MODERATOR'S NOTE: There is a supplemental HOW-TO guide for this job, located here. It is advised to read both the original and supplemental HOW-TO guides to best understand and achieve this job.
Today, I attempted to replace the transmission overload protection switch, located on the left side of the transmission. The last time I did this, I had no wrench or socket that would fit over the 35mm nut, which is an integral part of the switch.
I was told by a tech years ago that he used an air chisel to spin the nut off. It worked for me the last time, but this time when I tried it, the nut was so fused to the transmission that it just wouldn't budge. In fact, as you can see from the picture, I actually removed a piece of the nut.
In metric size sockets, all I had was a 34mm and 36mm (the 36 being a little too loose). I found that a 1 3/8" socket was a very snug fit. The problem (as anyone who has done this knows) is that there is limited space between the transmission tunnel and the nut, even when the four transmission crossmember bolts are removed and the transmission is lowered on a jack as far as it will go on its own weight.
My socket and a 3/4" drive breaker bar were way too large for the space, so I used a Dremmel tool to cut about 3/8" off the bottom of the socket (it took about 20 minutes of grinding). I also cut the end of a 3/4" drive extension so there would be just enough room to get it into the socket and get a long, 22mm box end wrench on it to turn the socket. (NB: I learned that Craftsman Dremmel blades last about 1/5 the time as Dremmel brand blades for this type of cutting.).
Still, the nut, which is only 3/16" thick, is so fused onto the transmission that the socket is slipping off as I try to turn it. The fit between the socket and nut is so tight that I actually have to hammer the socket onto the nut--and it's still slipping.
What I think contributes to the difficulty is that I'm on my back and I don't have much maneuvering room to work with. I put this away for another day where I can jack the car up higher and try to figure out how to wedge something between the transmission tunnel and socket to keep it from slipping off. I'll probably soak it a few times in penetrating spray to see if that helps. With all the rubber up there, there's no way to get a torch on it.
In the mean time, has anyone else dealt with a fused switch like this without the benefit of a lift?
