Swaay
You do not have the required permissions to view the files attached to this post.
J. M. van Swaay
Postby gerryvz on Tue May 19, 2009 4:56 pm
Those (caps and rotors) should be replaced, looking at your photos.
The main things to look at are the scoring and pitting on the contacts inside the caps, and on the rotors. They look to me bad enough to cause issues.
Postby Honza on Tue May 19, 2009 8:27 pm
Not yet because I am changing the job now but maybe this week it will run again :alky:
Then I have to do the technical check to drive it legal and then there will be the time for installing the beautiful refurbished Brabus Monoblock III 9.5x19 :woot2:
Honza
http://www.e500.cz/
Postby Quicksilver500 on Wed May 20, 2009 12:19 am
I had a similar problem and it turned out to be 2 plug wires. Everything was fine and when it got hot I guess it moved and shorted. You can get a cheap multimeter and measure the resistance of the wires. Mine was undetectable until you swung the wire around then the ohms jumped around....spent a lot of time swapping parts and chasing ghosts. At least I knew what cylinders were missing though so I could focus my hunt.
Maybe check the cam sensor? If that is broke it can create a no start because it doesn't know where TDC is so it guesses what to fire, if it guesses right it will start, and if it guesses wrong it won't. Could be a intermittent failure, heat and time do funny things to electronics....
Doesn't really sound like it could be a fuel problem but I guess you never really know.
-Mike
Quicksilver500
Postby J. M. van Swaay on Wed May 20, 2009 2:41 am
Thank you all for the responses so far, it may be a day or two before I get another chance to "play" with the E500. I'll post updates and more information as the problem/solution develops.
J. M. van Swaay
Postby gerryvz on Wed May 20, 2009 4:11 am
If it's externally shorting wire(s), you can tell in a dark garage by running the engine. You'll be able to see it arcing in blue sparks. I just dealt with this on my 560SL.
Postby J. M. van Swaay on Sat May 23, 2009 3:14 pm
Update:
Haven't had time to pursue this the last few days--work has a way of cutting in to my E500 playtime.
I decided to go ahead with the ignition part replacement plan. I got a litle crazy with the click to buy link, I should have new coils caps rotors plugs and wires sometime next week. I choose the Bosch OEM parts as opposed to the OE. I guess I should have asked if the experts think there is a difference......
Closer inspection did reveal significant erosion on a few of the cap contacts, I think this was the subconscience cause of the click to buy fest.
I know that coils and wires can be checked with an ohmeter, but I have had cases where a cold ohm check was good but the part would still suffer breakdown when hot. Because of my symptoms, I'll just replace it all....
At least now if (or probably when) I replace the EZL, I'll know everything else is up to snuff.
Stay tuned.
J. M. van Swaay
Postby gsxr on Sat May 23, 2009 3:24 pm
Sounds like a good plan, JM. Bosch OEM is perfectly fine, I would have done the same if they were less $$$ than OE/dealer items. With all those goodies installed, if the problem is not cured, then you'll know for sure it's the EZL!
:excited:
Postby J. M. van Swaay on Wed Jun 03, 2009 1:21 pm
Update:
Box of parts came last week--installed caps and rotors only, symptoms have not reocurred after 4 drive cycles.
During the course of disconnecting/reconnecting coil wires, I noticed a small pool of power steering fluid at a low point of the coil wires about half way between the coils and the left distributer cap. The two coil wires were in contact with each other and formed a small crescent shaped holding pool. I previously replaced the short piece of hose between the top of the power steering pump and the reservoir because of a slight seep. I thought I had cleaned up all the fluid from the leak but I obvioulsy missed this.
Is it possible that this little pool of fluid was responsible for my misfire/rough running condition? It seems to make sense because my symptoms appeared to be associated with a whole bank as opposed to a single cylinder. Is it possible that when one coil was trying to fire, the other was providing a "leak to ground" through the conductivity of the power steering fluid pool?
I'm a little annoyed at myself for not seeing this earlier...................but I'll be happy if it is now fixed. Another 25 drive cycles and I might be convinced.......
Thanks for everyones input.
J. M. van Swaay
Postby Honza on Wed Jun 10, 2009 1:37 pm
I have changed the rotors and plastic rings today and the problem is solved :woot2:
The old rotors and plastic rings were really worn out and there were many black places on them because of the backfire. The rings were quite wet so I undestand now why the ignition didn?t work after reaching the operating temperature.
Now is it fixed :excited:
Honza
http://www.e500.cz/
Postby gerryvz on Wed Jun 10, 2009 1:56 pm
Glad that the analysis of the cap and rotors insulator was correct and helped solve your problem.
I'm on my third set of caps and rotors in less than 40K miles (admittedly, I until recently lived in a rather wet climate which IMHO contributed to the fairly early demise of the C&Rs due to moisture) so I've experienced what you did and my mechanic shop showed me many examples of M119 bad C&Rs in their shop.
ADMIN EDIT: Later information has shown that bad insulators "kill" new caps & rotors; or possibly new caps & rotors will temporarily overcome faulty insulators. If a car seems to "need"
new caps+rotors in a very short time (or miles), it is extremely likely the insulators are the root cause. Klink detailed in later threads that cars which came to the dealer seemingly needing new caps & rotors every 6 months, immediately stopped eating caps/rotors once the insulators were replaced.
Re: ignition problem
So the result of replacing the rotors and accesories is very good. The car is running properly and the fuel consumption fell from 16 to 11.5 l/100km and that is really impresive :)
Thanks for the follow-up and that's wonderful news to hear. :bowdown:
:wahoo:
Here is a magazine article about ignition & misfiring issues that appears in the latest issue of the MBCA Star magazine, which I just received today.
May be of interest to some folks.
Thank-you Gerry, Not only does it highlight a difficult to diagnose fault it lists off a number of other areas that will help other with their investigations.
Jim.
VERY interesting. Unfortunately, on the M119.974, that item is $124 USD list price - EACH. Part number is 119-158-01-88. I don't think I'd replace them unless (1) I had the intermittent misfire problem, and/or (2) there was evidence of electrical failure as shown by the arrows in the photos. Now I'll have to go inspect all my cars!!
Thanks for sharing this, Gerry...
I would think that you could just clean them off really good and try to see if that works. Use a solvent or brake cleaner etc. to try to clean the tracks off. Once the weather cools down a bit (we still have a month or six weeks to go ... it's 93 degrees outside right now) I'll spend some quality time out in my shop and check this out. Need to change my coils too, on both the 560SEC and the E500.
P.S. Here's the price from parts.com
i'm all over this like Paris on a coke-laced doob...as the car is idling worse since i swapped out rotors and caps a week and a half ago...
BTW...119-158-01-88 is $74.96 at AzAutoHaus...
That's for an aftermarket Bosch part, not the "real" MB part with a dealer-honored one-year warranty. That said, very likely the MB part is Bosch as OEM.
Thanks for the article Gerry, really appreciate your efforts
I couldn't find a separate part number for the insulation disc, it seems to be part of the cover behind the ignition distributor.
You know this could be a the one, He toke a similar diagnosis procedure as the one I and many others have taken:
1 - new spark plugs.
2 - new wire.
3 - new distributor.
4 - cleaned or replaced caps.
5 - checked ignition voltage. ( Anyone have values of theirs)
6 - checked combustion time. (same here)
I would also add that in high electrical load situations (AC on, headlight,Radio...) the misfire is a lot less noticeable or does not occur. Due to the coils not producing a higher voltage than required.
I would like to see more pics of those covers, is it a thin insulation layer? anything else we know about this?
I installed new caps, rotors and spark plugs this weekend and, so far, it has cured my warm restart difficulty and misfiring issues. It starts, idles and runs smooth now. I picked up everything at Rockauto, which has slightly better prices than AutohAZ, along with a 5% discount mentioned from the O2 sensor post.
Hello.
FYI - here are the different rotor back covers:
Old version: A119 158 01 88
New version: A119 158 02 88
Aftermarket from AutohausAZ: No OE PN, but it has the Bosch logo and PN as far as I can see. It's cheap'er than the OE and does the job - so far so good...
I changed this cover due to the happening shown here in post #5: http://www.500eboard.com/forums/showthread.php?2833-Short-clip-of-possible-EZL-failure
You asked about coil or spark voltages? A few weeks ago Jono measured mine with the car running using the factory SDS system.
If you have had a badly tracked distributor cap, I'd consider a new coil for that side. Heck- I think they are less than the cap/rotor?
Michael
Interesting....neither of those two part numbers for the rotor dust shield can be found on Parts.com. What gives?
Just thought I'd ad that the EPC list's the 2 part numbers as "optional" for each other.
Also, the 119-158-0188 is Bosch and 119-158-0288 is Doduco.
Having the same symptoms as originally posted in this thread by JM van Swaay in 2009. I have a 1992 500E euro spec. Additionally, my mechanic is now telling me that when they plug it in to check the fault codes, their computer can't read the EZL. Why can't the EZL be read? Appreciate any advise on how to proceed with this.
It depends what scan tool / computer your mechanic is using. Not all will communicate with the EZL, despite what the mechanic (or their computer) says. If they have the Mercedes SDS, or if it's the dealership, then something might be wrong. Otherwise, it's more likely their scanner won't work with your car. Especially if you can use a blinker box to pull the analog blink codes successfully.
:cel:
I have the Snap On Mt2500, which will communicate with the DI EZL. The only time it won't is lack of power or key off.
Last possibility is a bad EZL, if the car wont run. The need to try their scanner on another M119 LH car and see if it works on that.
The Snap-On kits usually will at least partially communicate, but they may not show live data... appears to be a software bug with some cartridge versions where it will show the live data attributes, but never update the values.
A lot of shops trust their scanners too much. Reminds me of a recent issue where a shop (dealership, IIRC!) condemned a 500E's SRS module because their scanner couldn't talk to it. Only problem is, the scanners can not communicate digitally with the W124 SRS modules. They only have analog blink codes! That's a software error with the HHT and SDS, which is pretty sad for OE stuff, but whaddya gonna do...
:roll:
Correct, that's why I bought 3 different software cartriges.
The 2003 works on all supported systems, LH, DM, DI, EA, ISC/CC, and BM on my 1993 400E
I get full live data on the EZL as well as the other modules.
Double-check if the live data values update for the EZL on the 2003 cartridge. I found the 2003 did not work for the EZL live data but 1999 (usually) did. WIth 2003 it would show values, but they would not update with the engine running, i.e. they were fixed or were all zeroed out. YMMV, etc.
They do, it can be slow, if that happens just back out (hit N) and Y going back in and you'll get the current value.
Lambda can be slow compared to using my Fluke 88 (I have X11 on my 93) as well as o2 voltage but
having a scanner with code reading ability and self adaptation reset considering it's 80's technology
is pretty good when you consider the cost of the alternative scanners.
It does everything I need and even works on ME cars.
I bought the 99 cartridge as well as the 2003 because of your posts.
Mine doesn't update at all. I let it sit five minutes, zero data update. Everything else works normally, really odd that only one system has issues. It definitely is a big help though, but you still need a blink code reader for ABS/ASR, SRS, etc.
ADMIN EDIT: Discussion after this point changed to ASR systems instead of ignition. That discussion has been cleaved off and moved to a new thread at this link.
:tejas:
After having removed my original / stock distributor insulators behind the cap and rotor, and replaced the camshaft seals, I have come to the following conclusion about moisture behind the insulators causing ignition issues / rough running.
I believe that the camshaft oil seals tend to wear from camshaft friction against the softer, ribbed seal surface as they age, in addition to getting harder and more brittle (with both age and heat cycles) over time.
This results in the already microscopic sealing surface between the seal and cam to have a slightly larger opening for minute amounts of BOTH oil mist and crankcase moisture+vapors to leak from the inside of the cylinder head to the outside of the head, and coaslesce onto the backs of the distributor insulators.
In worse cases, this can result in leakage of this mist+vapor PAST the backs of the insulators, through the rotor hole in the center of the insulator, and onto the fronts of the insulators and onto the insides of the distributor caps.
Over time and many millions of camshaft rotations, this combination of motor oil mist and vapors builds up wherever it is landing, and eventually forms an electrically conductive path (or paths). These paths then "short circuit" the proper electrical flow of the spark from the center of the distrubutor cap, through the rotor, to each of the four electrical contacts at the edges of the cap.
When the car is not driven, particularly in wet or humid climes, there is also the opportunity for additional moisture to enter the system, or for the humidity in the air to "activate" the moisture in the cap/rotor/insulator vicinity and make it more electrically conductive.
This short circuiting is what leads to the hiccups and rough running.
The running of the engine, and heating up of the area due to engine heat, eventually dries out the humidity and excess moisture in the area, and REDUCES (but does NOT eliminate) the "shorted" electrical pathways that are created. This is why the process repeats itself when the car is not driven for a period of a week or two.
Replacing the caps, rotors and insulators is a stop-gap problem, and DOES solve the problem for a period of time.
However, the REAL solution to the problem is not only to replace those components, BUT ALSO to replace the two camshaft seals behind the insulator discs.
What people are not getting, 100%, is that due to higher pressure INSIDE the engine than outside of it, and the fact that the cam seals are worn, there is a very slight pressure-effect that is blowing moisture and oil + crankcase vapors past the camshaft seal outward into the atmosphere ... and this atmosphere is onto the backs of the insulators and through their center hole into the distributor caps (eventually).
So, for folks who are suffering from this issue ... the ONLY real solution is not only as you have been, to replace the caps/rotors/insulators, but AT THE SAME TIME to replace the camshaft seals. This is not a trivial job, but CAN BE DONE as a DIY job, and DOES NOT require that the front cylinder head covers be removed (although this makes the process much easier).
Anyway, I have done a lot of reading of threads on this forum, and studies the issue quite a bit, and this is the final conclusion on this issue. I am sorry to have to report that it is a modestly more complicated issue than just replacing a few ignition parts. It is more important to attack the root of the problem, and this is the camshaft seals that are allowing the release of crankcase and oil vapors outside of the engine.
P.S. By the way, I NEVER had problems with the rough running/stumbling on my car. I didn't have major issues with wetness or oiliness on the backs of my distributor insulators. My cam seals were not significantly leaking. This post is based on my experience and understanding with wear patterns and how things work.
We've been doing cam seals as part of cap/rotor/insulator replacement for a number of years now...unless it's Perfectly dry/they have been replaced prior.
At this point most any seal that keeps oil at Bay is suspect and when replacement is Easy as these are it's a Good idea to freshen em up.
Pro tip, order 3 when you go to do the job...sometimes one doesn't go well :jono:
Jono
Gerry, excellent and sound theory, worthy of an Aircrash Confidential.
In my case, I had to replace 1 yo/~3k mi caps and rotors 2 months after I moved from SoCal to Virginia, and have not had issue for 2+years/20+k mi). Virginia is A LOT more humid vs southern California, and it rains every other day, it seems. In CA my car was always garaged, in VA always parked in driveway, under the elements. I had one hiccup in July or August of this year when hurricane "something" brought extra heavy rain into VA and the car sat for a week under it. That hiccup cleared in one drive and hasn't resurfaced since.
I guess sometimes Bosch caps and/or rotors are the primary culprit
They may be the culprit, but more often than not they are going to be the SYMPTOM of the larger problem. As I said, sometimes treating the symptoms will make the problem go away, but unless the seals are replaced, the problem will eventually return.
I am going to put out there that the cam seals should be replaced every ~100K miles, give or take.
Jono
And I'll bet that stumbling problems attributable to moisture/vapors/electrical tracks on the ignition components have been dramatically reduced as a result.
Another thing that I think people don't get with regard to seals is that it doesn't just take wear against the seals to shrink or deform them to the point where they seep/vapor is forced past them. Age can also make them harder and more brittle.
I did this comparison with my cam seals when I removed them. They were DEMONSTRABLY less pliable than the Elring replacements, as desribed here.
Didn't someone recently replace these seals, without removing the aluminum front cover from the head? Sounds like we need a HOW-TO on this.
Carefully dig them out with a suitable pick/small screw driver......emphasis on the careful so you don't damage the housing with said pick...
Do all your cleaning, then oil up new seals, I used an appropriately sized deep socket as a drift..less is more when installing the new ones. It's easy to drive them in to far.
Oh, pay attention to depth of original seals before you dig in...:)
Great time to re-seal the vvt actuators if you're feeling frisky.
Jono
Indeed on the VVT actuator re-seal. I have a 'mixed bag' M119 wrt cam seals, by which I mean one of my cam seals has been replaced, and the other one has not (appears original). I have continued to notice the oily residue on the interior of BOTH distributor caps (L& R). Makes me wonder if my leaky VVTs have anything to do with it.
Seems far fetched, but I am running out of theories at this point.
If the VVT's (intake cam adjuster solenoid/magnet) are leaking, the oil runs right along the bottom edge of the cap.
If the radial seal ring on the shaft which drives the rotor is new, and there is STILL oily residue appearing, an oil source upstream would be the most likely suspect.
