First hours of work done today, I'll continue this evening. Now I'm close!
Cleaned the valve covers, they turned out ok, it's at least a huge improvement over how they looked before:
Before:
After:
After:
After this it was time to vacuum everything in and around the inlet ports, to try to ensure that there are no foreign objects there. Fitted the manifold gaskets:
Manifold in place, vacuum hoses routed:
Connected everything to the throttle linkage:
Fitted plug wires guide and the plastic bits surrounding the magnets and distributors:
I have routed the vacuum hoses and used insulator cable to protect and collect the hoses. The EZL cables also got re-insulated.
It all seems like 30 minutes of work when I write this post, but I spent a good six hours in the shop today.
There's a lot of things to get right when doing this kind of job, takes some thinking to figure out the easiest way to route vacuum hoses when putting everything back.
I'm taking it slow, trying to avoid silly mistakes. I made one today though, and that was when tightening the intake manifold screw that also holds the plug cable support. I was busy looking at my torque wrench, so I missed that the plastic thing began to spin due to no lubrication. *Snap* and it broke. I'll glue it for now, at least it broke off clean and not in a million pieces. I've added the plastic bit to my shopping list.
Well, I'll be back with post nr. 2 for today later this evening, going back to the shop after some dinner with my wife and son.
