18" Neez?
Nice. Do you like the NEEZ?
Hi - I have assumed 9.0J, we did not measure them but essentially that is approximate measurement having them size by side on the floor next to the EVOs which are 8.25J. The ET and width specs not stamped on the wheel, I can't remember the number stamped but they were all the same.Nice. Do you like the NEEZ?
Are these F 18x9 ET 26 with R 18x9.5 ET 28 with ball seat bolts or are these
F 18x8.5 ET 23 with R 18x9.5 ET 25 with cone seat bolts?
What tires are you running? How do they ride relative to 17" EVOs?
NEVER MIND --- I see you are running a square setup.
If they are all 18x9.0 ET 26, does this mean these all have ball seat bolts?
Ah, the width and offset is engraved on the inner lips like so. However if the wheel has previously been refinished, this may be filledin w/ paint/powder.Hi - I have assumed 9.0J, we did not measure them but essentially that is approximate measurement having them size by side on the floor next to the EVOs which are 8.25J. The ET and width specs not stamped on the wheel, I can't remember the number stamped but they were all the same.
I don't know about the bolts but my original MB bolts worked fine with these wheels, without issue. The car these wheels came off was imported to the UAE from Japan over 5 years ago, by the look of the original bolts which came off that particular car we can conclude these wheels have probably been on the for quite a long time.
I really like the alloys TBH, pretty stock look and if I get on with the ride/look over time I will certainly have the wheels fully refurbished and diamond cut on the faces.
Thanks for that dude - did not know this - will check next time a wheel is off. I do not know if they've been refurbished before, look good from 5m away but up close they need work so might be original.Ah, the width and offset is engraved on the inner lips like so. However if the wheel has previously been refinished, this may be filledin w/ paint/powder.
btw if you are using mb ball seat bolts, closely examine the orig neez bolts. They might be 14R with a shoulder for size 14 holes. Mb w124 bolts are sized for size 12 holes and use 12R ball seats. You can clean up orig neez bolts with a wire wheel.
From the one photo, it does look like the rear is a bit high. Can you post measurements from fender lip to wheel center? Stock should be a bit less than 14" up front, and a bit more than 14" in the rear. Note the fuel tank level when measuring, as full vs empty can change the rear number 1/4-1/2". See photo below. If the rear won't drop by adjusting the SLS, you'll need to swap in Limited rear springs, and/or cut a small amount off (try 1/4 coil) from either stock or Limited springs. If you want the rear below ~14" you'll almost certainly need to cut the springs. BT, DT...I think the rear needs to come down slightly (divided opinion though from 4 other E500E fans), I'll probably try SLS adjustment first and see if that makes any difference.
It should reduce front body roll a little. Not a huge difference, but if your friend is giving you a decent deal, I'd jump on that. It uses the same 22mm outer bushings (124-323-51-85) and larger 30mm bushings from the R129 in the middle (129-323-01-85).I've been offered an AMG E60 front anti roll bar from a friend - any difference vs. stock? What bushes do they take?
Thanks dude, we ok with cutting springs on the forum ??? LolFrom the one photo, it does look like the rear is a bit high. Can you post measurements from fender lip to wheel center? Stock should be a bit less than 14" up front, and a bit more than 14" in the rear. Note the fuel tank level when measuring, as full vs empty can change the rear number 1/4-1/2". See photo below. If the rear won't drop by adjusting the SLS, you'll need to swap in Limited rear springs, and/or cut a small amount off (try 1/4 coil) from either stock or Limited springs. If you want the rear below ~14" you'll almost certainly need to cut the springs. BT, DT...
I don't like to, but I haven't yet found a suitable replacement spring that is slightly lower than the Limited spring.Thanks dude, we ok with cutting springs on the forum ??? Lol
Doesn’t @e500.org have a ltd car already, and didn’t he just put new rear springs on it?I don't like to, but I haven't yet found a suitable replacement spring that is slightly lower than the Limited spring.
Old springs still with me...they're going to get butchered if the SLS adjustment doesn't do the jobOOOPS, yeah, if it already has Limited rear springs... time to bring out the cutoff wheel (on the old springs, if available).
LOL! Yup they're new LTD springs on the rear, it would pain me to cut those but I still have the old rears so they may undergo surgery for stanceDoesn’t @e500.org have a ltd car already, and didn’t he just put new rear springs on it?
BTW @500.org, dude, glad to see, dude, you are adopting correct ‘Murican slang, dude.
Out of curiosity, when you put in the new LTD springs, did the rear of your car go up? (meaning were the old springs sagged a little)?LOL! Yup they're new LTD springs on the rear, it would pain me to cut those but I still have the old rears so they may undergo surgery for stance
Yup the rear did go up a little, noticable amount I'd say but still quite minimal overall.Out of curiosity, when you put in the new LTD springs, did the rear of your car go up? (meaning were the old springs sagged a little)?
I also have a new pair of LTD rear springs but I have not installed them yet. I suspect my OE non-LTD springs, which are on the car, have already sagged a little.
Hi Bill,I've been offered an AMG E60 front anti roll bar from a friend - any difference vs. stock? What bushes do they take?
This might help.Thanks for that dude - did not know this - will check next time a wheel is off. I do not know if they've been refurbished before, look good from 5m away but up close they need work so might be original.
Nice find! Note this issue *should* be picked up with a cold pressure test, which is always a good idea for cooling system diagnostics, and IMO is a good idea to pressure test every year or so (maybe every other oil change or something).I think I found the culprit for slightly higher temp running…coolant tank is split at the top where the cap screws on, water bubbling out when warmed up … CHANGE YOUR COOLANT TANK ASAP! & cap. Amateur move by me running the original one still, I should know better! I hope this fixes the issue…..
Correct... that will be a separate issue. The cut-in temp depends on the rating of the resistor added in parallel to the 2-pin temp sensor (aka "CoolHarness" modification). Generally this reduces it from 107C down to ±95C or so. If your engine isn't getting to the upper 90's, the fans may still not trigger. You don't need them on all the time anyway.AC fans still not coming on when car fully warmed up - @gsxr Dave I note you mention 107C before they come on, however mine have come on at temperatures much below that, so I assume I have a cooling modification. Do you refer to the temperature sensor plug at the top of the engine - if so, that indeed on mine has been modified. I assume this is not related to the coolant pressure issue?
Thanks buddy, I think I may have found the issue, the fuse on an orange relay is blown, will replace the fuse tomorrow and see if it activates them again.Correct... that will be a separate issue. The cut-in temp depends on the rating of the resistor added in parallel to the 2-pin temp sensor (aka "CoolHarness" modification). Generally this reduces it from 107C down to ±95C or so. If your engine isn't getting to the upper 90's, the fans may still not trigger. You don't need them on all the time anyway.
You can find the Electrical diagrams, 036 specific, here: 24 Electrical TroubleshootingThanks buddy, I think I may have found the issue, the fuse on an orange relay is blown, will replace the fuse tomorrow and see if it activates them again.
I don’t have wiring diagram and can’t find it in WIS. It appears someone replaced a fuse on the blue relay in the past. I will probably replace them all tomorrow as preventative maintenance.
View attachment 142575View attachment 142576View attachment 142577View attachment 142578View attachment 142579
Thanks, much appreciated!You can find the Electrical diagrams, 036 specific, here: 24 Electrical Troubleshooting
As well, for precautionary measures, it might be good to replace those aluminum fuses with copper ones, which are less susceptible to corrosion.
Bill, I’m on my 3rd coolant tank. I replaced a perfectly good brownish coolant tank when I first bought my car in 2004, a few years later I had to replace the new white coolant tank for the same reason as you. The NECK was LEAKING. It was very disappointing to say the least.I think I found the culprit for slightly higher temp running…coolant tank is split at the top where the cap screws on, water bubbling out when warmed up … CHANGE YOUR COOLANT TANK ASAP! & cap. Amateur move by me running the original one still, I should know better! I hope this fixes the issue…..
I have a feeling that the original brownish tank was of better construction and if I had left tha ugly part on the car it would still be functioning. Probably was a mistake but I actually threw it in the trash.I dealt with the same leakage. Yours was a sour experience, Terry, being a new product. Without a pressure tester, it took quite a few drives before I discovered the wetness below the cap.
I actually have a coolant level sensor in my parts stash, indeed that will be replaced at the same time 'whilst in there'...Low speed turns on & off based on refrigerant pressure, on a warm day with AC running, this is normal.
If the system isn't pressurized, yes it may run slightly warmer. I think. You may want to replace the level sender in the reservoir at the same time (OE/OEM only) unless it is recent and can be swapped over.
Do your homework on the lowering options. I had H&R springs on a car years ago and removed them. The front was too low and the rear wasn't low enough, and there was no way to raise the front. What is the distance in inches from bottom of fender lip to wheel center, front & rear? Note the fuel load also, this affects the rear measurement.Car needs lowering also, will try with adjusting SLS first and if no joy, I’ll be going with H&R springs. That should keep me busy this year
Thanks Dave, I’m really happy with the front, just not the rear, it’s far too high and the car does not sit nice. I have to admit I’ve not looked at the SLS adjustment yet so that’s next on the agenda.Do your homework on the lowering options. I had H&R springs on a car years ago and removed them. The front was too low and the rear wasn't low enough, and there was no way to raise the front. What is the distance in inches from bottom of fender lip to wheel center, front & rear? Note the fuel load also, this affects the rear measurement.
Your ride height looks nearly perfect to my eyes. If you want the rear lower, try Limited springs first, or cut 1/4 coil off the existing rear springs along with an SLS adjustment. I assume you are on 1-pt front pads already, if not, try that up front.
Got it - start by measuring the rear from fender lip to wheel center, and we can determine if the SLS is artificially lifting the rear or not. Otherwise you'll need to cut the Limited springs SLIGHTLY. About 1/4 coil should be plenty. Or cut 1/4 to 1/3 coil off the stock rear springs. I've done this on a couple of cars and it works very well. It's a lot of trial & error with spring pads and SLS adjustment to get it all sorted.I’m on Limited rear springs and 1 nib pads already. Cutting the rear springs is a last resort for me but I can get it done as I’ve got the old original set of rear springs I could technically butcher.
Tyres are fine, no issues to report at all.@e500.org How you like those MPS4S? I note that yours are made in Germany, 27th week of 2021.
The ones that I had so much trouble with (and returned and refunded) were made in the 14th and 19 th week of 2021 in the USA. I have also spoken with another 124 owner with 18” MPS4S here in the USA that is getting vibrations from those tires.
Btw do you prefer polishing? Or is there no one local that will machine finish those alloys?
